Question about RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2
3 pt lift
Work slow but loader on front seems to work ok
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 17, 2010
John deer 950 very slow loader hydraulics. Changed fluids, filters, still same issue. 3pt seems to work fine and curl function on FEL seems closer to normal. Lift is where it is really slow. Tested...
a small twist in a line can do that, or a soft line.... mine,(rubber hose connecting the filter housing to the metal tube going to the hydraulic pump) mounted to the filter housing under the right floor had a weak sidewall and sucked flat
that's where I'd start. Been there! different model but was surprised what a small twist did and a soft line.
Feb 20, 2018 | Garden
Admiral Washer makes loud steady noise during spin cycle but washes clothes & completes cycle. Possible bearing problem?
If a front loader type, try lifting up on the drum. If it clunks and seems to move somewhat easily, it is probably the front bearing on drum rear support shaft--a major tear-down to replace. If a top loader, try tipping the basket (that spins) in several directions--if it makes clunking sounds, try removing the agitator and check the tub mounting bolts at the bottom center for tightness. If ok, tip the tub again and watch for movement. It may have a bad bearing below the tub at the center area. Remove the tub bolts and pull the tub out revealing the drive hub underneath. Don't know if you would have to drop the transmission to repair what you find. Good luck!
Mar 17, 2010 | Washing Machines
Front loader washer machine not rotating.
Fisrt, see if you can rotate it by hand, BOTH directions. It should have some resistance. If you can spin it and when you stop pushing it will turn a full turn, your drum belt is too loose. If the belt is good and tight, it will spin less than one half rotation, there is probably something blocking one of the wheels that the drum rides on.
Nov 16, 2009 | Frigidaire GLTF2940ES Front Load Washer
Kenmore front loader washer HE3 kenmore Elite
ok " there is a filter on that line ,it has to be cleaned
to locate filter, follow hose back to filter
filter will come apart for cleaning
Jan 11, 2008 | Kenmore 44832 Front Load Washer
Whirlpool washer front loader model LHW0050PQ
This is not a Malber machine but the following fix has worked for the Malber washer. Try unplugging the machine for at least 2 minutes. Do not just turn it off as there is still current going to the machine .This should clear the computer. If this does not work, the imbalance may have overloaded the circuit board requiring replacement.
Nov 15, 2007 | Malber WD1000 Front Load Washer/Dryer
RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2 Logo
101 people viewed this question
Top RTO Toys Experts
The Scrivener
Pete Bruk
rostit
Are you a RTO Toy Expert? Answer questions, earn points and help others
