Question about Samsung Blackjack SGH-I607 Smartphone
No service I reset my blackjack phone and everything works well. when i power up my phone it shows no service, i can not make outgoing calls and can not recieve incoming calls. my sim card is working ok and we have tried everything to get the phone to work, any other suggestions on what to do to get phone service to work.
  • 1 more comment
  • pizzle Apr 30, 2008
    My samsung blackjack phone says that it is searching at the bottom left hand corner of the screen. I have no service anywhere. Somone told me that it was the simcard that isn't working, but all my numbers are still stored and my simcard is 3G, which 3G was made for the blackjack. HELPPPPPPPPPPPPPPPP!
  • Anonymous Jul 06, 2008
    yes my phone powers on get the 3G signal and all but it still says phone power off. what can i do???????
    I have taken the phone apart to see if anything wasnt connecting. i reset it. my next step is to change the antena. not sure how true this is but i heard that there is a silent recall on the blackjack,the antena s are faulty on the ones made from 2006 to 2007
  • Anonymous Nov 20, 2008
    I have the same problem i dropped it in water and waited for it to dry to turn it on everything works fine but i have no service what so ever and water voids the warranty so im screwed. :(
My service stopped working
Posted on Nov 19, 2008
6ya staff
SOURCE:
My panasonic KX-TG5000 phone headsets cannot make or recieve outgoing calls and the intercom function is gargly.
You need to reset the menu once again as it is possible that the phone had hung up as there was LINE PROBLEMS . Once this was reset the CLIP facility came back. So if you can once again remove power battery and keep aside to reset , then start all over to set up the base and slave units to MESH , the intercom and line facility must work.
You can remove the battery from the slave remote units to reset.
Oct 20, 2011 | Panasonic KX-TG4500 Phone
I cannot send text messages from my sony ericsson vivaz u5i, but i can recieve text messages, incoming calls and i can make outgoing calls.. what is the factory setting code so i can reset my phone?
First, try this:
  1. From the main home screen, tap menu
  2. Tap Settings, then Privacy
  3. Tap Factory data reset
  4. Tap Reset phone
  5. Enter your password if required, then tap Erase everything to confirm
If that doesn't work, or if your phone is frozen:
  1. Turn the power off. If your Sony Ericsson Xperia X10 is frozen, pull the battery out and reinsert it
  2. Hold the Left and right buttons located beneath the display
  3. Press and release the Power button
  4. Follow the on-screen instructions to hard reset your Xperia X10
All data including third-party applications will be deleted from the Sony Ericsson Xperia X8. Once the wipe is complete, the phone will reboot to its factory fresh state.
The password is user defined, try the second method if you did not set a password.
Good Luck!
Jun 16, 2011 | Sony Ericsson XPERIA X8 Cell Phone
My blackjack 2 is suddenly reading no service
Im guessing that the Reciever/ Data/ Projection outgoing antanae became disloged on impact(that isnt the official term so dont use it if u talk to ATT. You can either risk damage to the phone and take it apart and screw it all back together, or send it to ATT for free if you got the insurance or warranty. I dont recommend taking it apart b/c you might have to break it and even once you get inside it might be unfixable!!!!!
Apr 11, 2009 | Samsung BlackJack II Smartphone
Error 20 01 NG: poor line condition on outgoing fax's
My fax shows poor line condition. I have checked all of the connections and everything is ok. Perhaps my settings are wrong
Jan 23, 2009 | Brother IntelliFAX 4100 Laser Fax
Help!!
What happens to the incoming calls? Check that you have not set the phone so that calls are diverted to voice mail or another number. Call your service provider and they will probably be able to send you a "service message" that will reset that.
Dec 16, 2008 | Samsung Blackjack SGH-I607 Smartphone
Service loss
I have the same problem and I know it is an ATT thing, ive noticed that if i turn the phone on then off again i get a more accurate reception for where I am at so try that next time you get that awful "no service statement"
Oct 02, 2008 | Samsung BlackJack II Smartphone
My samsung blackjack phone has trouble finding the network and dialing out and sending text messages, sometimes it would work fine then it won't work at all, is this a software problem?
my samsung blackjack recently started acting up and showing "no service" or "searching" on the screen. my account is active and is up to date. it has the exact trouble what frank10 is saying. i have called at&t and they reset it twice already and nothing has worked. can't wait for my phone upgrade in october.
Jul 28, 2008 | Lands Phones
Unable to make and recieve calls
I flashed and flexed the set but to no avail, tried a software update but no update was available from motorola. I then went to the Security settings of the set and restricted all outgoing calls and restricted all incoming calls except the phonebook entries. Then I dialed my mobile using a landline which was on my phonebook and my phone started recieving the calls, then after that I allowed all incoming and outgoing calls. This solved the problem. I believe it is sheer luck because I tried that step earlier on the same day but it gave no result.
Jul 21, 2008 | Motorola Mobility L6 Cellular Phone
Samsung Blackjack SGH-I607 Smartphone Logo
231 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
