Question about Stanton T.120 Turntable
Half the signal only through left speaker
Im running a stanton t120 through an older phillips cd player. I run the stanton into the rca inputs of the phillips. the problem is that only of my 2 speakers is working but only when im using a record player (it works fine for an ipod). The stanton has a switch that says line/phono. I dont have a phono input so I switch it to line. Seems like it should work fine but I don't know much about electronics....
    Scholar:
  • 70 Answers
Try the switch in the other position and see if that fixes the problem. some turntables had a phono level that is different than a standard rca line level input. Also try a different cable if the rca is not hardwired in to the turntable. The cable could be bad. If worse comes to worse upgrade to another amplifier or tuner that has a separate phono input. hope that helps.
Posted on May 09, 2010
Testimonial: "thanks a lot i've tried the switch in both positions but it could easily be the cable which is not hard wired!"
Why do my subwoofers not work when connected to an amplifier that is powered?
The bus connection is actually not an RCA looks very, similar i think if you look at it it will say IN. as far as i remember its an input for like a CD changer. Run a Y splitter on one of the other RCA out put, split the signal and run one to your bass amp. it does not affect the voltage in the RCA signal. i think your amp is trying to send a signal instead of receiving one.
Apr 11, 2017 | Sony CDX-GT510 CD Player
Hooking up an amp
yes of course!! since it has pins provided on the wire but make sure you how to connect it OR it will fry your amp.be careful!!! have it consult to a technician for sure.
for better instructions, go to this link:
http://www.caraudiohelp.com/how_to_install_a_car_amp/how_to_install_a_car_amp.htm
this will help you a lot..Goodluck!! rate me here as fixya!!! tnx!!
Feb 05, 2008 | Car Audio & Video
I accidently put the rca wires in the wrong audio input/output on my craig cd graphics karaoke player.Could this be why i have no sound?
The RCA outs are designed to send a signal to an external amplifier. That amplifier, in turn, sends the music signal to speakers.
The RCA inputs are designed to take audio signals from another device (like an ipod, CD Player, or computer) and play it through the Craig System speakers. If you sing into the microphone, the vocals will be mixed with the incoming music. However, in these cases, there won't be lyrics on the screen. If you play a karaoke DVD in a DVD player, connect the red, white and yellow RCA cables from the DVD out to the Craig Inputs, the lyrics should appear on the Craig screen while the music plays.
If you mistakenly plug RCA cables into the Craig Inputs and plug the other end into an amplifier's inputs, neither will produce any sound.
Using RCA outs is only necessary if you want to have louder music than the on-board Craig speakers can handle. Of course, you can run the yellow video cable to a TV RCA input to get a bigger lyrics window and the RED and White RCA to the TV RCA Red and White inputs to hear the music through the TV's speakers.
Aug 30, 2014 | Audio Players & Recorders
Im not geting any sound out of the left side. Its not the speakers or receiver. I ve changed all the wire testing it. It is the left side of the cd player.
the channels burn out its a common fault the quick fix is to buy a rca adaptor to run 1 output to 2 or replace the cd player it will cost a lot less to replace than fix
Jan 02, 2011 | Technics SL-MC50 CD Player
Have a stanton STR8 60 turntable that I forgot about. Hooking up it only has one output. Where do you put it?
turntables have very low output signal need a phono input to amplify it more than cd,cass. if has mono output use rca conn 2 to 1
Jun 10, 2010 | Stanton STR8-60 Turntable
How do i hook up my dvd recorder to my dvd player? where do i hook my cords to?
You need RCA cables to do this.These have red yellow and white cable ends.The yellow is for video the white is for the left speaker,red for the right speaker.Run the RCA cables from the output of you DVD player to the INPUT of your dvd recorder.Run another set of RCA cables from the output of your dvd recorder to the input of your TV.Most modern tv's have these inputs. These RCA cables can be purchased at Radio Shack or places like Walmarts.
Jan 10, 2010 | Lite On LVW-5005X DVD Recorder
I have an Onkyo receiver and left speak stopped
TRY SWITCHING SOURCES, FOR EXAMPLE, IF YOU WERE USING THE CD PLAYER OR OTHER EXTERNAL SOURCE, YOU COULD EASILY HAVE AN RCA CABLE NOT PLUGGED IN OR SIMPLY A BAD RCA CABLE. RATHER THAN START SWAPPING CABLES, SIMPLY USE THE TUNER. IF USING THE TUNER,YOU STILL HAVE THE PROBLEM, CHECK THE SIMPLE BALANCE CONTROL WHICH IS THE ONLY OTHER CONTROL THAT COULD CAUSE YOU TO LOSE THE LEFT CHANNEL. IF AFTER CHECKING IN THIS FASHION AND YOU STILL HAVE NO OUTPUT FROM THE LEFT CHANNEL, THEN ONE LAST THING TO DO IS TO MAYBE CHECK THE SPEAKER SELECTOR SWITCH. RUN IT THROUGH THE DIFFERENT MODES, A, B, A+B, ETC. IF NO BETTER THAN THIS IS ALL YOU CAN CHECK AND THE RECEIVER WILL NEED TO BE SERVICED. BACK TO THE BEGINNING, IF YOU WERE USING AN EXTERNAL SOURCE AND THEN SWITCHED TO USING THE TUNER AND BOTH SPEAKERS STARTED WORKING, THEN CHECK THE RCA CABLES FROM THE EXTERNAL SOURCE. IF NO GOOD, THEN TRY CONNECTING THAT SOURCE TO ANOTHER EXTERNAL INPUT, AS MOST INPUTS ARE SWITCHED BY SENSITIVE CMOS SWITCHING CIRCUITS WHICH CAN BE EASILY DAMAGED, ELECTRICAL TRANSIENTS AND SURGES, CAUSING PROBLEMS LIKE YOU ARE EXPERIENCING, WITH ONE OR MORE OR SOMETIMES ALL INPUTS. THIS MAY ALLOW YOU TO AVOID SENDING IT IN FOR REPAIR. I HOPE THIS HELPS YOU TO TRY ALL OPTIONS BEFORE HAVING TO SEND IT IN FOR REPAIR. BEFORE SENDING IT IN, YOU MAY WANT TO CALL ONKYO AT 800-229-1687 AND ASK FOR DON PHILLIPS IN TECHNICAL. I HOPES THIS HELPS YOU TO GET THIS RECEIVER UP AND RUNNING. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Jan 05, 2010 | Onkyo TX-DS575 Receiver
Back rear speaker wont play when singled out. more details inside
I would suggest you mdisconnect the rear speakers from the amp, take a 9volt battery and click te speakers on at a time. If proble duplicated, the you have the left speaker tied to the right somewhere.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 26, 2009 | Clarion EQS746 Equalizer - 7-Band In-Dash...
HOW DO I INSTALL A RCA ADAPTER TO MY VEHICLE
There should be a diagram entitled "adding and amplifier to a factory stereo" in the owner/install manual of the high to low convertor. You need to signal tap some audio signal from your front or rear stock speakers in the car and those wires need hook up to the high to low convertor's input side. From the convertor you connect RCAs that go to your amp. In other words find your rear speaker wires and hook them to your adapter then hook up the rca wires
Dec 02, 2008 | RCA Pie Pio/P Rca Adapter P Bus Mcd To Aux...
STANTON STR8-150 Sound levels
try different rca leads to amp
Jun 01, 2008 | Stanton STR8-150 Turntable
Stanton T.120 Turntable Logo
164 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Vito Vacirca Jr.
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
