Question about IBM ThinkPad R51 Notebook
Subscript numbers are locked so that when I try to type letters -- ie j, k, l . . . I can only get the numbers below. How do I release
  • 88 Answers
you have to turn off Num Lock.
NumLock is on the same button as scroll lock however you have to first press and hold "Fn" (left-bottom corner) and then press NumLock/Scroll Lock or hold "Shift" and then press NumLock/Scroll Lock or hold.
Leave rate if I helped you, thanks!!
Cheers,
Mike
Posted on May 09, 2010
Medion notebook typing normally. getting numbers instead of letters
Examine your keyboard to ensure your "Number Lock" key is not activated.
This activation is indicated by the key being lit up.
If the key is activated, press it to deactivate the lock.
The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
hope this helps
Nov 05, 2012 | Medion md40298 Notebook
Tip
Short cut keys for Blackberry phone,storm,curve,pearl.bold
Typing shortcuts keys for BlackBerry
These shortcuts keys can be used when typing text in Blackberry:
  • If you want to type the alternate character on a key, hold the Alt key and press the character key.
  • For an accented or special character, hold the letter key and roll the trackball left or right. Click a selected character.
  • To type a symbol, press the Symbol key. To view more symbols, press the Symbol key again. Type the letter that appears below the symbol to insert the corresponding symbol.
  • To insert a period (.), press the Space key twice. The next letter is capitalized.
  • To capitalize a letter, hold the letter key until the capitalized letter appears.
  • To turn NUM lock on, hold the Shift key and press the Alt key.
  • To turn NUM lock off, press the Alt key.
  • To insert an at sign (@) or a period (.) in an email address field, press the Space key.
  • To type a number in a number field, press a number key. You do not need to press the Alt key.
  • In order to type a number in a password field, hold the Alt key and press the number key.
  • To type a letter in a number field, hold the Alt key and use the multi-tap input method to insert the letter.
  • If you are typing input languages, hold the Alt key and press the Enter key. Select a language, then release the Alt key.
Know more about Windows 7
Windows 7 keyboard Shortcuts
on Dec 05, 2009 | Cell Phones
Tip
How to use Blackberry as a modem to acces internet?
Hye mr expert...Here i have some question about my samsung netbook n220 series. For your info...actually this problem never happen before.The problem is some of my key not working & some of my key...
The problem with your Netbook seems to be that you have turned "NUMBER LOCK" or "NUM LOCK" on. This causes some of the letter keys, e.g U,I,O,J,K,L,M to be printed as numbers 0,1,2,3,4,5,6.
To turn this off, hold down the "FN" key (near the bottom left of the keypad) and then press "F11" and then release both keys.
Please try this and post back if you need further assistance.
Regards,
BElectric
Dec 16, 2010 | Samsung N310-13GB Netbook
Why did the subscript numbers of the keyboard are entered instead of letters? how can i change it?
This can happen if the Fn (function key) is held down while the scroll key (number lock) is pressed. Try holding the Fn key down and press the scroll key to see if the letters free up.
Sep 26, 2009 | IBM ThinkPad T42 Notebook
Hi, I've got 2 eeepcs, with identical problems,
When the RH side of the keboard types numbers instead of letters then the Num Lock (number lock) key has been pressed.
Press the Num Lock Key again to return to letters again, usually this is usually done by pressing the Fn key plus and probably the Scroll keys, this key will be also marked NumLk, and there will be a LED light that will indicate when the number lock is on.
Aug 13, 2009 | ASUS Laptop Keyboard for Asus Eee PC
How do you change the text message settings to TAP instead of Abc
How to set up Text Entry Mode?
1. From any text entry screen (ie. when you are writing a text message), press the top center button, the one above the directional wheel.
2. Press on "Entry SetUp"
3. Select the "Primary Set Up" or "Secondary Setup" by choosing your preferred input mode among the ones below. Us the wheel by pressing on the right arrow to change mode:
  • ITAP: it's a built-in software which predicts the word you are typing.
  • TAP: enter individual letters and numbers by pressing the keys multiple times. Ie. for the letter "F" press the number 3 button three times.
  • Tap Extended: enter individual letters, numbers and symbols by pressing the keys multiple times
  • Jun 11, 2009 | Motorola Mobility RAZR V3
    Ibm thinkpad keyboard. i type letters, numbers show up. fix?
    With my IBM Thinkpad, I had to hold Shift+ScrLk to turn off Number Lock.
    Mar 27, 2009 | IBM Thinkpad 560 Series Laptop 20h4241...
    IBM ThinkPad R51 Notebook Logo
    288 people viewed this question
    Top IBM Computers & Internet Experts
    Alun Cox
    Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
