Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Maytag stack washer/dryer washer stopped
Waher became unbalanced and shut off, as it has done before. I rebalance and tried to start it again....and nothing!! Dryer is fine, but the washer is dead.
  • 2 more comments
  • pfg2 May 09, 2010
    the model # is LSE7806ACE
  • pfg2 May 09, 2010
    my Maytag LSE7806ACE stacked washer dryer stopped after an unbalanced spin situation. I rebalanced the load and tried to restart...nada!! Nothing: fill, spin, agitate on any setting.
    The dryer is fine.
    BTW how do you remove the front panel after removing the two screws at the bottom.
  • pfg2 May 09, 2010
    nope didn't work. Fuse is okay btw
  • pfg2 May 10, 2010
    I got the front off. Everything looks good. The brackets and springs are all free and intact. The fuse on the front left is good. I shook the machine left/right, back/foward and shoved the tub araound and centered it back up, shut the breaker off for 1/2 an hour. Turned it back on and.....nothing!!!
  • 4,059 Answers
Take the front off and look at the tub support brackets making sure none of them are broken loose and make sure the outer tub is in the proper position.
Posted on May 10, 2010
    President:
  • 2,468 Answers
Shake the unit side to side and back and forth,the balance ring switch could be stuck inside the unit or you may need to unplug it to reset the ecu control board
Posted on May 09, 2010
    President:
  • 1,554 Answers
Maytag Top Load Washers are equipped with Unbalance Control System that monitors the washer for vibration and unbalanced condition. It consists of outer tub displacement switch, inertial switch, strut displacement switch, and a cabinet vibration sensor mounted on the control board. One of the switches may have been dislodge causing the washer not to start again. Please indicate the exact model number of the machine for specific and accurate troubleshooting and repair advice.
  • Jahn27
    Jahn27 May 09, 2010
    Your washer has no unbalance control system like the one described in the previous post. But it has a fuse in the lid switch assembly that might have been blown due to high inrush of current during the unbalanced condition. The lid switch assembly contains the lid switch, lid check switch, and the fuse. Check the condition of the fuse including the lid switch and the check switch when activated. Here's the wiring diagram for your reference.
The washing machine will start turn a few times add some water but then stops and the light flashes
Sounds like unbalanced now - try to rebalance the adjustable knobs under the washer - we have to rebalance every few months because our floor isn't the straightest. We always know when its time because the washer won't work right.
Mar 23, 2014 | Amana NFW7300WW Washer
I have a maytag washer i bought in 97. It became unbalanced well my husband fixed it and everytime it goes on the spin cycle it gets unbalanced again and makes a very loud noise
If the washer is truly balances (check with a level to be sure) you might just have an unbalanced load. When filling your machine with laundry, think of the tank as a big circle divided into four pie slices. Make sure you fill each of the four slices evenly. This should help,
Nov 04, 2010 | Maytag Washing Machines
Unbalanced load stopped machine will not restart why?
On some of the maytag washers when an unbalanced load stops the maching it blows an internal fuse located behind the front panel on some stacking washer and dryer machines and under the counsel on some of the top load machines. ON the top load machines it is recomended that you change the lid switch with the fuse that comes with it.
There are two screws located on each side of the counsel. Remove the two screws and tilt the counsel up and locate the lid switch, fuse assembly. You can check the fuse at this point.
Dec 28, 2009 | Maytag Washing Machines
Washer won't agitate, drain or spin
quite possible that the fuse has gone bad again, if that s the case i would recommend replacing the fuse, and the lid switch.
Dec 08, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag neptune stackable washer dryer stopping
Maybe a water fill problem ,washer will stop if no or not enough water enters the tub in a given time
Dec 04, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
MLE2000 front load washer
Hi..I had the same problem yesterday...the maching would start when I pushed the button and then stop..I had to push the button again to get it going..My stacked set is around 8 years old.
Here's what we did..moved the washer away from the water source and unscrewed the water intake lines..there is a little screen there...took the screen out of both hot and cold lines..one screen has some debris in it..the other was almost completely blocked..we are on a well and sometimes dirt..etc..gets in the lines..
Today no problems doing the laundry..its working like new..
Oct 26, 2008 | Maytag MLE2000 Front Load Stacked Washer /...
Washer stopped
There are two switchs and a fuse hooked to the lid switch. If the fuse went out on of the switchs is bad. You can get the whole switch assembly with the fuse if that is the problem.
Apr 24, 2008 | Maytag LSE7806A Top Load Stacked...
Washer stopped working??
change the pressure switch its the switch that you select the water level with
Mar 18, 2008 | Maytag LSE7806A Top Load Stacked...
Dryer stops running
Sounds like a thermal breakdown in the motor.
Jan 11, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
193 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
