I would need an disk engine for my external Western Digital 250GB disk? The disk seems ok but it the engine doesn´t work.
  • 88 Answers
yes if it's broken :/
Hard life with those HDDs. Try to find SAME model on ebay e.g. if you wish to recover files.
Leave rate if I helped you, thanks!!
Cheers,
Mike
Posted on May 09, 2010
Testimonial: "Had that in mind but now I´m sure thats what i have to do.Thanks"
Ac adaptor will not work
Go to any computer-store, and buy a new "empty" external drive enclosure.
Then, "transplant" the disk-drive from your W.D. enclosure into the new enclosure.
All your files will remain accessible, and the new power-supply will power your disk-drive.
Nov 04, 2010 | Western Digital 250GB ELEMENTS EXTERNAL...
Western Digital external USB 2.0 Problem
Buy an External USB 2.0 Hub with the 5.0V power supply. I have a TARGUS 4 Port Hub. MY WD2500XMSB works fine thru the HUB, but will not work using any cable (even the one that came with it) when directly connected to the USB port on my computer. The power consumption of passports sometimes exceeds the .5 milliwat rating for the ports and ccause the port power to interrupt (see USB 2.0 specifications). The external hubs with external power have a higher power output usually an can power the passport drives. CW Rumsey
Oct 07, 2009 | Western Digital 250GB MyBook External USB...
The WD does not show up
I had the same problem with my WD eBook external hard drive. I had to send it back to the factory at Western Digital and they replaced it free. From their support website, you can download the shipping label after you enter your serial number and other information. When drives make that kind of noise, its not a good thing and you have done the right thing already by trying it on other computers. Now you know it won't work.
Sep 12, 2009 | Western Digital WD Passport 250GB Portable...
Local disk error WD My Passport 250GB
Do you connect & disconnect the drive according to WD's recommendations here? Try another cable. (If yours was wearing out, that might explain why it only connected some times.) Try another usb port. Check the power supply (another receptacle) Unplug other usb devices from the system.
See this article. Good luck!
Aug 18, 2009 | Western Digital WD Passport 250GB Portable...
I cannot retrieve my files from the wd 250gb
First instinct is that your drive has failed. I would remove the drive and insert it into a system to test. If it works, then it is the housing from the external drive that failed. If the drive does not work once inside your system, then the drive is bad. Good luck.
Jun 04, 2009 | Western Digital 250GB MyBook External USB...
Western Digital 250GB External Hard Drive not working
there are a couple of reasons for this. Likely the drive has not been setup in Windows. Hard drives need to setup in Disk Management. Disk Management can be found under Computer Management in the Control Panel. After you run Computer Management, expand the Storage tab and Disk Management is located there. At the bottom of the screen threre is a listing of all drives (hard and CD) located in or attached to system... You will see your new drive listed, but not active. Right click on the new drive in the bottom window and Windows will prompt you on how to configure the drive. You'll need to activate so Windows can assign a drive letter to the drive, partition and format. Once this is done, you will be able to see and use the drive under windows.
I've attached a link from Western Digital that provides their FAQ response to your issue.....
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=1017&p_created=1055796499&p_sid=7R8631pj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTQsMTQmcF9wcm9kcz0yMjgsMTAxLDIxOSZwX2NhdHM9JnBfcHY9My4yMTkmcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PXJlY29nbml6ZWQ*&p_li=&p_topview=1
You didn't mention what type of connection it uses (USB, etc). According to Western Digital, if you have a USB External Drive, you should get a prompt to install drivers by Windows when a new device is installed. Similar for Firewire device.... Did Windows "recognise" the new device by opening a New Device Found window? If not, try using a different USB port and/or ensure the USB port is enabled in WIndows.... The Quick Start guides for all models can also be found from the link provided above.
Jan 24, 2009 | Western Digital 250GB MyBook External USB...
Computers & Internet Logo
David Payne
David Payne
