Question about Electric Newest Esky RC Helicopter! 4-Channel Esky Dauphin - US Coast Guard Marine
I am having a problem with the trim on my helo. it wants to lean left or right even before lift off. i can use the trim but still have to hold control knob over to fly. is this an adjustment in the 4 in 1 mix control. there are no instuctions for it and don't know what the two scews do. please help
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 17, 2010
What steps do I have to take to replace the (sliding hide away door that covers the drink holder). This sliding hide away door is between the driver and the passenger seats on my 2005 Acura TL
I don't believe this part is available aftermarket, only from Acura. Part # 77230-SEP-A02ZA $93.17. It isn't hard to replace. First you pry up left and right chrome side trims on the console. Start at the back, they are held on with clips, be gentle but firm, don't flex the trim. A plastic trim tool helps. Once you've done 1, they are easy. Then it is just screws holding the rear section, slide both seats all the way forward to help lift out console. Go to Acura E Parts to see an exploded view.
Aug 31, 2014 | 2005 Acura TL
Does top lid of washer lift up
Yes, -UNPLUG THE POWER- remove the left & right trim strips on the dash and then the screws at the bottom, where the trim strips mounted. Lift the fold back the dash. You'll see a curved metal strip at each corner. Use a screw driver tip to remove them. Then the drum lid will lift off, after you unplug the LID Switch wires.
Aug 18, 2014 | Kenmore Washing Machines
Blade MQX QUAD-COPTER
It's difficult to determine witch trim buttons effect the props. The only way to do this is durring flight. At low power, since you are working with 4 axis, each set of 2 buttons will effect the rotational speed of 1 motor. Typicaly in this set up, the left stick will control power and yaw(up and rotation left and right), while the right stick controls direction and pitch.(forward/reverse and bank left or right) Here is what I think you need. The left side bottom butons, control horizontal control. If you take off and notice the helo going to the left(banking, not turning) click the right button to attain horizontal stability. If you notice it is going slightly forward click the bottom button on the right side of the left stick. The same can be said with the axis control on the right stick. I hope to see this aircraft on youtube, as there is a shortage of these flying stabile anywere. good luck.
Apr 22, 2013 | Toys
How do I change passenger side headlamp? It is burned out.
Raise the hood and find the 4 push-in retainers that go along the top of the front grille. Then when you pop off that trim on the headlight you will have a little room to work with. Remove those retainers. Get a flat-bladed screwdriver and a rag, place the rag above or below the trim on the headlight. The rag will protect the headlight from getting scratched when you pry up on the trim with the screwdriver. The trim will pop out towards you. That should give you enough room to remove the headlight. There are two hex-headed screws right on top you can easily see holding the headlight and then one more if you lean in and look down further. Remove the 3 bolts. Now just wiggle and lift up on the headlight and it should come loose. You may need to unplug the side marker bulb wiring to give you more room. Keep the rag wrapped around the trim piece to again avoid scratching the headlamp. Then you will see the big round black plug cover to turn and remove to gain access to the bulb. The bulbs are halogen type bulbs so don't touch them with your hands. The oils from your skin will cause the bulbs to burn out prematurely. Use a clean cloth to handle the bulbs. Reinstall the headlamp the same way you removed it. You will see how it goes back in once you get it out.
Feb 12, 2012 | 2006 Chevrolet Equinox
How to remove the rear seat of a Honda Ridgeline 2010.
1. Pull the plastic panels under the seat bottom straight forward to remove them.
2. Remove the six bolts (14mm) holding the seat and center seatbelt in place.
3. Pop the two small plastic covers at the top and behind the seat using a trim removal tool or screwdriver tip covered in masking tape.
4. Lift the seat straight upward.
5. Remove.
The Service Manual states a 35 ft lb torque and must be re-installed in a certain sequence for the 6 seat anchor bolts (not the seat belt bolts). When putting the rear seat back in install the bolts in this order. (1) center left (2) center right (3) left lower (4) right lower (5) left upper (6) right upper.
Nov 09, 2010 | 2008 Honda Ridgeline
How do i take the radio out of my 98 xk8
Hi
1. Remove the black trim panel holding the cruise control and sport mode buttons from around the shifter. There are 4 clips holding the panel on: upper left, lower left upper right and lower right. Be careful, they break easily. Remove the wires from the buttons.
2. There are two brackets holding the wood panel down, one on each side of the shifter. Remove the two screws holding down each bracket. Be sure you note the orientation of the brackets - it will make reinstallation easier. Lift off the wood trim panel.
3. Under the wood trim you just removed, there are four bolts fastening the console to the car. Remove them.
4. Open the console lid. Remove the two screws fastening the latch strike plate. Again, make note of the positioning of the latch plate for reinstallation
5. Remove any other screws retaining the console compartment. Lift out the compartment liner. Close the console lid.
6. At the rear of the console is a trim cover. It is held by two tension clips. Just pull it off.
7. There are two bolts under the rear trim cover - remove them.
8. Remove the console.
9. Remove the screws holding the radio in the dashboard and pull the radio forward.
10. Remove the antenna wire and wiring harness connectors from the back of the radio.
11. Unbolt the ground wire from the back of the radio.
Reinstall in reverse order.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Jul 31, 2010 | 1997 Jaguar XK8
2002 avalanche po171-po174 code
171 is posting right fuel trim is lean
174 is posting left fuel trim is lean
can be faulty injectors not opening all the way it seems
Jul 10, 2010 | 1999 Chevrolet Silverado 1500
How to replace the programmer timer on a whirlpool washing machine
Hello,if its a top loader, there should be two screws in the rear on both the left and right side that pop the control panel up,if there not in the rear then there should be a trim on the left and right to remove these trims,grab the top of the right trim and pull down and forward they will pop off and the two screws will be on the bottom left and bottom right,lift the control panel and from there you can remove the timer.
Thanks
May 25, 2010 | Washing Machines
My cx3 takes off to the left and i cant stop it . I try trimming it out but still have to hold stick to the right to lift off straightr up, and when it flys it still goes to the left if I dont hold the...
You need to adjust the rotor heads speed, one of them is spinning faster than the other look at page 33 and 34 of the manual that came with your heli, it will tell you how to fix this problem.
Nov 19, 2009 | E-Flite Measuring Tools & Sensors
2000 Honda Odyssey rear wiper motor replacement
You are probably correct in thinking its the wiper motor. You can do this but you will need to remove all the interior trim from the rear hatch first. Get a trim clip removal tool at a parts store...it will work much better than just a flat blade screwdriver. You'll have to remove the trim panels starting in order from the top of the door, then the left rear window side trim, then right rear window side trim, then the grab handle, and finally the main rear hatch trim panel. Once inside, removing and replacing the rear wiper motor is easy. You'll start by lifting the cover on the wiper arm retention nut. Remove this nut to get the wiper arm off, then remove the nut under neath which is the motor shaft mounting nut. Now, back inside to remove the other 3 motor mounting bolts. Don't forget to disconnect the connector for the motor wires. Reverse steps to replace.
Mar 29, 2009 | 2000 Honda Odyssey
Electric Newest Esky RC Helicopter! 4-Channel Esky Dauphin - US Coast Guard Marine Logo
67 people viewed this question
Top Electric Toys Experts
Robert A. Watson
Robert A. Watson
Tom Chichester
 Russ Hill
Russ Hill
Are you an Electric Toy Expert? Answer questions, earn points and help others
