Question about Insignia NS-24 TV TV
Yellow color The television color goes from normal to yellow. And stays yellow for different periods of time. Some times it will go back to normal, other times it stays yellow.
  • Insignia Master
  • 8,457 Answers
Ur tv is missig the red color,when it turn into yellow color.Take ur tv to another location,put it into another coalax incomming signal cable use it for awhile see,if have the same problems?Not,than it ur coalax incomming signal cable is defective.Yes,take ur tv aparts the video board that connected to the CRT socket holes are cold solders,resolders those CRT socket holes to have good conductivity.Will not lose red agian.Or take it to the shop,they will resolders it for you.Ask they'll charge u maybe $40-50 get it service,more than that don't they're cheating u.
Posted on May 09, 2010
Sanyo dp26648 has sound, but has vertical lines w/picture popping in periodically.
change your device cables or try to put at a pc to check if isworking your pc
Dec 15, 2013 | Sanyo DP26648-R 26 in. LCD TV
When TV is first turned on, color looks like a reverse negative in a photo, picture is mostly black, white, and purply pink. TV picture then shuts off, power light indicator stays green, sound stays on....
we had a SONY Rear projection and we had that problem turned out to be a bad fan and caused the main control board to fail thus the same problem contact the company and see what the warranty covers
Jan 02, 2011 | RCA HD61LPW42 61" Rear Projection HDTV
It stays on for a different length of time each time it's turned on. Sometimes will work for many hours per night and 4 or 5 nights, sometimes will stay on for only a few minutes. When it shuts down, you...
This tv is aging and you many bad grounds on the deflection board [it has the flyback transformer] And many bad grounds on the signal module [has convergence ICs]. And many many bad capacitors..I know as I repaired a few of these.
Nov 20, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Color went from normal to tecno pinks and blue polaroid TLA-04641
Turn it off unplug for 1 hour. Turn back on and time how long it takes to go bad, if it does. If the set works, then goes bad after time, you have a temperature sensitive component that's bad or will be 100% bad soon.
Mar 30, 2009 | Polaroid FLM-323B Television
My Samsung DLP TV is making a noise that sounds like a bad fan.
This high pitch noise comes from the color wheel. Now is unbalanced and the noise is going to be even hardest with the time. send it to change now. this part is inside the light engine
Dec 26, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
DLP Colors Are Off - Picture Is Mostly Blue and Yellow
You are missing either red drive signal to CRT or you have a cold / fractured solder joint on the television. Also with the set unplugged check with a non metalic object like a ruler or a wooden spoon and start tapping around in the front or back of set and see what happens. See if you can narrow which area of the set has a problem... Good luck future technician.. Happy holidays.. Jay
Dec 08, 2008 | Hitachi 43FWX20B 43" Rear Projection...
Picture keeps turning green or yellow
This could be the screen amp board or a picture tube shorting.
$$$ yes
Jul 11, 2008 | Sony KP-57WS520 57" Rear Projection...
After approximately 10 mins watching a dvd on JVC TH-1U system the screen turns to a yellow picture. Some times it will flicker between normal and yellow but then settles on yellow. Switch it off for 5...
This can be so many things, could be the color wheel, lamp, etc...depends on the type of tv.... If you got it from Best Buy and are in your 1 yr warranty or if you bought the service plan ( a must with any electronics) then give them a call and you will be all set.
Jun 07, 2008 | Televison & Video
Picture goes out periodically
Sound like color problems, could be convergence going out. Not quite sure of yellow color, but you could be loosing one of the 3 colors red blue green, this could be why you see yellow.
Sep 24, 2007 | Sony KP-61S75 TV
Insignia NS-24 TV TV Logo
140 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
