Question about Tappan 30IN ELEC IGNa Oven
The electric ignition does not work.
The stove worked fine when it was disconnected and placed in storage for a year or so. Now, upon reinstallation, the electric ignition does not work.
    President:
  • 1,561 Answers
That one problem with electronics kept for a longer period, one thong or the order will be damage on trying to use back.
Switches, control modules or igniters can go bad on a stove with electronic ignition. Use the following guide to test these devices.
  1. Check that the stove is plugged in, there is power to the outlet, and the circuit breaker hasn’t tripped. Spark ignition stoves need electricity to power the igniters. If your oven light turns on, you have power.
  2. Test if the switch is at fault by turning a functioning burner to the “Light” position while simultaneously turning the one that’s not working to “Light.” If the burner that wasn’t working now comes on, the burner has a bad switch. See Photo 1for instructions on replacing a switch.
  3. One at a time, turn each burner dial to “Light” for three seconds, then off again. Watch the igniters to see if they spark while you’re doing this. (Turning off the kitchen lights may help you see them.) Replace the module if none of the igniters sparks. This is a common problem. if the above troubleshooting did not solve the problem, then,
  4. Call in a pro to test the igniters. Igniters rarely fail, but they are difficult to test.
Take care.
Posted on May 17, 2010
  • jvanco May 17, 2010
    What and where is the Control Module?
  • Sulaimon Jimoh Olayemi May 18, 2010
    Follow the below link to see how to diagnose your electric stove with the diagram and where to locate the control module which is the knob.
    http://www.familyhandyman.com/DIY-Projec...
    Type the above link in your web browser to see the procedures on how to diagnose your electric stove.
    Take care.
Hello, We have a Kenmore gas stove model # 71761. The burners on top work good.The issue is with the oven portion. Oven is working. Flame comes on upon ignition to desired temperature setting and then...
It sounds like yous stove is working fine. Cycles fine. If you think the stove is cycling more often than when new then ck the seal on the door. You may be loosing heat.
Jan 14, 2011 | Ovens
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven quit working . Stove top burners work just
if its an electric start. then the problem is usually the ignitor for oven. if you change this yourself, be carefull they are very fragil. hold on to igniter by its base. slide ignitor into steel case then install. and hook up the 2 wires for ignitor.
May 14, 2010 | Ovens
I have a kenmore electric stove. The top burner
I have the same problem, it turns out that the clock has a sensor in it to turn on the oven. If that sensor is not working, which is found in the clock, the oven does not work. I had a repair guy come out and it will cost 350.00 to repair. My stove is only six years old. It is only two months to the day off warranty. Apparently a power outage can cause the sensor to go. Hope this helps.
May 12, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I am having trouble with the electronic ignition lighting the gas burner in the oven. It makes the clicking sound, but there is no spark 75% of the time. Gas flow is consistant every time. It is a model...
I tried the one thing no repair person or manual ever mentioned: take out the bottom drawer, which is used for storage, and check the wire connection under the stove that connects to the ignition wire. If it is loose, disconnect at the spade connector, clean, and re-attach. Now it works fine.
Dec 10, 2009 | Kenmore Ovens
I have a kenmore gas range with electric ignitors. My question is that my stove top doesnt ignite but lets gas by and I can use a lighter to lite them. However my oven doesn't do anything...no gas no...
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Nov 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Electronic ignition system failed
electric ignition. Electric goes to ignition button, then to a spark generator, where upon a spark is produced. If any part of this sustem is wet, then it is shorted to earth. No spark.
Feb 11, 2009 | Bosch HBN 131560B / 131520 hot-air...
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
Faulty bake or broil element
The solution to this problem depends on whether the oven is electric or gas. Electric oven. If your electric oven's bake or broil element isn't working properly, either it isn't receiving electric power or the element or the oven control may need to be replaced. In many cases, the wiring to the elements can be burnt or broken. 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Call an appliance repairperson or replace the element yourself as follows. 4) Unplug the oven and let any hot parts cool. 5) Unscrew the mounting screws that secure the element bracket to the oven and pull out the element far enough to access its terminals. Note which wires are attached to each of the terminals, then disconnect the wires (pull off the wire clips or unscrew the wires). 6) Take the element to a parts dealer, along with your oven's model and serial number, and buy a replacement (preferably the manufacturer's suggested replacement part). 7) Reverse the process to reinstall. Gas oven. When a gas oven doesn't get hot, it generally means that it isn't receiving gas, the gas valve isn't distributing gas to the oven burner, or the ignition system -- either an electronic ignition or pilot light -- isn't working properly. A common problem with ovens that have a pilot light is that the pilot light has gone out. NOTE: Gas ranges younger than 10 years old have a sophisticated fault code system that governs their ignition. Always call an approved warranty service provider to handle problems with these ranges. Here's how to troubleshoot your range: 1) Be sure the controls are set on the proper setting. 2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit. 3) Check the gas valve to be sure the gas supply is turned on (also make sure the house's main gas valve is turned on). 4) On a stove with a pilot light, make sure the pilot light is burning. If it isn't, re-light as discussed HERE, or in your owner's manual. 5) Adjust the pilot flame (older stoves only). 6) Turn off the gas and unplug the stove (or turn off its circuit at the electrical panel). 7) Clean out the oven burner ports, using a stiff wire. 8) Plug in the stove (or turn on its circuit) and turn the gas back on. Re-light the pilot (if it has one). 9) If the oven still doesn't work, call an appliance repairperson.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Tappan 30IN ELEC IGNa Oven Logo
80 people viewed this question
Top Tappan Ovens Experts
Dan Webster
Dan Webster
ashburton
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Tappan Oven Expert? Answer questions, earn points and help others
