Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Where is the model and serial number on the bottom freezer refrigeraters
  • 1,284 Answers
Hi, you can locate the model and serial number of your fridge by looking at
1. Inside the refrigerator or freezer, on the left or right side wall.
2. On the face frame of the refrigerator body.
3. Behind the lower crisper drawer.
4. Behind the lower toe kick-plate.
Take care
Posted on May 08, 2010
Serial #
What problem are you having? All you need is the model number.
Jul 05, 2013 | GE Monogram ZICS360NRRH C... Bottom...
My refrigerater is still iceing up ,in the freezer part,causeing the refrigerater too be warm ,and i have already changed the heater and the thermostat.
if you have a full freezer and a not so full fridge a brand new one will do that but check your door seals as well
Apr 23, 2012 | Refrigerators
I have a kenmore elite trio fridge with bottom freezer. recently, the ice maker stopped producing ice yet the water is still being dispensed from the refrigerater. wondering if there might be a quick fix...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Aug 09, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Brought the GE WR55X10942 Refrigerator Main Control Board, and I am getting ready to install it, it saids to eliminate thermistor wire in pin 2 of J1 connector for any encoder models that starts with a...
Yes you will need to cut the wire the directions states all bottom freezer models and models with certain serial numbers... But you will not need to do other modifications specifically for bottom freezer only models.
Jul 15, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My refrigerater is not cold. but the freezer is working fine. what can be wrong
You have a defrost problem Need model number to see who made your frig as Kenmore makes nothing.
Nov 26, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
How do I install the toe grill on an elctrolus french door refrigerater model EI23BC361
it just pops on the clips and off i use a putty knife it help it move they are tight . mm
Aug 18, 2010 | Electrolux EI23BC56I (226 cu ft) Bottom...
Refrigerater is not cooling
The refrigerator gets air from the freezer. Look in the freezer for frost. If you have frost in the back or bottom the you have a defrost problem. Could be a timer or heater that is bad. If no frost do you hear a fan? You should have a evaporator fan running. Maybe thats out and it not circulating air for the refrigerator. You can check this out.
Hope it helps
Aug 17, 2009 | Whirlpool Refrigerators
Ice cream and bread don't freeze, food in frig DOES freeze
Not fixed but I do not want to spend MORE money to find out what's wrong with this AMANA piece of ****. Apparently, from research on the net, the compressor or motor is not strong enough in this unit to actually do the job...but if anyone has any suggestions, I'm happy to hear them...
May 16, 2009 | Amana ATB1832AR Top Freezer Refrigerator
MY Maytag Wide by Side freezes in the produce drawers.
When a unit freezes in the lower drawers this is usually due to a thermistor which is not functioning properly. If you can provide your model number I can try to locate your schematic to your unit showing the thermistor that you would replace to alleviate this issue. I will await your reply as to the complete model number of your unit.
p.s if you had ice up the top of the unit as well then you would look at the damper door otherwise known as the diffuser door in some units or the control for the door as the problem area in your unit.
Thank you,
Rick
Jan 21, 2009 | Maytag 26 cu. ft. Wide-By-Side...
My freezer is working but my frige is not cooling
wrong model # ,defrost problem. remove freezer panel, check heater, check limit switch while still covered in ice, if both ohm infinity, replace defrost timer.
Sep 15, 2008 | Haier HTP18GAA Top Freezer Refrigerator
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
44 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
