Question about LG LS-L1210CL Mini Split Air Conditioner
Our air conditioning unit is not giving cold air
    Problem Solver:
  • 11 Answers
You are low on refrigerant and most likely have a small leak.
Posted on May 21, 2010
2003 ford zx2 air conditioning not blowing cold air
Check and see if there is any Ice on the copper line that runs from condenser (outside unit) to air handler (inside) if so you need a charge. You can also make sure the fan is working on the condenser unit outside it should spin when you have the air on. If it is not you have a bad fan motor. there are other things it could be but these you can see.
May 25, 2015 | 2003 Ford ZX2
Tip
How Heat Pumps Work
How on earth can you get hot air or hot water from very cold outside air? How does a heat pump make this heat out of cold air?
When certain gases change their state from a liquid to a gas or from a gas to a liquid the magic happens.
A heat pump can do some pretty amazing things, when it comes to making heat. To understand the way they work, you must first understand what happens when certain gases change from a liquid state to a gas and back to a liquid again. To simplify it a bit we need to look at a basic air conditioning system. The refrigerant in an air conditioning system is changing to a liquid in the outdoor condenser. The compressor compresses the gas forming a hot gas. As this gas cools under high pressure it changes into a liquid form.
Inside the indoor coil the liquid is pushed through a small hole or orifice. When it comes out the other side it rapidly changes it’s state to a gas as the pressure suddenly drops. The rapid pressure drop changes the refrigerant to a very cold gas. Air flowing over the cold gas inside the pipes makes the air cool and provides air conditioning.
Now for a heat pump the process is much the same, only coils are just switched by used a reversing valve in the outdoor condenser unit. Instead of the heat being purged to the outside from the condenser unit, the indoor unit then becomes the condenser coil. The outdoor coil becomes the cold coil and cools the outside. This is why if it is very cold outside the unit will have to run in air conditioning mode for a short time to defrost the outside cold coil. When this happens the system will usually have electric heat inside to run and keep the indoor air warm.
The reality is that a heat pump is really no more than an air conditioner running in reverse. Through the magic of using refrigerants, a heat pump can then run many times more efficiently than straight electric heat. A careful heat loss/gain should always be performed by a qualified service person before any sizing of a unit. Too large or too small of a heat pump system can make it inefficient and possibly cause it to be very uncomfortable. The longevity of the unit can also be affected by sizing and installation. Be patient and look carefully for the best contractor to install your system.
A properly designed and installed heat pump system can give you many years of comfort and efficiency. If you look for and find the contractor that can do the job right you will get many trouble free comfortable years from your heat pump unit.
on Dec 29, 2009 | Heating & Cooling
My EverStart portable air conditioning unit
sounds like you need to wash your condenser coil. Sounds like your compressor is kicking out on high head pressure. Once it cools off it starts cooling again take it out and give it a bath don't get the electric wet.
Sep 12, 2014 | Heating & Cooling
My amana window ac is blowing condesation out the vents. it is still cooling..is this a problem
There is a condensation drain on the unit that is probably plugged. It is natural for air conditioning units to produce condensation as the evaporator coil (the coil/fins that make the air cold as a fan blows air across it ) is much colder than the outside air temperature ( usually between 38 and 55 degrees depending on the unit ). There is a basin or tray at the bottom of the unit that catches the condensation as it drips off the evaporator coil, and there is a drain that allows the water to drain form the unit. If this becomes plugged the water will build up and eventually drip out of the vents of the unit. http://www.air-conditioning-and-refrigeration-guide.com/air-conditioning-circuit-and-cycle-diagram.html
In the image, air is blown across the coil in the bottom left section of the picture ( this is the "cold' coil). Condensation can form on this.
Jul 29, 2011 | Amana Quiet Zone 12M12TA Air Conditioner
The air conditioning system will only blow cold air. Regardless of the mode, I can only get cold air. Can you give me an idea on how to fix the problem? Thanks Don 615-653-3834 drcamp117@comcast.net
The air conditioning is supposed to blow only cold air. Are you trying to get the heater to blow hot air? Make sure the temperature selector is in the hot position.
Dec 19, 2010 | 2002 Buick LeSabre
I have a 2001 Honda Odyssey. I only recently bought this. The rear air con vents only blow out cold air, no matter what the temperature it is set to. The dealer I bought from said this was standard, and...
I've have never heard of a "only cold air system", but hey, nothing surprises me anymore. try replacing the control unit in the front. hopefully that will take care of the problem. If not you need to check your blend valve. (headache depending on location)
Aug 02, 2010 | 2000 Honda Odyssey
My Carrier Home AC unit stopped blowing cold air today. I opened it up and cleaned everything and didn't notice anything out of place, any ideas?
This could be complicated to resolve over the internet but I'll give it a try. When you stated that it stoped blowing cold air, did it stop blowing air all together? Also is the outside unit rtunning?
Sep 05, 2009 | Carrier 38CKC042 Air Conditioner
Panasonic air con unit is not blowing cold air out.
This unit is use in motels etc. Check the ouside coil ( conderser) from the inside (discharge fan ) for dirt. Most of these units are floor level . This can cause a unit to short cycle ( cold air is at the floor) .
Jul 17, 2009 | Carrier 52PQ307 Wall/Window Air...
Air conditioning unit
It sounds like both of your units has a refrigerant leak, if its not still under warranty, time for a new unit.
Greg.
Aug 17, 2008 | Heating & Cooling
No cold air
Unless you are EPA Certified you can not charge an air conditioning system with refrigerant. You would need to check with gauges to see the pressures. You would need to find where the leak is. And you would have to buy refrigerant. Does it sound like the compressor is coming on when you turn it on or just the fan? If the compressor isnt coming on it could be a realy or contactor.
Jun 09, 2008 | Maytag M6D24E7A Air Conditioner
LG LS-L1210CL Mini Split Air Conditioner Logo
261 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
