Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Wont agitate, spin or drain
Whirlpool model # LSQ9695LWO wont agitate, spin or drain. makes humming noise when turned on then clicks off.
  • brats4 Mar 27, 2008
    that was model # LSQ9659LWO
  • brats4 Mar 28, 2008
    Your instructions were perfect!! Found out the pump was jammed. Took about an hour from start to finish. Thanks so much for your help Tech 17!
    President:
  • 1,314 Answers
More than likely you have something jamming your pump im going to give you the procedure for replacing the motor coupling but stop at the pump take the hoses off of it and see if its jammed if not then reply to me and we will go further First unplug the washer and turn off the water. If you have a shop vac take the drain hose out of the drain, and through the drain hose vacuum the water out of your washer. If you don't have a shop vac go to the auto parts store and buy a pair of radiator hose clamps. Then facing the washer locates the two screws. They will either be in the front or rear of the control panel or back them out far as you can. Once you have done that pull the control panel slightly forward, and tilt it back on the hinges. Now unplug the lid switch wire but don't forget to plug it back when you’re done. Next locate at the rear of the washer body the two gold clips then push forward, and take careful note of how they fit. Then pop them out with a screw driver tilt the washer body forward at 45 degree angel and walk forward with the body, and set it down. Now you will see the white pump and motor assembly. You should see two clips holding the pump to the motor pop them off, and pull the pump off the motor shaft. Now if you fell the need to remove the pump use the radiator hose clamp. Take them and clamp the hose coming from the tub but it’s not necessary for the repair. Next disconnect the wiring harness from the motor (note the position of the harness for reassembly). Remove the two 5/16 inch screws from the motor clamps and pop the clamps off. Once that is complete, remove the motor put the new coupling on the motor and transmission shaft. I use a socket and a hammer
Posted on Mar 27, 2008
  • robert samples Mar 28, 2008
    glad to assist but you fixed it
SOURCE:
Whirlpool heavy duty extra large capacity washer,washes, water drains, won't spin, makes a humming noise (not loud) when trying to spin
Are you sure it’s agitating? If it isn’t agitating or spinning, then motor coupler is most likely broken. If it is actually agitating, but not spinning, clutch may be bad or article of clear thing could be lodged between basket and tub.
Sep 21, 2018 | Whirlpool Washing Machines
Whirlpool washing machine wont drain or spin but will agitate
you have a bad lid switch. located under lid on left side of machine.
Dec 24, 2014 | Whirlpool Washing Machines
Know when clutch going bad
Needs agitator dogs in agitator.
Mar 13, 2014 | Whirlpool Washing Machines
My Whirlpool Ultimate Care II LSB6300PW0 is about 6.5 years old. In the middle of a wash it started making a very loud humming noise. The machine wont agitate or spin. It still fills and drains the water...
Renee,
This might be too late for you but hope it helps!
I was able to fix a similar problem with the same model washer of a similar age so see if any of the following helps you.
Our washer died during a rinse/spin cycle and started making a horrific spinning/clicking sound when it was supposed to be agitating or spinning. It filled and drained like normal, and the horrific noise stopped when the lid was lifted.
Because of those two facts, I discovered it was likely the direct drive coupling, which connects the washer's motor to the transmission.
Turns out, that horrific sound was indeed the sound of one of the couplings spinning uselessly after it broke.
After some internet research, I discovered it was a simple matter of getting and installing the new coupling, which was very easy to do with a little professional help via YouTube:
Also, here is the website of a parts supplier with great schematics and great prices that I bought the part from.
Dec 22, 2010 | Whirlpool LSB6300PW Top Load Washer
Washer won't agitate. New transmission...new timer.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Top load, direct drive Whirlpool / Kenmore washers use a reversing motor.
It turns one way for agitating and reverses for draining and spinning.
It sounds as if either the motor is shot or one of the connectors is bad.
As a place to start, see the Whirlpool Service manuasl (with wiring diagrams) for their top load, direct drive washers.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Feb 13, 2010 | Kenmore 24832 Top Load Washer
Washing Machine wont spin/agitate
The most common problem is the lid switch. with a screw driver in hand open the lid and press down on the lid switch. sometimes the mounting screws will crack the switch housing and the striker can't move the actuator far enough. I am interested in the clicking noise, as this could indicate a pump issue or a sock seizing up the tub.
Jun 14, 2009 | Kenmore 12502 Top Load Washer
Whirlpool direct drive top loader will not spin
Hi, Is the humming noise coming from the timer area? Do you know if it agitates ok?
When you have it in spin cycle, Try lifting the lid and see if the hum stops.
The reason for these questions is that on this model, if it drains the water out but does not spin, it is either lid switch, coupler, or transmission.
If it's the coupler, it will not agitate either.
Please let me know so I can assist you further.
Thanks
Vic
May 30, 2009 | Whirlpool LSR8433K Top Load Washer
WHIRLPOOL WASHING MACHINE WON'T SPIN
replace coupler between motor and gearbox.
Mar 08, 2009 | Washing Machines
Agitator won't turn and tub won't spin
The motor coupling is broken, the part located between the motor and the transmission.
Dec 25, 2008 | Whirlpool Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
154 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
