Question about Sharp AF-S120MX Air Conditioner
Sharp Air Conditioner - AF-S120MX window unit . Brand new keeps resetting every 3-5 minutes .
KOakaKO
  • 135 Answers
SOURCE: Air condition problem
An E1 error is automatically generated after the AC runs for so many hours to remind you to clean the filter. The manual says to clean filter and unplug unit, then plug unit back in and code will be reset.
Posted on Aug 02, 2007
Ok...so I posted "this solution doesn't work" about 30 minutes ago. I found this answer online. This one worked!! Very poor writing in the instuction manual I guess! Their solution was not even close! "Sharp window A/C - Every thirty days the AFX 12,000 BTU unit is set to turn off automatically and display an E! error to remind you to clean the air filter. To restart, unplug the unit. Hold down the power button and plug in. Wait for the beep and then unplug. Plug in again and the unit should restart. If there is is no beep there may be a mechanical problem."
Posted on Aug 03, 2007
  • 95 Answers
SOURCE: Thru-the-wall air conditioner won't turn on
Check for power at the plug in, if it's got power take it back under warranty.
Posted on Jun 10, 2008
  • 23 Answers
SOURCE: reset air conditioner
Unplug it. Wait a few minutes. Hold in the Power button while plugging it back in and keep the button held down until a beep is heard (~5 sec). Unplug the air conditioner, then plug it in again.
Note: some units require using the Mode switch, rather than Power.
Posted on Jun 15, 2008
  • 143 Answers
SOURCE: AIR CONDITIONER MODEL #AF-S85FX--CODE E1
The Sharp e1 problem is a timer that is pretending to demand that you clean the filter. It stops the machine every 720 hours and forces you to do a procedure to get it to go away.
There are 2 possible procedures.
1) Unplug the machine. Hold down the power button while you plug the machine in and wait for a beep about 5 seconds long. Let go of the power button. Unplug the machine. Plug it back in.
2) Unplug the machine. Hold down the mode button while plugging the machine back in and waiting for a beep of about 3 seconds duration. Let go of the mode button. The machine will start. Turn the machine off by pressing the power button. Resume trying to use the machine normally.
If these don't work, the "demand to clean filter" timer is broken and you will need to buy parts to repair the machine.
(Don't you just love having a computer chip in every appliance?)
Posted on Jul 25, 2008
Reset air condition
Turn the Master ON/OFF Switch to OFF and unplug the unit. Wait 15 minutes, plug the unit back in, Turn the Master ON/OFF Switch to ON. Hopefully, that 15 minute timeout allowed the electronics to reset and revert back to the original factory settings.
Hope this helps you.
Jul 08, 2011 | Sharp AF-S85FX Wall/Window Air Conditioner
I get an error code e1 and have cleaned and replaced the filter. Runs for a couple minutes then shuts of with same message. Any ideas?
THIS SHOULD RESET IT
1 DISCONECT THE POWER PLUG FROM POWER SUPPLY 2 CLEAN FILTER 3 HOLD DOWN THE POWER ON/OF BUTON ON THE UNIT AND PLUG THE UNIT KEEP PRESSING UNTILL IT EMITS A BEEP SOUND FOR APROX 5 SECONDS 4 DISCONECT POWER AND PLUG AGAIN
IF THAT DOES NOT WORK 1 DISCONECT UNIT 2 HOLD DOWN THE MODE KEY ON THE PAD OF THE UNIT AND PLUG THE UNIT KEEP PRESSING UNTIL IT EMITS A BEEP SOUND APROX 3 SECONDS THE UNIT WILL START. 3 STOP THE UNITS OPERATION BY PRESING ON/OF 4 RESTART UNIT.
BEST OF LUCK
May 31, 2011 | Sharp AF-R120FX 12,000 BTU Comfort Touch...
E- 1 flashing and air conditioner not running. I know your suppose to push the reset button and the on button in a certain order but the instructions are incorrect in the manual
Here is a tip that gives a further explanation of that E-1 code. The causes ofthe E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening withyour window air conditioning unit and give you some things to try to help youget your problem resolved.
E-1 Code on Window Air Conditioning Units
heatman101
Sep 27, 2010 | Sharp AF-S120MX Air Conditioner
My airconditioner displays E1 and turns off after only 3 minutes of use, what's happening?
Here is a tip that gives a further explanation of that E-1 code. The causes of the E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening with your window air conditioning unit and give you some things to try to help you get your problem resolved.
heatman101
Sep 03, 2010 | Sharp Comfort Touch AF-R120EX Air...
I have a Sharp window unit that keeps shutting off it flashes E-1. what does that mean. How can I make it work?
heatman101
Aug 28, 2010 | Sharp AF-S120MX Air Conditioner
It keeps flashing E1 on the unit , why ?
heatman101
Aug 26, 2010 | Sharp AF-S85FX Wall/Window Air Conditioner
Air conditioner will only run a short time then shut off.
Manula or online site will tell you what e-1 is, I would think it is a power outtage reading and unit needs to be reset. Dont be afraid to call your units manufacturer and ask tech how to reset unit with an E1 error.
Jul 07, 2010 | Sharp AF-S100FX Comfort Touch Air...
How can I clear E1 permently from my AC
Sharp updated the procedure for resetting the E1 code.
1. unplug unit
2. hold the Power button while plugging the unit back in
3. keep holding the Power button until the unit beeps
4. unplug unit again
5. plug it back in and it should be good
Here is the updated user manual
http://www.sharpusa.com/downloads/archives/product_manuals/air_man_AFS100FX_S120FX_S125FX_R100FX_R120FX.pdf
Jul 30, 2008 | Sharp AF-S120FX Air Conditioner
E1 code
Use a universal remote (like the one for a TV) to turn on and to adjust settings. I was some what doubtful, but after trying my universal remote, my air conditioner started working.
Jun 18, 2008 | Sharp AF-S120MX Air Conditioner
Sharp AF-S120MX Air Conditioner Logo
65 people viewed this question
Top Sharp Heating & Cooling Experts
AJMAL KHAN
Tim Whalen
Brandon Berry
Brandon Berry
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
