Does not switch on .power lead is ok.green light does not illuminate
  • 11,361 Answers
LCD or CRT? Make and Model will help.
LCD problems:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 08, 2010
My 95 nissan pickup has light issues. I can't seem to figure out what causing the night not to work I have tested the fuse block and all leads into the illumination control switch but don't know where
According to the wiring diagram, you should have two 15amp fuses powering the headlight switch. One wire is red and the other is red white.
Power out of the switch is pink blue for the tail lights, and red with green, blue, black, and yellow for each headlight circuit.
Diagram courtesy of autozone.com
Feb 28, 2013 | Cars & Trucks
I run my finger over the power button but it wont turn on.
You don't need to run your finger across it, with the red light illuminated, press and hold the power button for 3 seconds you should hear a beep then a blue/green light should illuminated. If you see no light ensue the MAIN power switch on the back is switched on.
Rylan
Dec 16, 2010 | Sony Playstation 3 (PS3) Console
Wiring diagrams for clarion dxz535 car stereo
Here's how it goes:
Speaker wires:
grey=right front pos.
grey/black=right front neg.
white=left front pos.
white/black=left front neg.
violet=right rear pos.
violet/black=right rear neg.
green=left rear pos.
green/black=left rear neg.
red=12 volt switched power source
yellow=12 volt constant power source (direct to battery)
black=chassis ground
orange/white=illumination (switched source,not to head light switch)
blue/white=amp turn on lead (to remote turn on lead of amp)
blue=auto antenna (switched power source)
brown=phone mute lead (to cell phone mute lead)
RCA connector leads:
grey lead:
red=right front
white=left front
black lead:
red=right rear/right rear subwoofer
white=left rear/left rear subwoofer
(connect to external amp)
red lead:
red=right aux input
white=left aux input
(connect to external unit)
green lead:
red=right dual zone output
white=left dual zone output
(connect to wireless head phones)
That should be all there is. on the yellow that goes direct to the battery you need to use an inline fuse holder with 30 amp fuse.
Sep 26, 2010 | Car Audio & Video
Color code radio wireing 2001 malibu
Battery Orange +
Accessory Yellow + Note this vehicle does not have a dedicated accessory turn on wire . use a lead from the ignition switch or fuse panel to supply accessory voltage .
Ground black -
Illumination Gray +
Dimmer Brown +
Lf Speaker Tan +
Lf Speaker - gray
Rf Speaker + Light Green
Rf Speaker - Dark Green
Lr Speaker + Brown
LR Speaker - Yellow
rr speaker + Dark Blue
rr speaker - light blue
Aug 28, 2009 | Car Audio & Video
How does the illuminated light work inside a Leviton light switch? Since there is no neutral (white) wire hooked up to the switch itself? Does the switch illumination light have its current flow into the...
The neon lamp inside of the switch draws very little current (milli, or mico amps) so there is no significant current flowing to ground.
As for your real question, there are several various types of 3-way pilot switches:
Load on: Pilot on
Load off: Pilot on
Some 3-way pilot switches have an external lead which allows them to be configured either way.
If both of your switches are the same type and are wired correctly, they should work the same.
If you suspect that one is defective, try swapping them.
Aug 03, 2009 | Electrical Supplies
I need the wiring diagram for my new Clarion dxz385usb
Brown wire-Phone mute Yellow 3A-Bus power lead Yellow 15A-Memory backup lead Red-Power lead Blue/White-Amp lead Black-Ground Orange/White-Illumination lead Blue-Auto antennae SPEAKERS(black strip is -ive) gray+gray/black-front right white+white/black-front left purple+purple/black-rear right green+green/black-rear left
Jul 02, 2009 | Clarion DXZ385USB Car CD/ MP3 Player
Schwinn S1000 illuminates both green & red light, but no power
I am having the same problem. By all indications it looks like the motor controller is the problem. Everything else works OK. I am pulling the controller tomorrow and replacing. If that doesn't work I am junking it.
May 12, 2009 | Mongoose Currie Schwinn Gt Izip Scooters
Computers & Internet Logo
201 people viewed this question
David Payne
David Payne
