Question about Navigon 2100 Portable GPS Receiver
Navigon 2100 car charger unscrewed. Found a few
Navigon 2100 car charger unscrewed. Found a few pieces and looks as though it needs a fuse.
What strength and where could I buy a fuse? Radio Shack only sells complete units and I'm too cheap to pay $30 when I may just need a part. Thank you.
    Problem Solver:
  • 9 Answers
[PDF] NAVIGON 2100/2120 User's Guide Your NAVIGON 2100/2120 comes with the following accessories. .... With the NAVIGON 2100/2120, you can also use an external GPS antenna (not pro- ...
support.navigonusa THEIRS A SITE FOR YOU YOUR FUSE IS A 6V 1 A RADIO SHACK SHOULD HAVE ONE OR PACK OF 5 6 BUCK OR SO
Posted on May 09, 2010
Navigon 2100 screen problem
When you changed your charger, did you get the right one?
I bought an iGo and thought I could use the standard min usb tip. However, tip number A53 does charge and show the map.
I hope this answers your question.
Mar 23, 2010 | Navigon 2100 Max Portable GPS System
My GPS stopped speaking consistently and then it
You will need to replace the battery. Either you can buy one of garmin website or you can use a third party website. Be careful of using those because some of those batteries are refurbish.
Dec 16, 2009 | Navigon 2100 Portable GPS Receiver
Navigon 2100 displays the computer symbol when connected to charg
Wiring diagram pinout for Navigon GPS charge and concurrent use Pin Pin
Name Description 1 +5V 5 Volts Direct Current 2 Data floating/Not connected 3 Data floating/Not connected X Ident Conneted to Pin 4 (GND) as pure short, no resistor 4 Ground Ground, shorted to pin "X" Use of standard mini-b will place unit in Data Exchange/Synchronization mode. Use of mini-b with a 4-x pure short will allow use of Navigation software and concurrent charging. USB power source must be 1000 ma or above.
Sep 13, 2009 | Navigon 2100 Portable GPS Receiver
Need fuse replacement
Fuse 5S2A 250V FUSE:2:0A
Exclusive use for only 12V negative ground electrical systems, this is of the lable on the charger, i am still looking for a supplier for the fuse.
Jul 15, 2009 | Navigon 2100 Portable GPS Receiver
When i plug my NAVIGON to car charger he is not working
So, if it's good on the mains !!!
There is a fuse in the Charger's connector,(( on the end of it ))
unscrew the end and check the fuse is good.
Also check the cars fuse hasn't been blown too.
Or battery could be dead, some are repacable,
you can buy batteries online, 2 screws to remove to change it.
Hope this helps
Regards
Ric.
Apr 17, 2009 | Navigon GPS
Plug in car charger and it shows navigon connected to computer
The problem lies with the fact that a standard mini usb pin-out has + voltage on pin 1 and ground on pin 5. The navigon is programmed to recognize this as a computer. The navigon charger however has + voltage on pin 4 and ground on pin 5. The reason for navigon doing this as opposed to following the standard pin-out is due to the unit requiring a stronger power supply to charge the battery. USB current output on a computer does not have the capacity to do this. As a consequence, you will have to find a charger that has the right pin-out for this device ( + on pin 4 and - on pin 5 ). The tough thing is, there is no way to tell one from the other, they look identical. However, I have found that chargers with a capacity of 1000 ma or greater are pinned-out like above ( + on pin 4 and - on pin 5 ). Other than using a multimeter to verify the pins, the only thing to do, would be to plug it in and see if it works. Hope this helps.
Dec 28, 2008 | Navigon 2100 Portable GPS Receiver
Screen stuck
Had same problem with a navigon 2100 and after trying my daughters car charger it worked properly. Called Navigon and they are sending me a new car charger.
Nov 27, 2008 | Navigon 2100 Max Portable GPS System
Navigon 2100 Portable GPS Receiver Logo
586 people viewed this question
Top Navigon GPS Experts
perdue40
Are you a Navigon GPS Expert? Answer questions, earn points and help others
