Ricoh 1170L model
Hello!
I have a ricoh 1170L model fax machine. I have one touch dialing capability and I need to edit the fax numbers that are currently stored. I can't figure out how to change the numbers. I would greatly appreciate your help.
Thanks!
    Novelist:
  • 141 Answers
Http://www.ricoh-usa.com/downloads/manuals.asp?tsn=Ricoh-USA
This is the link for the manuals
Scroll down to Facsimile
From the Drop Down Menu, choose your machine and click GO
It will take you to the manual (PDF format)
I hope this will help you.
Posted on Mar 27, 2008
I need to erase the speed dial and quick dial lists in my Ricoh 3770 fax machine.
Many of these devices have a Web Interface that you can access if you have administrator's rights (password) and the original password was not changed when the device was installed. If you are not using it as a network printer and only a fax, you would still need to login as the administrator to edit/delete/add fax numbers.
Jun 22, 2017 | Ricoh Office Equipment & Supplies
Need to reset speed dial numbers but cannot get the cursor to appear.
Dear
Storing One Touch Dial Numbers 1Press Menu, 2, 3, 1. 2Press the One Touch key where you want to store the number. 3Enter a number (up to 20 digits), and then press Set. 4Enter a name (or leave it blank), and then press Set. 5Press Stop/Exit. Storing Speed Dial Numbers 1Press Menu, 2, 3, 2. 2Enter a three-digit (a two-digit for FAX-4100e) Speed Dial number, and then press Set. 3Enter a number (up to 20 digits), and then press Set. 4Enter a name (or leave it blank), and then press Set. 5Press Stop/Exit.
Thanks.
Feb 03, 2015 | Brother IntelliFax-4100e Fax
Recieving error open heat error
Unfortunately with this error/issue the Fuser will most likely need to get replaced. If you are covered by a service agreement please call 1-800-835-6100 Option 1, 1 or call them if you need to get part numbers to order privately. To purchase the parts,call 1-800-835-6100 options 9,3,1.
Oct 12, 2011 | Ricoh Fax 1170L Laser Fax Machine 1170-L,...
How do i change programed number
Hello Ms Nelling,
You can change the programmed numbers by simply programming new numbers on the saved position.
Press the MENU/SET button and select FAX \ Setup Quick Dial and then choose whether you want to program a speed dial or a one touch button.
If you had previously programmed a 1 touch on button 3, just select that 1-touch and it will ask you if you wish to change the current settings.
Thanks,
Pat
Apr 14, 2011 | Brother IntelliFax-2820 Laser Fax
How do I delete speed dial numbers on the Intellifax 2820?
Changing One Touch (For FAX Models Only) and Speed Dial Numbers
If you try to store a One Touch (FAX models only) or Speed Dial number in a
location where a number is already stored, the LCD shows the current name stored there, and then prompts you to either:
1 Press 1 to change the stored number-OR- press 2 to exit without making a change.
2 Enter a new number, and then press Menu/Set.
• If you want to erase the whole number, press Stop/Exit when the cursor
is to the left of the digits. The letters above and to the right of the cursor will be deleted.
• If you want to change a digit, use or to position the cursor under the digit you want to change, and then type over it.
3 Follow the directions beginning at Step 4 in Storing One Touch Numbers
(For FAX Models Only) and Storing Speed Dial Numbers.
Dec 03, 2010 | Brother IntelliFax-2820 Laser Fax
I don't understand the one touch dialing on the HP 2140
Hi Suzeo. Many HP fax machines have the function you are requesting. It is called the broadcast fax feature. Look in your owner manual for this feature. If I knew which model you have I would have researched it for you. IF by chance, your machine does not have this feature, it would be money well spent to replace your current machine with one that does. Depending on how many pages the daily fax is, I am estimating that you are spending an hour or more each day on this task. J.
Jul 03, 2010 | HP Office Equipment & Supplies
How to turn off the 'toner empty' message on a Ricoh 1170L
Just looked in the service manual. There is no SP to turn off toner message. The only way to clear it that I can see is to add another toner cartridge.
Apr 13, 2010 | Ricoh Fax 1170L Laser Fax Machine 1170-L,...
How do I delete stored faxed numbers (speed keys)of the fax machine? How do you change a speed key title?(let say I fax documents to this fax number everyday: I stored the fax number under the name "Team...
From Ricoh Aficio MP2550 manual:
Delete destinations registered in the LAN-Fax Address Book:
numb01.gifOn the [Start] menu, point to [All Programs], [LAN-Fax Utilities], and then click [Address Book].
The [Address Book] dialog box appears.
If LAN-Fax Driver has already started up, click [Edit Address Book...].
numb02.gifClick [New/Browse...], and then select the CSV file containing the address list to be edited.
numb03.gifSelect the destination you want to delete so it is highlighted in the list.
numb04.gifClick [Delete].
numb05.gifClick [Yes].
numb06.gifClick [Close].
numb07.gifIf you made changes to a destination, a confirmation message appears. To save the changes, click [Yes].
If you do not want to save the changes and want to quit editing, click [No].
To return to the editing display, click [Cancel].
The confirmation dialog box does not appear when you have not made any changes after starting Address Book.
You can download the manual (HTML or PDF/ZIP versions) from here:
http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/mp33/mp33en.htm
Jul 29, 2009 | Ricoh Aficio GX5050 GelSprinter InkJet
133 people viewed this question
jasbo
jasbo
