My kenmore elite calypso has a code of ce - Washing Machines
  • 8,197 Answers
CE Communications ErrorIf there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
Some common causes of CE errors include:
· Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a CE error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
Posted on May 09, 2010
  • Jyackle5
    Jyackle5 May 18, 2010
    I see how you are you get an answer then you reject it. I gave the right answer to fix but you down rate me
    THANK YOU SO MUCH!!!!!!!!!!!!!!!!!!!!!!!
jsrock516
  • 5911 Answers
SOURCE: Calypso kenmore elite - problems trying to wash a load
This is usually a symptom of a bad motor control board which located under the console. I had the same problem. You can open the console by removing the three screws in the back and lifting from the rear first. The console will pop off. In addition, if you look along washer top front edge in the seam there is a retaining clip about 2 inches in from each side. Using a putty knife, push in on each clip while lifting and the top should pop up. There will be a tech sheet affixed to the front wall of the washer between the wash tub and case. This tech sheet will give you all the guidance necessary on how to perform tests to prove whether or not the motor controller is at fault, or if the pump is at fault. I believe you may have a motor controller problem, though. Another possibility is getting something caught in the drain pump reservoir. This could binding the pump. Let me know if any of this is helpful to you.
Posted on Aug 16, 2007
SearsTechToo
  • 261 Answers
SOURCE: kenmore elite calypso 24082 error code CE
On the ccu, the board on the right is usually the culprit, I have recently replaced one with that same error but I would first unplug it and remove and re connect each plug on the board looking for dark connections or dialysis, corrosion. If not fully insert each plug and try again.
Posted on Sep 07, 2008
  • 113 Answers
SOURCE: Kenmore Elite Calypso wont drain
Oh the dreaded calypso pump...Seen that one a million times. Pumps get clogged pretty easily. Try to get the water out manually first. Than push the washer back and lean it against the wall so that you can access the bottom. Remove the 3 screws. Bottom panel should come off. The pump is on the right, its black. Get ready with a shop vac or alot of towels, theres gonna be a flood. There are 2 clamps on black hoses that need to be taken off so that you can slide the hoses off the pump. Next remove the 3 bolts that hold the pump in place. Next lower the pump out of the hole it sits in. Youll have to follow the wiring harness up and disconnect it. Now you can try and clen out the pump or replace it. Part # is 285990. Costs about 75.00. Hope that helps. Let me know if yiu need more help. Dave www.washermd.com
Posted on Dec 16, 2008
dbpickell
  • 30 Answers
SOURCE: kenmore elite calypso washer CE
Here is a link for the error codes on calypso, in most cases it is a blown fuse on the motor control board so I would first check that. Hope this is helpful and please remember to rate this solution.
Posted on Mar 10, 2009
  • 49 Answers
SOURCE: my kenmore elite calypso keeps beeping Fl what
FL (flood condition) also can be an indicator of a bad pump. The washer tries to drain and cannot because the pump has failed or is jammed with debris.
You can run a complete washer diagnostic procedure to see if you can isolate the fault by doing the following. I recommend you make sure the room is quiet so you can hear the pump motor running when expected, as well as the main drive that nutates and spins.
Perform a "key dance" to put the washer in the diagnostic mode by pressing the Prewash Options button, Wash Time, Prewash Options, Wash Time - each 2 times in rapid succession within 5 seconds total. The display will change to 99 and begin counting down (in seconds) as it runs the following tests. Listen for the pump motor to actually run and not just "hum", indicating a jam or burnout.
Display 99-81, Nutate & fill
Display 80-61, Nutate & recirculate
Display 60-41, Nutate, Fill & drain **
Display 40-21, Nutate, Fill & drain **
Display 20-0, Spin & drain **
You can cancel the test in progress at any time by pressing the Stop/Cancel button.
**during these phases the pump will run forwards and backwards (recirculate & drain). If you do not hear water pumping inside the washer or draining out the drain, your pump is likely bad and needs to be replaced.
The old style pump was a two-part assembly and the re-engineered part # mentioned above is a single piece that solves the impeller failure problem the original pumps were prone to have.
www.pcappliancerepair.com sells replacement pump part # 285990 for this washer and they are a reliable supplier with a good value. You can purchase a lifetime warranty on the pump from them for an extra fee.
Unfortunately there is not enough room in this text box to post the pump removal & replacement procedure but you can get your local handyman to do the work for you if you are not inclined, as I was, to drain the washer and turn it on its side to figure out how to replace the pump.
The other problem is that once you start getting a pump failure you need to look at the root cause. If the pump was ruined by draw strings or debris being sucked into the pump impeller, it is time to replace the top wash plate assembly (the plastic plate inside the washer that the clothes sit on).
There is a rubber seal on the outside edge of this plate which wears out over time and rotates upward, opening a bigger gap between the plate and the stainless steel drum which lets draw strings and other things get sucked all the way down into the pump. The upper wash plate & seal is a single unit and the seal itself cannot be replaced as it is molded into the plastic piece. Order this from Sears to insure a more recent 'cure date' on the rubber seal from the manufacturer, rather than 3rd party suppliers who might stock the part for longer periods and have old rubber seals past their cure date. The wash plate should be replaced about every other year.
Posted on Oct 03, 2009
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Jan 27, 2016 | Washing Machines
My Kenmore Elite Calypso wont stop washing
What is the model number of your unit?
Nov 22, 2012 | Washing Machines
Kenmore Elite Calypso top loader and error code ce
Com error between control and motor. See page 51. Check for corrosion on the pins at the quick connect. Check for broken wires
Sep 16, 2011 | Kenmore Elite HE4 Electric Dryer
Getting the CE message
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 12, 2009 | Kenmore Washing Machines
Washer won't start. shows CE on the display
That is a communication error between the control and the motor board.
Could be a corrosive buildup on the ribbon connectors and/or a bad wire or loose wire.
You can unplug the machine and trace all wires to look for a pinched or loose wire.
Unplug and clean all wire connections.
If that does not work it will be a bad motor controller.
Mar 04, 2009 | Kenmore 24032\24036 Top Load Washer
Calypso kenmore elite water level low sometimes
something is clogging recirculating pump inspected both pump that should fix
Nov 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite calypso 24082 error code CE
Sep 06, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
116 people viewed this question
Top Washing Machines Experts
