Question about Samsung 931BF 17" LCD Monitor
Unplugged monitor. left home for a couple of days. Plugged monitor in and got no picture. Turned CPU on and off and the CPU does recognize it, but still no picture. the monitor power button just flashes.
  • daddiboi4 May 10, 2010
    I used my DELL monitor in place of the SAMSUG 931 and the DELL worked just fine. I am concerned about the flashing SAMSUNG power botton. The SAMSUNG gets power and I can hear the CPU recognizing the SAMSUNG monitor (you can hear the "da-dunk" recognition sound on the speakers), but no picture.
  • 11,361 Answers
Try it on another PC, if it still does not work and you want to DIY repair, please read below and look at pictures.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 09, 2010
  • Bud Martin
    Bud Martin May 10, 2010
    Well, you will need to open up the monitor, the 5vdc for the logic is working but the 12~18vdc for the inverter circutis may not be working, or the inverter circuits, lamps assemblies amy have failed.
I have a ViewSonic VX2235. No picture at all
sounds like a burnt or a cold solder around the TRANSFORMER section of the power supply , I suggets if your handy w/ tools to open the monitor and inspect the PC BOARD for any burnt or cold solder THAT not making the connection , hope it helps AJ
Nov 09, 2009 | ViewSonic VX2235WM Monitor
Dell LCD TV won't turn on
check the cable who comes from the cpu
May 07, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Monitor problems all of a sudden
Replace your monitor power cord.
Apr 27, 2009 | Computers & Internet
My computer is not showing when my camera is plugged in
Make sure the camera is turned on, plug the USB cable into your PC first, then into the camera, wait for a beep from your PC to show it has recognized the hookup, then go to "My Computer" and look for the Fuji icon. Don't unplug the camera anytime the lights are flashing on it.
Mar 21, 2009 | Fuji FinePix S1000FD Digital Camera
No sound from monitor speakers. Worked fine for 5 years. Can hear sounds when using headphones plugged into CPU. Hope you can help even if only to tell me I need a new monitor. Sincerely Dizzyme.
Hi...there,
First of all, check if your audio cable are still plugged into the monitor and pc output (light green) audio jack. If not just plugged it back in... Still still got no sound... Then turned off the monitor and pc. Unplugged all the cables from the monitor and pc, wait for 10 second till all the surged built up are cleared out. Then you can plugged all the cables back Monitor should have 3 cables, a audio cable, a VGA or DVI cables, and a power cord... OK! now you got all the cables plugged back in...
Turned on the monitor and PC....and a few seconds....you should hear window started. Still... had a problems....just get a external speakers. Have nice day!
Oct 08, 2008 | Hansol H550 15" LCD Monitor
Green light just blinks
Four bad 1000mf/25v caps in DM module = Common repair
for qualified Mits tech..................................T.
Nov 11, 2007 | Mitsubishi WS-48513 48" Rear Projection...
DCLCD 19" flatscreen won't turn on correctly
Same problem here, but after using the plugging/unplugging method it eventually stopped all together. So, I took it to a local monitor repair shop (AM Stereo, Seattle). The problem is a power supply issue where the capasitors go bad. They fixed the monitor by replacing the capacitors for $70. In there experience, all monitors, regardless of brand, tend to use the same cheap capacitors which fail. He replaced them with better quality capacitors which may make this monitor better than it ever was. I'm back in business with a great monitor!
Oct 31, 2007 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
Samsung 931BF 17" LCD Monitor Logo
74 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
