Question about Garden
How to replace pull cord on ryobi 725r trimmer?
  • 3,740 Answers
Before you start... transfer the handle assy to the new rope. Remove the old rope and install the new rope just like the old one. Make sure to tie 1 knot in the end of the rope so that the rope ded not pull out of the handle
-Remove the recoil assy.
-Remove the old rope.
-Wind the spool counter clockwise until it stops
-Back up the spool until the rope hole aligns with the rope guide. DO NOT let the spool unwind. It really takes 2 people to do this.
-Burn the end of the new rope with a match and very quickly while it is still soft. pinch the end of the rope to make it as small as possible.
-Thread the new rope through the rope guide and into the hole for the knot of the spool.
-Use a scribe or needle to lift and pull the new rope through the hole
-Tie 1 knot in the rope
-Pull the knot into the hole in the spool
-Let go of the spool and the rope will rewind
-Install recoil assy
-RETURN TO SERVICE
Thanks for using FixYa!
Kelly
Posted on May 09, 2010
Replacment of starter pull cord
Remove the recoil cap cut the knot of the old cord off pull out the string. Cut a new cord the same length thread it in and knot it . rewind the spool until the cord in the spool. fish the cord out of the pull hole and tie on the pull handle
Aug 04, 2009 | Ryobi Factory Reconditioned 18" 40cc...
2 Cycle Gas Trimmer will not start
it is normal to see air bubbles in line when pumping the bulb. to make sure what the problem is, try starting several times, remove spark plug. if dry, yes no fuel, remove the carb. if wet, place plug on engine block and look for blue spark. no spark means you need new plug, plug cord or ignition module
Jul 24, 2009 | Ryobi Factory Reconditioned 18" 40cc...
How to remove drum connector off ryobi weedeater
I believe there are four phillips headed bolts around the outside edge of the housing
Jul 23, 2009 | Ryobi Garden
Need routing of fuel lines on Ryobi string trimmer Model 725R.
The larger fuel line goes from fuel filter to carbuerator.The smaller line is the return line from the purge bulb tofuel tank. mitchjl_1692
May 27, 2009 | Ryobi 15" Electric Factory Reconditioned...
Replacing Drive Shaft for a Ryobi 725r
The lower flex shaft should cost around $40, unless you order it online and have to pay shipping. You should be able to get one from your local MTD dealer. (Ryobi is owned by MTD)
May 25, 2009 | Ryobi Garden
Ryobi gas trimmer stalls when lowering the revoutions
do you have the right kmix fuel to addat start on choke let run tell it dies then pump the ball on half choke and chage the plug
May 15, 2009 | Ryobi 15" Electric Factory Reconditioned...
The pull rope broke on my ryobi 705r/725r gas trimmer. I have all the screws off but it seems to be held on by the center shaft that spins. What do I do now?
I have the same issue of clutch removal on a Ryobi 725r. Actually the clutch finally died after many years of use.
Instead of using a screwdriver to hold the piston I recommend using a piece of clothesline rope. It will be easier on the internal components and won't scratch up the cylinder walls or piston. Just be sure to leave a small amount hanging out of the spark plug hole so you can pull it out afterward.
Apr 15, 2009 | Garden
Ryobi 2 cycle gas trimmer 705r/725r
The gas nipple that come out I have...whats goes in the other hole?
Aug 28, 2008 | Ryobi Garden
Garden Logo
988 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
