Question about InFocus Proxima DP6155 Multimedia Projector
I purchased one off of ebay and it just came without the bulb or casing or cover for the bulb area. It also had no power cord. I can still order these reasonably from someplace?
  • 74 Answers
If your looking for a bulb at a cheap price, look on ebay. If you need an OEM bulb look into projectordoctor.com
Posted on May 11, 2010
5 beeps
Hi this sounds like a memory/ram issue you need to power of your machine, remove the power cable & then without the power cable connected, press & hold the power button for 15 seconds until it makes a chime noise, that is a basic power function reset, if that does not solve it, remove the memory cover panel on the under side of your laptop then carefully remove the memory chips blow or vacuum the area & use a dry piece of tissue to very gently clean your memory of any dust, replace the ram chips & re-connect power cord, this should solve it, but if not try starting up again without the power cord, if it's successful without the power cord you'll need a new 1, if not it suggests your ram chips have gone bad & you may need to purchase new ram chips, good luck :-) you can find more info about the 5 beeps here: Computer Does Not Start and Emits an LED or Beep Code
if you need to purchase new memory/ram chips you can get cheap ram here: Cheap Laptop Memory RAM Upgrade Low Prices UK Deals Ebuyer com
If you do need to buy new ram chips, I'd advise buying 2x 4GB modules :-)
Apr 15, 2014 | HEWLETT-PACKARD Elitebook 8460P
Cahinsaw has no power. Stepped on the cord. Probably pulled it loose. Loose pwer cord. How to open the case and remove the old power cord. power cord
Most times a break in the wiring is not visible and can occur inside only one wire in the mains power cord several centimeters from the power appliance. The first thing to ascertain is whether there is continuity between the plug pins to the junction. You will need to use a polarity tester. If you don't have a multi-meter you can use a small battery and torch bulb and run them in parallel. Test both the positive and negative wires. If one wire fails to provide continuity then rewiring will solve your problem.
Mar 27, 2014 | Worx Garden
I lost my cord for my boom box model number RCD150. Where can I purchase another?
You can order for it online at ebay.com or just walk into electronic workshop within your area to get it.
Apr 06, 2011 | RCA AM/FM Stereo Cassette Recorder...
Lost my power cord. where can I purchase a power cord for a Pixma iP90 printer.
Go to web site of canon and order OR from the website you can find the canon dealer in your area OR go to any electronics shop in your area ans you can get it there
Jan 17, 2010 | Canon PIXMA iP90 InkJet Printer
Vaio llcd lap top bulb
Well, Alot of repair shops won't replace the bulb itself for lack of knowledge on how...
To CHange the LCD Bulb, You Can Order One On Ebay..
Just Go To Ebay and Type In .....
15.4" WXGA LAPTOP LCD SCREEN CCFL BACKLIGHT BULB 334mm
To Replace The Bulb...
You Need To Pull The Front Bezel Cover Off (first Unscrew it)
hen Unscrew the Side Connections holding the Display to the Back Cover....
Then UnPlug The Power Inverter Plug and Display Plug From The Little Power Inverter Circuit Board..
Be Careful Not To Bend The Power Inverter
Then You Unscrew And Remove The Metal LCD Bulb Cover from the bottom back of the Display, and You Will Need To Use A Razor and Cut The Tape Carefully Along The Whole Bottom Seam and Halfway Up The Sides.....
Unscrew The 1 or 2 screws on the sides of the display to be able to pry the frame apart and pull out the LCD Bulb.....
The LCD Bulb Will Come Right Out Along With Its Protective Metal Casing and Power Cable (pink and White).....
Just Do The Reverse To Replace.....
Nov 17, 2008 | Sony VAIO PCG-K35 Notebook
Replacement parts
You can go into a full service fabric.repair service shop and they can order one for you. Ebay is also another great place to start. Its good to know what the plug looks like. Ebay currentlt has this power cord and presser foot for $34.99. Be carefull when ordering off Ebay look at the photos, many sellers are selling the presser foot without power cord and a live wire on the end where the cord should be, or the cord with a live wire where the presser should be, Make sure your getting the whole unit.
Jun 14, 2008 | White Sewing 1632 Mechanical Sewing...
Hood lights
first remove mains cord from main power. and remove the microwave oven top cover and check the bulb and crefully remove the old bulb and put new bulb. at high voltagae section dont touch any thing ,that area very dangerous ,thats why very carefully work inside the microwave oven ..
Sep 09, 2007 | Goldstar MV-1320W/B Microwave Oven
InFocus Proxima DP6155 Multimedia Projector Logo
56 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
