Question about Brother IntelliFAX 1270E Plain Paper Fax
Brother 1270 solid black 3 inch line on right side of sent faxes
  • Anonymous May 27, 2008
    When I send fax they are all black, or have a one inch line down the middle. Until today I could copy with no problems. Today when I copied I have all black but a square on lower left. When I print out the help list, iit is fine.
  • Tony Walker May 11, 2010
    Does the same thing happen when you make a copy? Does it happen when you receive also?
    President:
  • 2,072 Answers
One of 2 things going on here.
If it is in the same spot all the time on sent faxes.
There could be some contaminant on the scanner glass, Some toner, white out or a piece of paper blocking it.
With as wide as it is, that is not likely.
I would think with it being that wide, once section of that scanner CCD assembly has failed. That would need replaced and probably pretty costly.
As was asked above. Does this problem occur in copy mode and does it repeat when you print out a report.
Posted on Mar 28, 2008
How to cancel a fax in progress on a brother intellifax 1270
If it's from your side just turn the device off, if it's from the other side (if you sent a fax over to someone) then it's in their memory and you can't do anything about it. For further help consult the manual here: Brother Intellifax 1270e manual
Jul 29, 2014 | Brother IntelliFAX 1270E Plain Paper Fax
I keep getting a black line about 2 inches along the right side of the paper if copying as well any faxes sent are also getting that blac line. Brother fax machine intel 4750e
Well you said the Lines are present when you are copying and when you are sending from the fax unit. Copying and sending functions both uses the scanning unit. What you lift open the document feeder for original documents. In there you should see rollers and a glass. clean this glass with cotton swab and alcohol for left to right the entire glass. Close the unit and try copying or sending, documents should now be clean.
Apr 04, 2011 | Office Equipment & Supplies
I have a Brother IntelliFax 1270 (how is that for a dinosaur) and am getting a black line on the right hand side, when I cooy or send. Have cleaned around. I dont see any anwers but questions on this...
Check the docement scanner.there is a glass plate under it and see if something is stuck on it /look real hard its hard to see sometimes.Use a paper towel damp with water only.
Aug 13, 2010 | Brother IntelliFAX 2800 Laser Fax
Solid black lines on the right side of page
Try sliding the blue tab on the drum unit side-to-side. If that does not cure it, you need a new DRUM UNIT
Oct 02, 2009 | Brother IntelliFAX 4100 Laser Fax
I am getting a black 1.5 inch band down the right side of my fax transmissions. Help please...
If the band is on received faxes, the problem is a dirty drum or corona wire; if the band is on sent or transmitted faxes, the problem lies in a dirty scanner.
Sep 01, 2009 | Brother IntelliFAX 5750e Laser Fax
95% of copy or sent fax black
You need a new cis unit, that is the scan assembly. Some of the pixels are burned out. Exposure settings won't help at all...
Jul 24, 2009 | Brother IntelliFAX 4100 Laser Fax
A bar code stripe on the right side of the copy.
i'm not sure if you're talking about a solid black band or a bunch of little stripes running down page. does it happen when you run an internal report or only on copies? if its a black solid band, check and make sure the bluish colored tab on top of the drum is all the way to the left side. if its a group of fine lines, depending on whether it happens on internal reports or not, it could be the drum is going bad or you may have a bad scanner. write back with a little more info if this suggestion doesn't work.
good luck,
razors
Mar 18, 2009 | Brother IntelliFAX 5750e Laser Fax
2 inch vertical solid band on right side when making a copy
There is probably dirt or ink on the scanner glass, this would affect both copying and sending faxes.
Here is a link to the manual and a description on page 74 showing how to clean the glass.
http://www.brother.ca/en/products/pdf/manuals/FAX1270-UG.pdf
Jan 21, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Brother IntelliFAX 1270E Plain Paper Fax Logo
118 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
