Question about Venturer PDV880 Portable DVD Player
If the battery needs replacing will the unit still work with the charger?
  • Venturer Master
  • 6,993 Answers
the answer is yes. The battery is there in case there no charger, but since there is charger, the player will definitely work even without the battery.
Good luck.
Posted on May 08, 2010
Xantrex XPower PowerPack 300 will not charge even after replacing both battery and adapter. What else can I try?
Either charger has an issue or new battery is boogus. Check charger output for specs. Subject battery to a few discharge/charge cycles. If charger is definitely good and battery will not charge fully after a few cycles then you have confirmed that new battery is bogus.
Sep 06, 2017 | AMP Computers & Internet
My battery charger just does not work anymore! I have the two batteries and charger that were purchased as a package with my drill. I bought many other pieces to add to my Ryobi family.
Receipt will do nothing for you if it is out of warranty. Normal warranty is for three years.
Write to the company regarding your situation - see if your unit has a serial number that can give indication of age of unit. Perhaps they will replace the charger for you.
Make sure that the charger cord/connections are good and that unit is receiving power from wall.
Sep 17, 2016 | Ryobi Two 18V Lithium-Ion Batteries +...
My RCA tablet won't turn on and will not charge, what can I do?
If battery is depleted, then no, it will not turn on.
If battery charger is dead, phone won't charge or turn on.
If battery charger cable is broken, tablet won't charge or turn on.
You need to ensure you have a good working charger, and a good cable. Only a known good charger and a known good cable can charge the unit. Borrow or invest in a new charger and cable (they're cheap on eBay).
Only once you know the charger and cable are good can you determine that they are not the problem.
Depending on how old the unit is, it's possible the battery can no longer hold a charge and needs to be replaced. You won't know that though until you first determine the charger and cable you're using are working properly and providing a good charge.
May 07, 2015 | RCA RCT6691W3 9" 8 GB Wi-Fi Black Tablet...
I have a PV-IQ404 Panasonic Palmcorder that the power pack has been lost from. Can this be replaced?
By power pack do you mean the actual battery or the charger unit that plugs into the wall to charge or power your Palmcorder? Either way, bot are available on Ebay as universal units and you should make sure the charger or battery pack is for or a 6 volt capacity. Many chargers for these Palmcorders are labeled as VHS-C / 8MM, that should work with your camera. Universal battery packs are made reversable, meaning that you can flip the battery to accomodate several other camcorder models. I've replaced my batteries and charger for my Panasonic Palmcorder from Ebay.
Dec 06, 2014 | Energizer Panasonic Pv-iq404a Camcorder...
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
Sep 21, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover linx battery, charger or unit itself?
As a former owner of one, my suggestion is that it be discarded rather than repaired.
Jan 01, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
New charger
it may not be the charger on most occations have the battery checked out at your nearest cellphone tech. to find out if you need a replacment battery
Jun 15, 2009 | Duracell AAA NiMH Battery Charger with 4...
Charge light orang on for a second and turn off unit not charged.
This kind of problem is usually caused by either of this 3 things: Either the problem is the battery not being able to charge anymore(bettery would need to be replaced), or the charger does not give any charge to the batter(recommend try another charger), or last would be the console charger port( would need to replace console, or repair charger por,not recommended)
Mar 10, 2009 | Nintendo DS Console
Sony DCR-VX1000E batteries
Li-Ion batteries cannot be charged efficiently with power supplies or NiCad chargers, they need a pulse charger dedicated to Li-Ion batteries. Also, there is a danger in charging with other sources as Li-Ion batts. will catch fire or explode if not charged properly. Please get a charger that is made for those batteries
Jun 19, 2008 | Sony Handycam CCD-TRV37 Camcorder
Venturer PDV880 Portable DVD Player Logo
224 people viewed this question
Top Venturer Televison & Video Experts
john milligan
Are you a Venturer Televison and Video Expert? Answer questions, earn points and help others
