Question about Fisher and Paykel 23 in. DD-603 Built-in Dishwasher
FLASHING F-1 THE MACHINE IS FLASHING F-1
  • Fisher and P... Master
  • 3,247 Answers
There is water collected in the base of the dishwasher under the drawer.
the F1 alarm is triggered by a flood switch.
Turn mains power off.
Extend the drawer out as much as possible until the base of the shell is exposed. Take a few towels and dry it out. Also run a hair dryer across the base.
Wait a little so that moisture dries off and then turn back on.
The causes of flooding can be many. Too much foam in detergent, kink in the water inlet/ outlet hoses or a cracked hose, or simply some leak in the drawer gaskets.
Posted on May 08, 2010
Testimonial: "Thanks, I will try that but what if that is not the problem ?"
1.My Nespresso Pixie Lights never stop flashing. 2. I also want to reset to factory settings because the cup portions are off. 3. I feel the water temperatures is never hot enough for the coffee
1: Depending on how long you've had your machine, it may need descaling. The machines are preset for hard water - if you're in an area with soft water, try pressing and holding the Lungo button while you turn the machine on. Hold until the lights stop flashing.
2: The Pixie can be reset to factory settings by holding both buttons down before and when you turn the machine on, again until the lights stop flashing - this will reset to factory settings.
3: The temperature is preset to be the optimum temperature for the extraction process. If, after following the above steps, the temp is still too low, call the Nespresso Club and they will advise you.
Hope this is of help to you!
Mar 18, 2015 | Nespresso Coffee Makers & Espresso...
How do I fix dyson cordless vaccum flashing red light
Hi there, it's Jack at Dyson.
A flashing red light from a Dyson cordless vacuum signals a fault with the machine. We're happy to take you through some simple diagnostic checks over the phone when you have your machine easily to hand - just give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
If a replacement part is needed we can also confirm if this is covered under your Dyson guarantee.
We'll look forward to speaking with you.
Feb 20, 2015 | Dyson Vacuums
Hoover dyn9144dg washing machine door lock flashing wont start.....lock changed still wont start.....light still flashing
Hello the
Plesre and welcome to fixya
can i ask you a question did you unplug the machine and leave it sit for at least 1 hour
See these machines have a internal computer that stores information like any settings that are in the programed in the machine
It normally takes any where from 45 min to at least 1 hour to compete the memory loss on the computer thus resetting the computer ok
so please tell me if you did this if so there is more that we can do ok
Best regards michael
Dec 10, 2013 | Washing Machines
Flashing lights.
The Flashing lights indicate several different things. 1 flashing red light means its time to charge your unit. if it is still flashing after charging then you will more than likely need to change the battery. A flashing red and green light means that the unit is overheating which could happen if the filters need to be washed, or that there is a blockage or if your machine has been left in direct sunlight. Allow 1 hour for machine to cool down. 3 flashing lights indicated that the pre-filter has been put on incorrectly. I hope this helps. If you do decide to wash your filter dont use any type of soap it is not needed and allow fiter to dry for atleast 24 hours. putting a wet or damp filter in will damage your machine.
Sep 18, 2011 | Dyson DC16 Root 6 Bagless Handheld...
Indesit D41 lights 1 & 2 flashing
1, Tilt machine and remove base plate 6 screws.
2, fixed to the inner ring at the bottom of the machine is the water level control.
(brown, round with 3/4 wires attached.
3, remove it, lift and pull forward.
4, remove the attcahed clear plastic tube.
5, tip up and drain out any water in the unit, Should be none.
6, Blow throught the free hanging rubber tube, should be clear
refit.
Dec 21, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
IBM Personal Wheelwriter 2 - Machine comes on and is stuck with flashing lights on the left . . .
If the 1 &2 lights are flashing check the keyboard conectors and see my tip under WW1000.
DickyO
Dec 11, 2008 | IBM Wheelwriter 30 Typewriter
Getting an error L flashing then 1
Background:
The L1 is indicating a scanner lock.
Easy way to fix it:
1. Turn machine off.
2. Turn scan locking switch to unlock. This is a clear plastic knob. (it is located on the left hand side of the machine under the document glass in the copy exit area - check your manual for a picture of it around page 9 or so).
3. Turn machine back on.
4. Try a copy.
5. If you still get an L1 then it might need service because the scanning bar is jammed. They will ask you to try some service codes first to verify that it is indeed jammed. Call 1800 237-4277 for further support.
Followup:
This also is a fix if you are getting blank copies.
Mar 18, 2008 | Sharp AL-1641CS Laser Digital Copier
Indesit WIL103 flashing lights problem
because of the short time this runs then stops, there could be maybe 3 faults, 1 check water inlet valves and supply for water flow 2 check for any motor action (use another programme) 3 check heater element for open circuit number 1 or number 3 sounds most likely hope i have helped, if so rate me please
Sep 25, 2007 | Indesit W 123 Front Load Washer
Fisher and Paykel 23 in. DD-603 Built-in Dishwasher Logo
125 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
