Question about RCA D56W20 56" Rear Projection Television
Cable connection The male cable input on the back of my t.v has broken off and i have no way to hook up cable. is there another way to bypass that of how can i fix it if not both.
    Genius:
  • 1,030 Answers
Take the rf connector and plug it into vcr or dvd player then using rca cables plug it into vid 1 and change to that input on tv... the down side is you have to change channel using dvd or vcr remote....as a tech i repair those cable connectors every day someone who can solder may be able to fix it.
Posted on Mar 27, 2008
How do i hook up auxillary chord to a denon avr-884
There are several "line" inputs that should work.you will need an adapter to go from 3/5mm [1/8" phone] to RCA Stereo. This can be a cable with Male 3.5 mm stereo on one end and two RCA male on the other, or a 3.5 M-M cable plus a 3.5 female to RCA male adapter. or a stereo M-M RCA cable with RCA F to 3.5 Male...
If you have easy access to the back panel, plug into and use the CD/Tape [IN]. Or you can simply plug the RCAs into the front L and R audio and use that input sans video.
Jan 03, 2015 | Denon Audio Players & Recorders
I want to connect my dell inspiron 1525 to my lcd hd ready tv but have no idea how to? Does anyone have any advice?
The 1525has a a hdmi port which you can plug a hdmi cord into. This may not support the audio. the tv and pc should detect the new monitor automatically or you may have to toggle it by hitting F4 key.
Apr 22, 2011 | Dell Computers & Internet
How can i hook up xm receiver to unit
hi,
you can connect the XM receiver to you player. for that you need a cable (STEREO MALE TO RCA MALE CABLE). its one end will looks as headphone pin and the other end 2 RCA pins.
connect the headphone pin to you XM receiver's earphone out and the other end (2 RCA) to the AUX IN 2 (AUDIO L/R)(on the rare pannel) of ur player.
select the AUX 2 input pressing the FUNCTION button on your player.
or
purchase a STEREO MALE to STEREO MALE cable and connect its one end to the earphone out of XM radio and the other end to the AUX 1 input of you player (on the frond pannel)
select AUX 1 by pressing FUNCTION button
ok
Jan 13, 2011 | Samsung HT-X50 System
I have a Sony ICD-BX800 IC Recorder. I have purchased and hooked up the Audio Cable to transfer the recordings to my computer (I need to email them to someone.) However, I did a test recording, and the...
Sony IC RECORDER ICD BX-800 (!without USB connection!)
What you need:
- newests audio drivers in Windows 7 (updated audio-drivers)
- audio cable 3,5 M (male) both ends M-M (male-male)
- freeware application Audacity for Windows (with LAME)
Howto step by step:
- one end of audio cable connect to dictaphon's headset (earphones) jack in recorder Sony IC RECORDER ICD BX-800
- other end of audio cable connect to PC/notebook microphone (or LINE IN)
- nothing special setup (adjust) regarding Audio in Windows 7, the device for record Audio keep Microphone (default)
- in Audacity set very little volume "Input Volume Slider" and "Output Volume Slider" (for example both 0,1)
- in Audacity like Input Device set "Input (Audio device High Definition Audio)": !Don't set in Audacity like Input Device "Microphone"!
- Audio Host: MME
- Output Device set "Speakers (Audio device)"
- Input Channels set "2 (Stereo) Input"
- Sampling (Hz) set 44100
Dec 26, 2010 | Audio Players & Recorders
The cable plug in on back of this new television has come unattached from the television. How can it be fixed? Purchased from sams couple of months ago. Just hooking up to satellite. Can I fix?
You have to be very careful when reattaching this connector because some models use a HOT ground and if you short out this circuit you can damage the TV's power supply. If you haven't done
soldering before I would suggest taking your set to a TV repair center.
Since you have satellite I would suggest bypassing the broken cable input jack and using either the video/audio out from the satellite receiver to the TV's Video 1 input or the satellite receiver's HDMI output to the TV's HDMI 1 input jack. Of course you'll have to switch the TV's souce to match the input that you selected. This will work fine without having to worry with the expense of fixing the broken cable connecter.
Hope this does the trick,
Casey
Dec 07, 2010 | Sony Televison & Video
Sony KP-53XBR45 rear projection TV: Coax input Selector Antena part on rear has the AUX input 'male' connector but the TV/Cable 'male' connection end is missing. Is there a way to use the AUX or any other...
You can replace the connector or if you have a cable box with audio and video outputs on it---connect them into one of the sets of jacks on the back of the set--switch to that input and change channels with the box----you can also do the same thing with a VCR--hook the cable into it and use its video and audio output jacks to connect to the video and audio input on the back of the TV.
In this case (the VCR does not have to work except as a tuner) you will go to whatever input you connect to and use the VCR to change channels.
These are a little less easy to use but costs you nothing---I am here to help, if you have any questions or need help let me know.
SD TECH
Oct 04, 2009 | Televison & Video
How can i connect an mp3 player on my Power Acoustik PTID-4007
Expandability Options:
  • 3 sets of preamp outputs (front, rear and subwoofer)
  • Telephone Mute trigger wire for Bluetooth adaptation
  • iPod Ready: IC-1 iPod Connection Cable Required and Sold Separately
  • Front-panel auxiliary input: Mini USB input and SD Card slot
  • Rear auxiliary input: 1 back-up camera input and 1 A/V input
  • 1 Video output
The aux rear a/v input should do the trick.
If it is a component (RCA) type input, you will need a Male 3.5mm to dual Male RCA adapter.
If it is a 3.5mm input, a Male 3.5mm on each end.
I believe you will need the Dual RCA (red/wht) to 3.5mm cable.
The Audio inputs are purple RCAs on the back of your head unit.
Jan 14, 2009 | Car Audio & Video
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Jan 12, 2008 | Protron PD-007 DVD Player
PS2 connection question
by connectors do you mean a coupler? if so that should work. also verify that you are hooking the yellow (video) to an input and not an output.
Dec 08, 2007 | Sony PlayStation Portable (PSP) Console
Surround Sound using the video feature
You will not get 'surround sound' from this set only stereo sound. The Video/Aux jack at the back of the unit is an input terminal. You can connect the audio part of your TV(if it has a Line Out jack), dvd player or video game console to this input to get the sound through the stereo system. Use a male-to-male RCA cable to make the connection, they are color coded (Red and White). Press the "Video/Aux"  button to select the input terminal.
Nov 04, 2007 | Sharp CDBA3100 Remanufactured Mini-System...
RCA D56W20 56" Rear Projection Television Logo
64 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
