Question about Zonet MULTI FUNCTN USB 2.0 PRNT SRVR (ZPS2000) Print Server
I setup ZPS2000 using Windows XP notebook (not simple). When running software on Windows 7 desktop, the server cannot be found on the network. I can connect via IP address and ping it successfully. I have changed the default IP address of ZPS2000 to an static address in the range used by the Linksys wireless router. Even if I change my desktop IP address to the same range, the Zonet software cannot find the print server.
  • tedp1314 May 09, 2010
    I had already downloaded the latest drivers form this link. I downloaded it again. The file runs an installation wizzard. The installations wizzard cannot fine the printserver on the network. This is the basic problem.
    I tried adding a printer using printers and devices window. I tried adding as a local printer and network printer. I am sure there are many combinations of setups in these options, but I cannot find the printer on the network.
    "Add a wireless device to the network" - Windows did not find any devices to add.
    "View network computers and devices" to see the printers on the network. - There are no printers displayed in this window.
  • 493 Answers
Please download the windows 7 compatible drivers of your device by clicking this link.
- Download and install the driver.
- Check your device from the Control panel > View devices and printers
- Make your device default printer (be sure it is checked)
Hope this helps.
If not, use Add a device option to find your device.
Waiting your comments.
Posted on May 09, 2010
  • 1 more comment
  • Ibrahim OKTAY
    Ibrahim OKTAY May 09, 2010
    Hi again,
    You have Windows 7 operating system.
    Please do the followings:
    - Go to control panel,
    - Directly click on the "Network and Internet" (Green on top)
    - click "Add a wireless device to the network"
    (then you can select "View network computers and devices" to see the printers on the network.)
    Hope this helps.
  • Ibrahim OKTAY
    The wireless connection from your notebook to DSL-router may
    interfere with the network connection to the ZPS2000. Shut that down.
    Please do the following procedures:
    First had your printer working connected directly to your laptop and go to the web based menu to change the IP settings of the ZPS2000 and then reconnect to your DSL-router.
    Hope this works.
  • Ibrahim OKTAY
    For your info: If you do not do in the order as in my previous comment, the IP settings and the subnet of the router may be different than the ones from the ZPS2000.
How to set up wireless printer on windows 7 net book
I have just bought an epson sx435 wireless printer. I have set it up on my xp desktop with usb cable. How do I set it up to be wireless on xp
and how to I set it up on my Acer Aspire one 522 netbook running windows 7.
Home > Printer Wi-Fi Setup Setting up a Printer Wi-Fi Network Using the Control Panel Using the Wi-Fi Setup Wizard with LCD panel WPS setup You can set up a Wi-Fi network for your printer by using the printer's control panel. Using the Wi-Fi Setup Wizard with LCD panel If your printer has an LCD panel, you can use the Wi-Fi Setup Wizard to simplify manual setup. mark_no.gifNote: This setting is not available for all printers or may not be enabled. Make sure that the Wi-Fi is enabled on your computer in advance. Check the SSID and password for your network as these are required during Wi-Fi setup. If you do not know the SSID and password, check with your network administrator. For step by step information on setting up a Wi-Fi connection using the Wi-Fi Setup Wizard, click the following link. This feature is not available for all printers or may not be enabled.
exlink.gif../p_body/panel/wizard/manual_01.htm
Well to start with xp look at the following.
http://support.epson-europe.com/onlineguides/en/sx430sx435w_nwg/html/index.htm
May 30, 2012 | Computers & Internet
For key span server to work with windows 7 install windows xp mode to windows 7 ( this can be downloaded from microsoft website if you have windows 7 pro and above. if you have windows 7 home then install...
1. instal server utility on Windows 7
2. right click icon choose properties
3. select compatibility tab choose your o/s
now run it and presto......
regards, dean
Jan 08, 2011 | Keyspan USB Server US-4A (d47710) Print...
Iogear print server not compatible with windows 7
Not compatible or not working well with windows 7?
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
Oct 22, 2010 | IOGear GPSU21 Print Server
I have window 7 64bit and the keyspan software installed fine but the server utility does not recognize the print server. I allowed port 3842 tcp and udp through the windows firewall but still no luck.
for key span server to work with windows 7 install windows xp mode to windows 7 ( this can be downloaded from microsoft website if you have windows 7 pro and above. if you have windows 7 home then install windows virtual pc, start it up and insert a windows xp pro install disk. for info on this google 'workaround to install windows xp mode in windows 7 home premium and home basic') Once you have windows xp mode running, install the keyspan server utility int he virtual machine and setup as usuall. then share the printer. go to windows 7 devices and printers and add a printer, chose a network printer, select the new virtual machine and select the shared printer. In order for the printer to work just start up the keyspan program from windows 7 and print....your welcome.
Sep 08, 2010 | Keyspan USB Server US-4A (d47710) Print...
Wifi server
Once you have setup the central sever you can right click either the harddrive(s) or individual folders and there should be an option to share (or sharing and security). Open that and it should be quite straightforward to setup permissions so all computers can access those network places.
Next on the server right click My Computer and click properties. Write down what the workgroup name is.
Now go to the Vista laptops and goto Control Panel, then network places, or view wireless devices on network. Hopefully your shares will appear on the laptops and you can access them.
If they appear and you canot access them then you probably need to go back to step one and alter the permissions for sharing on the XP server.
Hope this helps, www.PuterCare.com
Apr 09, 2010 | Acer Aspire 5050 Notebook
Failed response from plugin device
Dirty fix...
When the printer errors out...stop, unplug the power to the printserver. Reset the printer, Clear the print que (delete jobs/restart print spooling service), restart the printserver software and plug the printserver power back in. Wait for the re-detect. Everthing should be good at this point. Unfortunatly the print job will be lost and you need to print again...BUT, NO REBOOT yea!!!
Note... for me, if this sequence is not followed, I will have to reboot. The printserver will be locked for the PC that was trying to print. All other PC's will be fine, and I have no idea why.
Good luck,
Bill
Jun 24, 2009 | Zonet MULTI FUNCTN USB 2.0 PRNT SRVR...
Windows Vista home + Windows XP Professional Networking issue
Make sure domain settings to your server are correct on the notebook computer. These settings are located in the control panel of the system setting.
Whats the operating system of your server?
Make sure the firewall in windows security is turned off too. Sometimes that thing sneaks up on you.
I haven't used the home edition of Vista but another reason why it might not be working is because it isn't the business version. Microsoft might have added extra security to prevent the home version from connecting to a server. I know we use the business version of Vista at work and it is working that way on the intranet server without a problem.
I would check with Microsofts website on that.
Jun 21, 2008 | Microsoft Windows XP Professional for PC
Zonet MULTI FUNCTN USB 2.0 PRNT SRVR (ZPS2000) Print Server Logo
132 people viewed this question
Top Zonet Computers & Internet Experts
Prashant M
Prashant M
KG John Justin
KG John Justin
Are you a Zonet Computer and Internet Expert? Answer questions, earn points and help others
