Question about Sony KP-46WT510 46" Rear Projection HDTV
Sony kp-46wt510 6 blinks, does not come on
    Genius:
  • 3,422 Answers
HI,
You will need a technician to fix this problem.The repair may cost anything between $150-$350 or may be more.
Sony Blinking Codes
Many of the later model Sony TV's have a built in Self- Diagnosis function. If the timer/standby indicator is blinking, this could be an indication of the problem with the unit. The diagnostic blinking will occur automatically with no action required by you to engage it.The timing of the blinking you see would be as follows: two to eight blinks (depending on the fault) about a third of a second apart, then pauses for 3 seconds, then the two to eight blinks about a third of a second apart again. Here is a list of the problems that might have occurred indicated by the number of blinks. The words in parentheses are those which you will see for
each of these faults on a diagnosis screen described later in this article. Unit is dead and there are no blinks---Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open)
Continuous Blink Once A Second, No Pausing As Discussed Above---
No reply from the jungle IC301 (data bus is busy, shorted to ground or held high), IK video path is defective.
ONE Blink--- not used for the self-diagnosis
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking, try turning up screen slightly.
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.Intermittent problems ? This is a great feature. You can also bring up these fault codes ON-SCREEN to see a list of the problem numbers with the abbreviation of the problem and the number of times this problem has occurred. This is slightly different than entering the service mode. To see the diagnostic screen, Press the following buttons:
Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up a screen with a list of the problems and number of times they have occurred.
Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC.
We have repeated them in parentheses in the text for the "Blinks" described above so you can correlate between the diagnostic screen and the blink codes.
So, now that you know about these self-diagnostics, how do you use them?
Say that you have a set with a black screen. You see that the LED is blinking 4 times....This would tell you that you have no vertical and that is why the video is muted. If it was blinking 6 times, you would know that you have a horizontal fault.It's not a sure cure, but it's a little better than a poke in the eye with a sharp stick.
IMPORTANT: after you repair the unit, PLEASE clear the values on this diagnostic screen. These codes do not reset themselves after the fault is corrected, so if you don't clear them, you'll be seeing "old" fault codes the next time you enter this screen.
Clearing is done by going into the service mode ( display, channel, 5, volume plus, then power ) then press 8 and Enter, which of course returns everything to the factory preset condition.
Goodluck,
Please don't forget to rate the solution.
Posted on Mar 27, 2008
    Sergeant:
  • 290 Answers
According to this article, 6 blinks means "No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206". Depending on your confidence in your abilities to repair it yourself, you might want to contact an authorized service center.
3 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: SONY KP-57HW40 TUNS OFF AND STANDBY LIGHT BLINKS 6 TIMES
6 blinks is usually associated with failure of the horizontal deflection amplifier - which shuts down the high voltage system as well.
The repair requires testing to determine the exact parts that have failed. There are, for example, a few hundred parts and a section of the Jungle IC chip involved. So, repairs could require something as simple as replacing some inexpensive passive components OR as complicated as replacing the jungle chip (very expensive).
most of the time it's the horz. transformer and transistor.
Posted on Dec 20, 2007
  • 68 Answers
SOURCE: stand by on my sony kp-53xbr tv is blinking steady
That can be caused by lots of different things going wrong. You will not be able to repair that yourself, and will need to have a technician look at that kind of a problem.
Posted on Dec 04, 2009
SONY KP-61HS20 DOESN'T COME ON JUST BLINK 6 TIMES PAUSE AND 6 TIMES AGAIN
Sis blinks of standby light denotes No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. If you wish to get more details about blinking codes to Sony PTV, check this link.
Mar 03, 2013 | Sony KP-57HW40 57" Rear Projection...
Kp-51ws520 blinks 4 time
here is a link I found when I Googled kp51ws520 4 blinks ---it might help you and also the plus and minus 15 volts they are talking about also goes to the convergence circuit I think:
http://www.techlore.com/forum/thread/24384/Sony-KP-51WS520-51WS520-4-blinks/
Mar 23, 2012 | Sony KP-51WS520 51" Rear Projection...
Stand by on my sony kp-53xbr tv is blinking steady
Dec 04, 2009 | Sony KP-53XBR45 53" Rear Projection...
Sony KP-65XBR10W had blinking light
In your google toolbar type in Understanding Sony Blinking codes it will then take you to website that tells you what the blinks mean .
Sep 24, 2009 | Sony KP-65XBR10W 65" Rear Projection...
My KP-51WS520 blinks 10 times
Type in Sony Blinking codes on Google you will find all blinking codes and what they mean.
Aug 06, 2009 | Sony KP-51WS520 51" Rear Projection...
Sony KP-46WT520 Standby Blinks 10 Times
High voltage in TV got problem and thats why TV gives 10 time blink error code.
Qualified TV tech will fix it as its bit complicated fix.
Apr 15, 2009 | Sony KP-46WT520 46" Rear Projection...
Sony KP-57WS520 57 in. Rear Projection TV standby light blinks
Please mention how many times standby light blinks on your KP-57WS520
There would be bit long pause between blinks so count the blinks and let me know to help you.
Dec 05, 2008 | Sony KP-57WS520 57" Rear Projection...
6 bliks on sony kp-46wt510
KP46WT510 Shutdown 6 Blinks. 6 Blinks = Low B+ OCP/OVP
SOLUTION: Replaced Flyback transformer. It had no rings on the ringer test.
HQ
Comments: Any load on the B+ line can cause 6 Blinks.
Example: If the 200v line is loaded down will cause a drop in B+ due to bright picture current demand.
Click Here! to download the Sony Kp-46wt510 full service manual.
Nov 11, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-FX432M91 TV 10 blinks
my sony kp-fx432m91 has a 10 blinks problem. it has no pictures but has sound that goes off after 5 seconds please advice on what to do.
my email address is drbonnyb@yahoo.com
Oct 31, 2007 | Sony KP-FX532M91 TV
Sony KP-46WT510 46" Rear Projection HDTV Logo
156 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
