Question about Cub Cadet Lawn Mower Idler Pulley Replaces CUB CADET 01004081
Broken pullcord the pull cord on my cub cadet push mowersnaped and broken and we put it back in and know it wont wind back in
  • 3 Answers
Yeah I got the same problem. My pull cord broke in the first season. On my own once the plastic cover is removed, 4 phillips screws, the cord housing is secured by 3 10mm nuts. Remove them and lift out the housing. On my own unit the spring had also slipped out of the mount on the shaft securing the assembly (another 10mm socket nut will loosen that) and I had to resecure that first, then wind it up before making the knot.. I used a Briggs and Stratton cord from another (truly dead) mower and have had no problems since then.
Posted on Jul 21, 2015
    Problem Solver:
  • 8 Answers
Before you rethread it you must spin housing counter clockwise till you feel tension (if you let it go you have to restart ) then tread it
Posted on May 09, 2010
Cub cadet sltx1050 wont go forward or backwards? was w orking fine then we had to push it backwards to jump iot cause it wouldn't start and now it wont move forward or backward
There are two possible options one is the belt for the drive is shot, the other is that the transmission is shot we tend to go out.
Nov 08, 2017 | Cub Cadet Garden
Cub cadet tank wont move once releasing the parking brake
Not sure what you are trying to do, but in order to push a Cub Cadet (when its not running), you need to put the transmission in ANY gear other than Neutral.
Jul 22, 2017 | Cub Cadet Garden
Cub cadet just dropped dead?
like a car engine broken rod--piston ring--wrist pin --blown gaskets
May 18, 2017 | Cub Cadet Garden
I have a cub cadet bc280 2cycle weedeater the pull string pulls but it want go back in need help please
un screw recoil cover and remove be careful because if spring is broke can cause it to pop out unexpectedly and spring is sharp check rope if off track use screw driver to reinsert and should wind back if rope broken will need to replace if spring or coiler damaged also need replacement
Aug 10, 2016 | Cub Cadet Garden
How can i fix the pto on my cub cadet lawn tractor?
if the engine didn't shut off as well when you bounced out of seat , you 4 sure have a fault in the seat switch , im under the suspicion that seat switch has two contacts one is 4 engine and one is 4 pto
Aug 24, 2015 | Cub Cadet Garden
How to restring cub cadet 173cc push mower
take off the hood remove any old string, now wind up the spring and hold it tight put the new string through the hole in the hood and into the hole in the crank wheel pull it through 6 or 8 in. slowly let the spring unwind now tie a knot in the rope and you're done
Sep 15, 2013 | Mtd 19 In. 173 CC OHV 3-In-1
Cub Cadet has broken pull cord
pull off cap first from engine look inside it pull the rest of the cord out to the end then grab the not onthe pully while holding it pull the rope out after that wind pully all thee way up shuve a new cord throug houseing pully then slowly let rewind up until it stops cut the rope 6 inchs in front of cap hole restall cap to motor slip your starter rope threw grip that you pull pullthe cord attached to handle out two feet hold onto rope cut handle loose slip[ and tie handle again to the houseing rope dont let go of the rope after that let it rewind back up done
Sep 04, 2013 | Garden
Broken Cub Cadet
I dont own one or there but it is an easy repair. Find a wrench/socket that will fit the 3 or 4 bolts holding down the pull cord (recoil) cover and remove them and the cover. (Prob. a 10 mm socket) Then wrap a cord/narrow rope CLOCKWISE around the pulley 3-5 times and prepare mower to start as you normally would and pull the rope. Now you can cut your grass before it becomes unmanageable. Take the recoil to any small engine repair shop and have them replace the rope and then you can reinstall the recoil. In my area the charge $7-$10 for this.
May 20, 2013 | Garden
Cub cadet walking mower, model 959468 can not pull cord to start
there is a the cable that goes to the handle you need to hold that releases the engine brake
Apr 04, 2012 | Cub Cadet Garden
I have a cub cadet lawn mower broken pull cord
just rewind the spring starting with the outer end and fill it back into unit. I always have the rope extended and rewind it back in and reinstall
Jun 07, 2009 | Garden
Cub Cadet Lawn Mower Idler Pulley Replaces CUB CADET 01004081 Logo
540 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
