Question about Goodman CLQ36AR49 Air Conditioner
Is there a reset botton for goodman - Goodman CLQ36AR49 Air Conditioner
  • 1 more comment
  • wardwardell May 09, 2010
    the problem with my unit is some came out to fix the heat and that did not work so from that the ac stopped working, and no heat still...now trying to trouble shoot every thing i got the heat to work, and in order for air to work i had to use piece of paper to prime ac unit to work, but without the paper there holding down button the ac will not work, so i need to find a way to fix this problem because now it stays one constantly . thanks
  • Brian Niten May 11, 2010
    What button do you have the paper stuck in? Are you talking about the contactor in the outside unit.
    What are you trying to reset?
  • 88 Answers
No reset for the goodman...is nothing coming on..or is it the outdoor unit only....please give input...
Posted on May 10, 2010
  • Michael Dorris May 10, 2010
    sounds like you..have a low voltage problem..so the contactor wont pull in...call to help troubleshoot...michael 843-384-8474...
WHERE IS THE Goodman GSZ130301 RESET BUTTON ON CONDENSOR
No reset button. As for low/high pressure switches they reset on their own when the problem is corrected. Usually low refrigerant.
May 03, 2014 | Goodman Manufacturing Goodman GSZ130301...
My Switching adapter does not work. Where can I obtain a new one?
Good day
hi you dont need to wory about the switch.. you can use your reset botton for the mean time
because the reset botton is same in on/off switch..
the reset botton have 2pins same as the on/off switch i hope i help you...
May 31, 2011 | Computers & Internet
Were is the reset button on my goodman heater?
Goodman doesn't make a reset button, however you can shut the power off at the breakers or at the switch for the furnace power if equipped.
Jan 02, 2011 | Goodman GMS90703BXA Heater
Does the a/c have a reset botton?
The best way to reset these units are to find the breaker and turn the power off to the outside condenser and the inside furnace. There will be two different breakers. Just wait a few seconds and kick everything back on. This usually doesn't fix anything, but will give you a place to start if you can see what it does before it stops working or if it just doesn't work at all. Hope this helps and good luck!
Sep 11, 2010 | Goodman CKL60AR60 Air Conditioner
# 3 and H Flashing ... will not do anything else ?
TO RESET THE MACINE PRESS THE ORANGE BOTTON (C),PRESS THE BOTTON UNDER THE AUTO DENSITY LIGHT,RETURN TO THE FIRST ORANGE BOTTON THEN THE AUTO DENSITY BOTTON, YOU HAVE TO BE FAST WHEN PRESSING THE BOTTONS, ALL THE LIGHT ON THE DISPLAY WILL GO OFF THEN PRESS 14 AND PRESS THE GREEN PRINT BOTTON,THE MACHINE WILL RESET AND START TO WORK, BUT IF THE PROBLEM COUNTNUE CHANGE THE FUSER UNIT.
Sep 10, 2010 | Sharp AL-1000 Copier
Give me nokia 5800 master code
I was also looking for that, but i couldn't find it. But i got one solution to format Nokia 5800 it doesn't work for security code.
To format or hard reset nokia 5800 press 'green key, red key and camera botton. After pressing these three botton, press the power which is located at the top. When it shake release only the power botton not the green, red and camera botton. It will start up your phone and after sometime it will display country botton and now you can release the keys. Thats it. This is call Hard Reset.
Jul 22, 2010 | Nokia 5800 XpressMusic Smartphone
Do i need to turn a switch on or off on my goodman unit or the furnace? how do i prep for the summer with out calling a tech?
There are no switches other than the breaker and outdoor disconnect that need to be on. Change your filter in the furnace. I would take a hose to the outdoor coil on the condenser to clean out any dirt and leaves on the coils. Do not spray on high pressure. Just get a good light pressure and spreay from top to botton perpindicular to the fins and up at a 45 degree angle. Other than that, set the thermostat to cool and you should be good to go.
Jun 06, 2010 | Goodman CLJ30AR32 Air Conditioner
How to reset and format
*#7780#
do rply
Jan 12, 2009 | Nokia 6600
Siemens Sx66 Pda phone- not responding for hard reset-
Hello, Did my solution fix your SX66 problem?
Jun 23, 2008 | Siemens SX66
Goodman CLQ36AR49 Air Conditioner Logo
267 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
