Question about Vehicle Parts & Accessories
How do I reset my park-zone for the garage - Vehicle Parts & Accessories
1. What is the best time to visit Corbett Park?
Corbett National Park remains open throughout the year for the visitors from Jhirna zone but the best time to visit Corbett is from mid of November to mid of June because during this time all the tourism zones are open for visitors and one can visit the entire national park area.
http://www.corbett-national-park.com/best-time-to-visit.html
Jun 04, 2013 | Cars & Trucks
Why I cant get reception in my parking garage?
GPS reception may be inconsistent in certain locations or under certain conditions. In most parking garages and underground parking lots you won't be able to get a GPS reception because the signal is blocked by the concrete.
Feb 06, 2013 | Home Security
I popped a brake line on my 1995 Nissan Pathfinder, unfortunately it's in a VERY expensive parking garage with ceilings so low it can't be towed out. Will the parking brake still work so I ca
Yes parking brake will still work. It is mechanical with a wire going from pedal/handle that when pulled squeezes the brake shoes round the rotor. Just go real slow and you should be alright. Hope this helped you.
Oct 17, 2012 | 1995 Nissan Pathfinder
How do you reset the compass??
  1. Stop the vehicle and place it in "Park."
  2. Press and hold the "Set" button on the compass for about two seconds. The button is located directly below the compass to the right.
  3. Press the "E/M" button repeatedly until the correct zone is displayed. If you do not know your zone, you might have to contact your dealer for this information.
  4. Press and hold the "Set" button for about two seconds until the display flashes, indicating that the compass is reset.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
Oct 22, 2010 | Toyota Land Cruiser Cars & Trucks
Service engine light
yes two ways,,,u can go to auto zone or advance auto,,havr them scan it for free,,ask them to clear it,,,or disconnect the battery for 5 minuets,, u will have to reset ur radio,,,,if light comes back on problem is still there,,,, hope it helped,,
May 28, 2010 | 1997 Chevrolet S-10 Pickup
Gear shift stuck in Park 2006 Chevy Impala
i dident read all but the car won't go in to gear if the car dos'ent sence you pressing the brake its a safety thing check brake fuse thats seems like what is happing if you nned to the switch for the brake is right above the brake pedel it should have to wires to it but it could be a fuse
Aug 11, 2009 | 1998 Land Rover Discovery
2003 HD Ultra Glide - Electrical Problem. Can't get it to start
thats basicly average lifespan for a battery-in the south anyway-bring it to a tester like auto zone to confirm itz old-12 volts is needed at all times because the ignition does not feed off alternator once started
Aug 06, 2009 | 2003 Harley Davidson FLHTCUI Electra Glide...
I have a 1993 park ave and need to now how to reset the transmiss
if you got climate control air conditioner control buttons turn on ignition key enter the self diagnostic system. select pcm override ps13 tps sensor learn.press the warmer button. the driver information center should display 09.indicating that the garage shift value has been reset.select pcm override ps14 tran adapt.press the cooler button the dic should display90 indicating the up shift adapt value been reset.press warmer button the dic should display 09 indicating the steady state adapt value has been reset. press and hold the off and rear defog buttons on dic until the message .transaxle oil life reset is displayed on the dic.
Apr 11, 2009 | 1993 Buick Park Avenue
Vehicle Parts & Accessories Logo
235 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
