I have a samsung SSC21 web monitor why is there a flat looking battery inside odf the monitor looks like the ones we use inside our watches but bigger
    President:
  • 1,561 Answers
If i may understand what you are saying, it means there is flat battery in your monitor, i suggest you check the manual of the ssc21 to see more information on this.
Take care.
Posted on May 16, 2010
Hello there,\r\nMy samsung 940be flat screen is
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 09, 2010 | Samsung SyncMaster 940BE 19" LCD Monitor
My SyncMaster 710N comes on for only a few seconds then the screen goes blank. if i turn it off ,then right back on, the log on display is there , but then it goes blank again after a couple of seconds , ...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 16, 2010 | Samsung SyncMaster 710N 17 in. Flat Panel...
My daewoo lc1700c will not turn on. No matter how many times how hard how soft how long or how short you hold the button in for nothing comes up nor does the light come on. Im not a fool. The monitor is...
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
May 11, 2010 | Daewoo L700C 17" Flat Panel LCD Monitor
My monitor is switching on and off what is wrong with it ?
Good Luck!
May 11, 2010 | Samsung 206BW Monitor
My LCD Dell Flat Screen Monitor has a blue
Good Luck!
May 12, 2010 | Dell E197FP LCD Monitor
My LCM-22w2 monitor will now rarely start up. It powers up white-screen and won't do anything. Occasionally it powers up ok and works fine.
Good Luck!
May 10, 2010 | Westinghouse 22" Widescreen LCD Flat Panel...
Power light keeps flashing
Please try this monitor on another PC first, if it still does not work, then please read below and look at the pictures to get some ideas of what to look for inside.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Samsung and other monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 08, 2010 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Power light on no picture
haukke, Monitor may have internal power supply failure due to some common parts failure. Use warranty if valid. Visit www.badcaps.net , www.lcdrepair.us , www.lcdparts.net , www.ccl-la.com/badcaps.htm You will also need to find video clips on YOUTUBE to see if DIY repair will work for you. Try "LCD monitor disassembly" or "LCD monitor repair" as search querey on YOUTUBE. After research finished, then let tech's here at fixya know what you will do by doing additional comment to this one. 12fixlouie
Apr 08, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
The samsung monitor ssc21web shows system initialize... the three periods blink
ssc21 web does not work, It was a cameras shut down it says LA and AL why
May 15, 2008 | Samsung 4 Channel Dvr
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
