Question about Emerson Audio Players & Recorders
Emerson Dual CD Audio System CD stops playing
The CD player on my Emerson ES17 will play 1 or 2 tracks on a CD and then the power will shut-off and will restart the CD a couple of times and it will show it has no disc.
  • mikey6786 May 09, 2010
    I tried this today and it didn't do anything different, when you first turn on the CD it will play 1, 2 or 3 tracks and the power will shutoff and after a few seconds it will come back on and play a few seconds and the power will go off again, it will do this as long as you leave it on turned on.
  • 10,515 Answers
This is a Common Problem with Lens. Unplug the Unit for Few Minutes,say 30 minutes and then Turn it ON.
If problem persists, then you could try to use a Lens Cleaner CD. More often that would work. Unless you need to either Replace Lens or there is a Fault in Electronic Circuit Board.
Both of these would need unit to be Opened and Repaired. If you wish to Repair it, Revert and i would be able to Guide you.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 08, 2010
  • taran_2005
    taran_2005 May 09, 2010
    Thanks for your response!!
    That's what i initially mentioned that More often, it needed repair. If you wish to Repair it, Revert and i would be able to Guide you.
    Let
    Hope i helped you.
    Thanks
Is having trouble reading or tracking disc.I opened top and while playing disc the tracking mechanism goes out then back in and starts playing where it stopped?
You can clean the lens with a small amount of windex and put a little oil like 3 and 1 oil on the spindle motor shaft and on the sled rails. Good luck !
Aug 22, 2015 | Audio Players & Recorders
Display demo
Could it have been knocked when in storage? Also try cleaning the lens of the CD player see if that makes a difference.
Jul 23, 2013 | JVC MX-K30 CD Shelf System
My Sony mini hifi component system is going berserk!! 2 problems: 1- CD system skips tracks and on playing on repeat song, the song skips certain times and jumps ahead of the track. 2- Tape system plays...
Your cd player is fubar and in definite need of replacement.
Tape unit seems to have a mind of its won. Try to reset the electronics to factory defaults. If that has no remedy, since it is a sony< best advise is to trash it. Repair cost is prohibitively expensive.
Sep 19, 2017 | Sony MHC-RG222 CD Shelf System
CD playing erratic
Run a "Laser Lens Cleaner" thru the unit a couple times. Use one that takes fluid, you can find them at just about any retail store for 15-20. If that doesn't solve it, it needs to be repaired. At that point weigh the cost over replacement. A new transport usually will cost 100-150 on average for parts and labor. Hope this helps
Jun 23, 2009 | Audio Players & Recorders
CD player does not work
10/6/08 Update.
Solved the problem myself.
Repositioned the printed circuit board with the CD Drawer open/close limit switch.
I suspect that the board shifted during shipping and failed to trigger the closed drawer position.
Player is now working.
Sep 27, 2008 | Emerson NR303TT CD Shelf System
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Cd jumps tracks
The CD lens may need cleaning.
Try a 'wet' CD lens cleaner.
The laser PU may be low emision.
Nov 09, 2007 | Emerson MS9700 CD Shelf System
CD's won't play
I know that Panasonic provides chips, optics (laser),etc. to Emerson. I am familiar with the problem you've experienced because I've had a Panasonic CD Player. If the disc doesn't spin (as you said), the problem must be that your shelf system probably has an optical problem (laser problem/pickup problem) and will need to be serviced.
Apr 22, 2007 | Emerson MS3103 Shelf System
I need a manual for my Emerson ES17. I have had this radio for some time now and its still in excellent condition, altho I seemed to have lost the manual. Please help.
Stefanie, An Emerson Owners manual for a model ES17 is available but Emerson dosent give them away like alot of other companys let you download them for free. It is available for a download or paper copy but thet get about 6 bucks for them. I think thats terrible! Try Here Http://www.treasurechestcorp.com Good Luck
Jul 26, 2006 | Emerson ES17 CD Shelf System
54 people viewed this question
Top Emerson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
