Question about Nintendo Game Boy Advance Console
Which controller has games - Nintendo Game Boy Advance Console
  • 106 Answers
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
asd-81
Posted on Jul 23, 2009
    Problem Solver:
  • 71 Answers
Dude no controllers hve games stored into them.
Posted on Mar 29, 2008
SOURCE:
I can't get any game to work. We used to be able to wiggle the game or take it out and put it into the console on a different angle, but now it won;t work at all. The power light still comes on on the...
Note: It is possible that the problem you have may be game play related. For example, if you cannot defeat a particular enemy, or are missing an item you need to complete an area, the problem is likely game play related and there is nothing wrong with your game. Please check our game play help for assistance.
  1. Insert the Game Pak into the system. The Game Pak label should be facing the front of the Nintendo 64.
  2. Make sure the Game Pak firmly clicks down into place.
  3. Remove all accessories (with the exception of the N64 Expansion Pak) to see if the Game Pak works correctly without the accessory. If the game does work correctly once the accessory is removed, then the game pak and the accessory may not be compatible. Check the game pak instruction manual.
  4. Check the instruction manual for the game to see if it requires any special accessories, such as the Expansion Pak, to operate.
  5. Check the list of specific game issues to see if there are any known problems for the game you are playing.
Due to the age of the system, we no longer offer factory repairs directly from Nintendo. Please click here to find out what options are available for repair or replacement of your product.
  • Controller Error Messages (e.g. No Controller Detected)
    1. Make sure you are using all licensed accessories with your system. Make sure both the controller is licensed and any accessories you are using with the controller (Rumble Pak, Controller Pak) are licensed as well. Unlicensed products may not be fully compatible with our systems.
    2. Slide the Power Switch on the control deck to the OFF position and unplug the controller. Plug the controller back in, making sure the controller-plug is firmly inserted into socket one (on the left front ofthe control deck). Slide the power switch on the control deck to the ON position.
    3. If possible, try another controller in the left-hand port. If you have a second controller, repeat Steps 1 through 3. If the trouble disappears, the first controller may need to be replaced. For information on locating replacements for older products, please click here.
  • Character Won't Move or Moves on its Own
    1. The most common cause of this problem is when the control stick on the controller is not in the neutral position when the N64 system is turned on. The neutral position is when the control stick is centered, as it is when you hold the controller while not touching the control stick. Recalibrate the Controller by using one of the following methods:
      • Turn the power off on the system. Make sure the control stick on the controller is in the neutral (center) position, and slide the power switch to the ON position. Be sure not to touch the control stick for the first few seconds.
      • During game play you can press the L+R+START simultaneously while the control stick on the controller is in a neutral (center) position.
    2. Consult the Game Pak manual for information on the primary directional control for the game. Some game paks use the control pad rather than the control stick for character movement.
    3. Try cleaning the controller (See Below).
    4. If possible, try another controller in the left-hand port. If you have a second Controller, repeat Steps 1 through 3. If the trouble disappears, the first controller may need to be replaced. For information on locating replacements for older products, please click here..
  • N64 Sticky Buttons or Control Stick, or other controller problems Try the following cleaning procedures:
    1. Unplug the controller from the control deck.
    2. Get a clean toothbrush (no toothpaste) and a cup of warm tap water (not too hot). Do NOT pour or submerge the controller in any type of liquid.
    3. Slightly dip the toothbrush in the water (the toothbrush should not be dripping wet) and scrub the area of the controller around the buttons and control stick.
    4. Work the bristles down around the sides of the buttons and the control stick.
    5. After cleaning the controller, dry it off with a paper towel.
    6. Let the controller air dry for at least a couple of hours.
    7. Test the controller for proper response.
    If possible, try another controller in the left-hand port. If you have a second controller, repeat Steps 1 through 7. If the trouble disappears, the first controller may need to be replaced. For information on locating replacements for older products, please click here.
Transfer Pak
  1. Verify that only licensed accessories are being used with the system. Unlicensed products are not fully compatible with Nintendo systems, and may not work correctly.
  2. Check the game pak manual or packaging to verify that the game is designed to be used with the N64 Transfer Pak.
  3. Make sure the Game Boy game pak works properly in a Game Boy system. It may be a problem with the Game Boy game pak and not the Transfer Pak.
  4. Verify that the game paks are inserted in both the control deck and the N64 Transfer Pak. If they are not, insert them and then turn the control deck power off and back on again.
  5. Verify that the controller is plugged into the proper controller socket on the front of the control deck. If it is not, secure it and then press reset on your control deck.
  6. Remove and re-insert the N64 Transfer Pak, making sure the pak is fully inserted into the bottom of the controller. If it is not, secure it and then press reset on the control deck.
  7. If possible, try another controller. If the Transfer Pak works in another controller, it may be the controller that is having a problem. Check out controller troubleshooting (click here).
If the issue persists, the Transfer Pak may need to be replaced. For information on locating replacements for older products, please click here.
Controller Pak
  • Deleting Saved Information From Controller Paks Depending on the game you own, there are a couple of different ways to delete the saved information on a Controller Pak.
    1. While turning on the Control Deck, hold down the START button on Controller #1. If the programmers utilized this feature, a Controller Pak menu should appear. This menu will allow you to view and delete the contents of the Controller Pak.
    2. If the first option doesn't work, then the game pak will have a feature that can only be accessed from a game menu. For example, in Wayne Gretzky's 3D Hockey, you delete saved info from the Options screen.
    To find out the specifics of how the Controller Pak works with a particular game, check the game's instruction manual.
Expansion Pak
  • For assistance with installing the Expansion Pak, click here.
Jan 19, 2011 | Nintendo 64 Console
Game controller
Uninstall and re-install the latest drivers which can be found here..
Mar 21, 2008 | Logitech Dual Action for Pc (963292-0403:)...
Why on some games does my wireless controller switch itself off whilst im playing, and on other games i have no problems with it at all
in some games the controls are different so use this method to solve the problem go to control panel then game controller then add then ur remote model is shown there add that and in some games if again this remote sitched off then see the settings of that game and check the control points if problem still continue then mail me at [email protected]
bye friend
Mar 26, 2010 | Microsoft Xbox 360 Controller
My game controller is not working on pc for call of duty modern warfare 2. Is this game compatable with a game controller?
On your controller box there should be a windows logo on it, for what it design for. For example, there should be a logo for windows xp or whatever it was design for.
Dec 21, 2009 | Logitech Precision USB Gamepad PC Game...
Im haveing problems connecting my wireless pc game controller
wireles? that is the problem-if your PC doesn't have bluethooth it can't read that kinda hardware
Oct 04, 2009 | Logitech Dual Action for Pc (963292-0403:)...
To play Game Cube games in the wii
You need game cube controlers to play the game cube games on the wii. Hope this Helps you.
Please rate FixYa!
Mar 29, 2009 | Nintendo Wii Console
Need help please
Depends what game you are playing but if you have the logitech profiler loaded then you can map commands to the various control buttons and joysticks - most games allow you to map controls anyway so it just a case of editing the controls settings in the game and pressing or moving the control you want for that action.
Jun 19, 2008 | Logitech Dual Action for Pc (963292-0403:)...
Game pad wont work
Some game controllers may not function in a particular game. This can be due to a number of causes including defective hardware, missing system components, incorrect game settings, or lack of game controller support within the game itself. Solution:
If your Logitech gaming device is not working correctly in a specific game:
  1. Verify the game supports your gaming device. The game's documentation or game manufacturer's web site should have this information.
If the game is supported:
  1. Click the Start Menu, highlight Settings, and select Control Panel.
  2. Double click the Game Controllers icon.
  3. After Game Controllers Control Panel opens, select the Logitech gaming device you wish to test and click Properties.
  4. Click Test.
  5. In the Test screen, verify the axes and buttons are operating correctly.
If the Logitech gaming device does not function correctly in the TEST screen or is not available as a selection in Game Controllers, please see Knowledge Base article 227 for further assistance.
If the Logitech gaming device is functioning correctly in the test screen, try updating to the latest version of DirectX. Windows 98/2000/ME/XP users should download the DirectX Runtime installer from here. Vista users should use the built in Microsoft Update utility to get the latest version. If your gaming device still doesn't work in your game after updating DirectX, please refer the game’s documentation or developer's support page for information on configuring a controller.
Please see the following articles as well on how to use the Game Pofiler for games:
Link 1
Link 2
Link 3
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
May 03, 2008 | Logitech Dual Action for Pc (963292-0403:)...
Can we play gamecubegames inside the wii console, if so how?
You can do both. With internet you can download Nintendo 64 games on the wii shop channel. For game cube games enter the controller in slot one, enter the game and it's like you don't have a wii!
Note: due to the fact the the wii remote does not have enough buttons ALL N-64 games need a gamecube controller or a classical controller. Game Cube games are not compatible with classical controllers.
Apr 02, 2008 | Nintendo Wii Console
Nintendo Game Boy Advance Console Logo
27 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
