Question about Eureka Altima Upright Vacuum Model 2996AVS Vacuum
Broken belt i need a replacement belt for eureka altima bagless vacuum
Eureka says size U BELT... NO!! I have tried this numerous times. I finally took off a belt from an old vac. and it works !!! dirt devil size 5 belt is the way to go!!
Posted on Aug 18, 2010
    President:
  • 1,871 Answers
Hello :
If you need to know how to replace the belt then follow these steps :
1: Release the handle lock, lowering the handle to the lowest position and turn the vacuum upside-down so you are looking at the bottom of the vacuum.
2:Slide the base plate patches outward from the center to unfasten the base plate, lifting the plate off the bottom of the vacuum.
3:Slide the brush roller out of the slots in the bottom of the vacuum and take the old belt off the roller as well as from off the motor shaft.
4:Remove any strings or other debris from around the brush roller and place the new belt around the roller, sliding the brush roller back into the slots on the base of the vacuum.
5:Stretch the new belt over the motor drive shaft in the center of the vacuum base and place the base plate back on the vacuum, sliding the plate latches in toward the center.
6:Turn the Eureka Power line Plus vacuum back upright and plug the electrical cord into the electrical outlet. Switch on the vacuum cleaner to test it .
Warning :
Unplug the vacuum cleaner before attempting to replace the belt .
If you need a place where to find the belt , then follow these links :
link 1
link 2
Posted on May 08, 2010
  • Fathi Elmahdi
    Fathi Elmahdi May 08, 2010
    On link 2 there you will find explanation on how to replace the belt .
    Here you will find a Maintenance
    Schedule
    in PDF format .
    Please don't forget to rate !
4 Suggested Answers
  • 10 Answers
SOURCE: smoking belt
Belt is slipping because the bearings on the beater brushes, which it turns, are jammed or full of dust.
Alternatively the belt has stretched after being overheated and needs replacing because it now slips.
Posted on Dec 31, 2007
  • 22 Answers
SOURCE: how to put on a belt on eureka uno bagless vacuum cleaner
Unplug the vacuum.
Turn it over so you have access to the bottom of the unit (you should see the brushroll)
At the base where the "head" attaches to the body there is a small silver button that you must depress to remove it from the body. Press the button in with a screwdriver or unsharpened pencil while pulling the "head" away from the body.
Use a #2 Philips screwdriver to remove all the large screws from the bottom. They are all the same size and type so you can collect them for safekeeping without worrying about which one goes where. There are 2 smaller screws (if I remember correctly) that are for the upright lock that you do not need to remove. They will be on the small plastic piece near where the bottom brush "head" attaches to the vacuum.
Remove the clear plastic clog cover.
Gently pry the gray cover off. This shouldn't be too difficult as the cover goes loose when you remove the screws.
Flip the gray side over and you should see the innards including the brushroll, the motor, wiring, etc. Facing the assembly like you were looking head-on at the vacuum the belt should be on the right.
Pull up the far end (non-belted end) of the brushroll and then the belted end.
The brushroll should now be free and you should check the teeth on the belted end of the brushroll to ensure none are broken.
Remove the old belt from the motor (also toothed) and replace with new belt (a second spare would be handy to keep around and this is a good opportunity to clean up the air path).
Put toothed end of belt into the belt loop and stretch it a bit to get the toothed end back into place. The belt should auto adjust but just in case you may want to manually rotate the brushroll a few times after replacing the far end (non-toothed end)
Repeat the rest of it in reverse order to put it back.
Posted on Feb 03, 2009
Vac Belts
  • 701 Answers
SOURCE: How do I change the belt on Eureka Altima 12 v
Here is a link to the owners manual which has instructions and a link to the belt you need.
Eureka Altima Owner's Guide
Eureka Altima Replacement Belts
Posted on Nov 20, 2009
How do I change the belt?
Complete Write Up found here
http://www.ehow.com/way_5925959_do-eureka-altima-bagless-vacuum_.html
Hope This Helps
Positive Feedback ALWAYS Appreciated :)
Mar 06, 2011 | Eureka Altima Upright Vacuum Model 2996AVS...
My eureka vacuum won't suction and starts to smoke when I try to use it. It sounds like it is suctioning when I first turn it on, but after about 20 seconds it begins to smell like burning and does not...
The problem is that your belt is stretched and worn. This causes that burning smell and it also causes the vacuum to not pick up well. You need to replace the belt. Here is the belt you need and the manual with instructions:
Eureka Altima Belt and Manual
Jan 31, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
How to change belt in eureka altima vacuum
Here is the belt you need to replace and the manual which has instructions:
Eureka Altima Belts
Owner's Guide
Dec 31, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka IMA Vacuum - brush not turning
Your belt is probably stretched or broken. Here is a link to the belts you need and to the manual which has instructions:
Owner's Manual
Nov 24, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
I have a eureka altima bagless and it wont pick up dirt i clean it and everything it just wont work
The belt is probably worn, stretched or broken that is why it is not picking up. Here is a link to the owners manual which has instructions and a link to the belt you need.
Nov 20, 2009 | Eureka Capture Upright Vacuum Vacuum
Replace a broken belt
Nov 15, 2009 | Vacuums
Eureka Altima Bagless Upright Brush is not spinning
You probably just have a broken belt. The belt needs to be changed about every 6 months regardless. I believe yours takes a style EXT U(Extended life upright), or a regular Eureka "U" belt works fine too.
Nov 24, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka Altima Upright Vacuum Model 2996AVS Vacuum Logo
1,034 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
