Question about Samsung SHR-2042 4 Channel Stand Alone Dvr with Cdrw
I have a Samsung SCC21 Monitor why is there a battery inside the Monitor looks like the ones that are normally found inside the P.C.
  • Samsung Master
  • 12,061 Answers
The reason there is a battery insider of this unit is because it has to keep the "Memory" alive, for all the settings etc, a bit like a CMOS battery in a PC, as you so correctly observed. many things these days everything has a CPU, and RAM, and needs a battery to hold all the settings etc.
Posted on May 08, 2010
Samsung turns on then shuts off.red light flashes
how old is this monitor ? if it is an older model , and goes out after you turn it on the capacitors might be weak or blown on the power supply board take a look inside they have a cross top normal flat if puffed up , that cap is blown . factories install 2000 hour long caps but remember the heat kills them soon enough can not put a fan inside EMP will distort screen ..I have repaired so many of power board and have had ordered them from DIGIKEY or others normally .62 cents each
Mar 13, 2016 | Samsung Televison & Video
Battery replacement for G Shock AWG-M100
Sounds like someone has replaced the rechargeable cell with a regular silver oxide of the same dimensions. Normally this doesn't work as the rechargeable cells have a part of the connector welded to them and normal cells don't. If you can source the rechargeable cell they are relatively easy to fit you just have to make sure the connector on the cell goes into the righ tplace on the watch.
May 31, 2014 | Casio awg-m100-1a g-shock awg-m100-1aer
Samsung 2233sw milky looking
try to change the plug adapter if isnt workink you get a problem inside at your monitor and there need it an expert
Dec 15, 2013 | Samsung SyncMaster 2233BW 22" LCD Monitor
My Samsung monitor 940mw won't turn back on
Most common failures in SAMSUNG and other LCD monitors are due to bad caps, that will be the first thing to look for inside. Please see SAMSUNG albums so you will know what to look for inside.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Please post back.
Apr 22, 2010 | Samsung SyncMaster 940MW 19" LCD Monitor
Samsung 226BW screen takes a long time to show anything
This model may have defective capacitors in the power supply. I normally replace the 2 or 4 bulging caps and normal function is restored.
Monitor Mike
Apr 20, 2010 | Samsung 226BW Monitor
Monitor blinking on and off. I had this problem once before with this same monitor. When you went from the screensaver to the desktop it would flicker back and forth between the image and the black. After...
Please read below if you decide to DIY:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Apr 19, 2010 | Samsung 206BW Monitor
My Samsung SyncMaster 2493HM Monitor has trouble starting. When my monitor has been off for a while and I restart it. It makes a little beeping sound and the little light on the right bottom of the screen...
The Samsung 2493HM monitors have an issue with power supply failure. When the board starts failing can be slow to show a picture, have no power at all or have a way or flashing picture. Your monitor sounds like it falls in the slow start category. The power supply board can be easily repaired and the monitor will be just as good as new. Here is a link to a free repair guide that will provide a step by step instructions showing you how to disassemble the unit, check and repair the power board.
http://www.ccl-la.com/blog/index.php/reparing-a-samsung-2493hm-24-lcd-monitor/
I hope this helps, if so please rate my solution.
BuddyMc
Apr 13, 2010 | Samsung SyncMaster 2493HM Monitor
Syncmaster 960bf suddenly blackscreen while playing a game. The computer was still online (I talked with my friends at skype). the graphic board of the computer and the cables of the monitor are working (I...
The problem can be caused by bad caps in the power supply, bad inverter circuits, or bad lamps. Look inside for bad caps with bulging top first and post back what you see inside so we can guide you further, see example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 01, 2010 | Samsung SyncMaster 960BF (White) 19" LCD...
Blinking power button
It could also be because there is a problem with the display controller in the computer. Try to hook up another monitor to this computer and see if it comes up. If it does not work with another monitor, the computer will need servicing. If the display does come up, the Samsung monitor will need service. Good Luck
Jun 20, 2007 | Samsung SyncMaster 170 T 17 in. Flat Panel...
Samsung SHR-2042 4 Channel Stand Alone Dvr with Cdrw Logo
Top Samsung Home Security Experts
Mike
Heilcode
Level 1 Expert
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
