Sanyo Vizon 20inch When you turn the television on it goes off and back on by itself then it will stay on..today it does the same and now will not come at all.I have checked with the cable company...and have unpluged it for 2 hours in hope that it would program itself but no luck..any advice?
  • rlgentry8 May 09, 2010
    model......CLT2054
    Serial....B5340688130630
    I am not a Mr Fixit...I hope there is an easy solution
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
If I understand this correctly it would go off and back on by itself on eventually stay on until it will not do anything now.
Let me know the model number as this is very helpful but I have some suspicions.
If it is a LCD or newer set made in the last few years there is a common problem many develop;
This type of set uses a "Standby" power supply which is up and running 7/24 and many of these sets they cut corners and use cheap filter caps in this supply.
The only way to tell if this is your problem would be to open the set and follow the power cord to the power supply. You are looking for any of the caps (see attached photo of what they look like) that are puffed up on the top.
The top should be perfectly flat and is silver in color.
I have seen and fixed a lot where several caps failed in the supply--cheap parts and if the problem a fairly inexpensive fix and usually a do it yourself job.
Please get back to me with as much info as you can so I can assist you.
Regards, SD TECH
Posted on May 09, 2010
  • SD Tech
    SD Tech May 09, 2010
    TYPICAL FILTER CAP:
    TYPICAL POWER SUPPLY BOARD:
  • SD Tech
    If you are not able to try what I suggested there is really not much hope for you on fixing this. This size set is fairly inexpensive to replace.
    Considering the replacement costs and that there is no magic wand that can be waved over the set to fix it, either someone has to open it and look or replace it.
    Check with local shops to see what they charge for an estimate in the shop and make your decision based on that and what you want to do.
    A set with power problems can be beyond a reasonable cost to fix. Many of these smaller ones there are often no parts available for them.
    I am sorry I cannot give you a easy or instant answer to fix it but what I have already suggested is the least expensive way to see what you have.
    Please let me know--and ask as many experts here as you like. I am telling the truth and I have been fixing sets for over 30 years.
    SD TECH
  • 10,515 Answers
More likely it is Power Supply Board. You need to Open the TV. Make sure it would be Unplugged. You need to Take all the Precautions. Locate the Power Supply Board. Remove the Connectors and Pull out the Board. Once you Pull out the Board, with the Help of Magnifying Glass, locate Cold Solder Joint. If Everything is OK, then you would Locate Bulged / Leaked / Swelled Caps. They would have Ammonia kind of Odor. You need to De-Solder them. You could take the same to Radio Shack / Fry's / Order Online. Once you get the New Caps, Solder them and it is all set.You also need to Check Fuses around that.
Getting a Service Manual for this Model could be tough, but i would be able to ask few vendors, in case problem would not be resolved. Usually, you could easy repair the Power Supply Board, if you could catch Few Bad Caps.
Note - I am Assuming that all the Cords and Connections are Fine.
Let me know,once done.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 08, 2010
  • taran_2005
    taran_2005 May 09, 2010
    Thanks for your response!!
    I wish we had a Better Solution. If there is any Internal Fault like Caps Failure, there is no Reset Button. I understand your concern, However, even if you call any of Technician, they would charge $35 - $75 and still tell you the same Problem.
    If you have tools to repair it, i would be glad to Guide you.
    Hope
    i helped you.
    Thanks
When turned on, screen goes black, but power light stays green
It sounds that the main digital board to this TV is faulty. Contact any service technician.
Jun 26, 2013 | Sanyo LCD-42CA9S VIZON MULTISYSTEM 42" LCD...
On a Sanyo Vizon HD TV where is the headphone jack?
Panasonic handle Sanyo TV Support now, Here are their contact numbers: Repair:-0871 3321711
Product Help:-
0844 335 2230
Apr 04, 2013 | Sanyo VIZON Multisystem 42" LCD TV 110-220...
Sanyo vizon liquid spilled on back & will not turn on now
You can attempt to recover it by either filling up a tub of white rice and leaving it sit there for a few days to a week, or you can put it near a heater to try and evaporate any remaining liquid. These steps will only work if the spill is very recent. It is possible that an internal circuit has been shorted, or an internal fuse blown. If either of these have occurred you will need to have it serviced by a professional. Contact Sanyo to locate a nearby location.
Mar 06, 2011 | Sanyo Vizon LCD-15A2 Television
My 26' sanyo vizon wont turn on and i dont know why.
I have the same tv. Was watching last night when it turned itself off. When I tried turning it back on the switch just made a click noise and nothing happened. After a couple more tries, it didn't even do that.
Jan 26, 2010 | Sanyo DP26746 26 in. LCD Television
My friend T.V. it blinks when you turn it on he has a sanyo vizon it's a L.C.D. flat screen
Probably overheated. Inadequate air circulation. Nothing you can do now. If it's less than 1 year old Sanyo might replace it w/ a refurb. I'd contact them. http://us.sanyo.com/
Oct 01, 2009 | Sanyo Vizon LCD-15A2 Television
Sanyo vizon tv black screen
Replace 12v ac adapter ( if you can find one ).
Nov 30, 2007 | Sanyo Vizon LCD-15A2 Television
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
