Question about Seiko Mantel Clock
My clock has Strausbourg Manor on face and below Westminster Chime Quartz. It chimes on the quarter hour and chimes 3 min late. I have no instructions. It is a wall clock and is battery operated.
4 Suggested Answers
escapement
  • 2334 Answers
SOURCE: Strausbourg Manor Wall Clock chime adjustment
It is normal for the average wall clock. Of course, this can be adjusted, but without watch/clockmaking knowledge it is impossible, because first you need to find out which part of the movement is causing early chiming - and there are plenty of them.
Super fine adjustment can be found only in top of the range clocks. Hundreds of hours of craftsmenship are spent to adjust and fine tune them. That's why they cost a fortune.
If you can not live with that early chiming, you have to bring your clock down to the watch/clock repair shop and ask for help. Be ready to pay quite a money, as this job takes the skill and a lot of time.
Rate me, please.
Posted on Jul 29, 2009
  • 5 Answers
SOURCE: I have a Strausbourg chime mantel clock. It chime
each press of the red button will advance the chime count by one. Advance the chime count to match the face clock
Posted on Jun 05, 2010
SOURCE: Elgin Westminster Quartz Chime clock won't work
IF I GATHER CORRECTLY , YOUR CLOCK HAS TWO BATTERIES, ONE AT BASE AND ANOTHER ON THE BACK OF THE UNIT. THE ONE ON THE BACK OF THE UNIT IS RESPONSIBLE FOR CLOCK'S FUNCTIONALITY AND I THINK THE BATTERY AT BASE IS FOR THE ROTATING BALLS ( PENDULUM ). SO OPEN UP THE BACK IF YOU HAVE NOT DONE SO, AND REPLACE THE BATTERY. CAREFULLY THOUH AS THERE RE TWO SCREWS ON TOP AND A SNAP AT CENTER BOTTOM WHICH YOU COULD EASILY BREAK IF YOU DO NOT DO IT WITH CARE. OPEN UP THE SCREWS FIRST AND GENTLY USING A SCREW DRIVER PUSH BACK ON THE SNAP HOLE TO FORCE IT UPWARDS AND INWARDS. IF NONE OF THIS MAKES SENSE THEN WE ARE LOOKING AT TWO DIFFERENT CLOCKS.
HOPE THIS HELPS.
Posted on Oct 11, 2010
How to set a classic manor quartz west minister wall clock to chime at the correct time.
Hello Fern Hicks,
Short of ORDERING IN A NEW movement I
would rather try removing the hands... and placing them where they are chime appropriate...
I'm sure there are more convoluted ways of accomplishing the same thing... but I so old & clock oriented... I only turn clocks & timers in the FORWARD direction (very OLD school).
Remove the minutes hand (from where-ever it strikes)...
Move the hour hand (only if necessary & replace the minute hand as appropriate to the movement strike.
Classic Manor Quartz Westminster Chime Pendulum Clock0 results You may...
Carnac the Magnificent
Mar 26, 2017 | Chime Home
How do I fix the westminster chimes on my grandfather clock
Grandfather Clocks Manual - theclockdepot
www.theclockdepot.com/grandfather_clocks_manual.html
Howard Miller Grandfather Clock Manual by The Clock Depot offering discountGrandfather Clocks. ... The movement controls the hour strike, time keeping, andchime. ..... the hour without the Westminster melody if the other Westminster melody lever is turned to Silent. .... My Grandfather Clock has Stopped, Can I Fix It?
Owner's Manual - Master Clock Repair
www.masterclockrepair.com/ownersmanual.html
Note: The following information will apply to almost all grandfather clocks made after ...(See my article on Clock Myths) It is best if the chains are not pulled so far that the top of .... Some play the Westminster chime only and cannot be changed.
Nov 23, 2015 | RIDGEWAY GRANDFATHER CLOCKS Ridgeway...
I inherited a Seiko Westminster chime clock. The time is perfect but the hourly chimes are 3 hours behind. How can I synchronize the two?
The next time it gongs multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it strikes once. Now put the minute hand back on pointing to 6 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
Sep 21, 2015 | Seiko Mantel Clock
My sterling and Noble westminster chime clock is not chiming. I have brand new batteries installed but still no chime
A handsome clock in solid red oak. The face is off white with a convex lens and a bright brass-toned bezel. The Westminster chime is pleasant sounding while counting the hours.
Runs on 4 AA batteries; two to manage the clock and two for the chime. The external speaker is located at the top of the clock for a clear, unimpeded sound. A button on the chiming unit allows you to control the striking of the hours.
You will see above that one set of batteries does the chime. Make sure they are good and inserted with correct polarity.
As mentioned, look for a button switch to turn the chimes off It is a feature so you can turn the chimes off when you go to bed.
Sep 14, 2015 | Home
MINUTE HAND NOR THE HOUR HAND NOT ADVANCING AS THEY SHOULD. CLOCK STUCK AT 8:45 FOR DAYS, PENDULUM MOVEMENT OK. WHAT IS THE SOLUTION TO GETTING THESE BACK TO WORK? THIS IS ON A STRAUSBOURG MANOR...
without seeing the clock .....are you sure it isn't something as simple as the hands ( arms) detaching from the centre spindle which continues to turn but without the hands. Alternatively have the hands become stuck on something on the clock face or become intertwined themselves ? Very simplistic but all I have to offer...
Feb 24, 2015 | Watches
How do I stop the continuous hour chimes on a WESTMINSTER chime mantel clock ?
Is this a older type mantel clock or an electric. A older one has a small arm on the back of the wooden case just move it to it's opposite position and that should stop all chimes. A few times that small switch is on the inside but very rear. If it's electric it also should have a switch to turn off all chimes.
Feb 06, 2015 | Home
How do i synchronize chimes with clock on westminister whittington clock .
The Westminster/ Whittington clock means that it has 2 or 3 settings.
1. Silent
2. Westminster Based on the music My redeemer liveth by Handel
3. Whittington
Set the clock onto the westminster setting, this is the easiest. At quarter past the hour it should sound 4 notes. The half past should be 8 notes. Quarter to the hour should be 12 notes and the hour should be 16 notes then the striking of the hour. For example on 8 'O clock you should hear 16 notes then the clock should chime 8 times. Sometimes if the hour is out just gently stop the pendulum, check what hour the clock is striking then without taking the hands off move only the hour hand to the hour. Do not do this with the minute hand.
I hope this helps you! If you are not sure please email me yvonne.finch@gmail.com I fix these clocks.
Apr 30, 2010 | Seiko Mantel Clock
I have a Strausbourg chime mantel clock. It chime 2 minutes late every 1/4 hour, how do i fix this. Rae
I lost directions to my clock, it takes two double a batteries for the chime but i dont know how to set it.
thanks
Dec 06, 2009 | Seiko Mantel Clock
Rate me, please.
Jul 29, 2009 | Seiko Mantel Clock
Syncronize chime strokes to clock
The next time it chimes multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it chimes signaling 15 minutes after. Now put the minute hand back on pointing to 3 o'clock and replace your dial nut and you are all set.
May 26, 2009 | Seiko Mantel Clock
Home Logo
1,019 people viewed this question
Top Seiko Home Experts
k24674
Jimmy Accardi
Are you a Seiko Home Expert? Answer questions, earn points and help others
