Question about Mitsubishi WD-52631 52" Projection HDTV
Outer screen scratch
I recently changed residences and in the moving process someone scratched the outer protective screen on my Mitsubishi WD-52631 52" DLP TV. Does anyone know how or where I might get a replacement. The local TV Repair shop (authorized Mitsubishi repair) said that Mitsubishi had discontinued the replacement part. That seems wacko to me since the TV is less than a year old. THe part number they gave me for the screen is 491P199030. Any ideas on how I can get a replacement part, or failing that, if there is any way to "polish out" a scratch?
  • 1 more comment
  • EmeryB Mar 27, 2008
    zzedly,
    You certainly seem to have found the part number at Sears. What's worrisome to me is that the Sears part number is Part# KITSCRNLEN65, which sounds like a 65" screen description. I am starting to wonder if the repair shop looked up the wrong part number.
    Clearly, the Mitsubishi site doesn't list a replacement.
    By the way, if I hit the accept button, do I have to pay again if I keep checking for answers or do the answers just stop?
  • EmeryB Mar 28, 2008
    Thanks,
    After i tried to get to the service technician folks to ask them to verify only to find that they were gone for the weekend, I went to servicedocs.com and downloaded the parts/repair manual. In short, the experts at the TV shop blew it. The part number they gave me was indeed for a 65" screen not a 52" screen. The right part number according to the manual is 491P199050 NOT 491P199030. Unfortunately, when I use the correct part number at Sears, it reports DISCONTINUED. Given the fact that this TV is only 10 months old, I sent a searing demand for a solution to Mitsubishi. It is tragically irresponsible to discontinue repair parts for high-ticket items less than a year out.
    Resolved.
    After much back and forth with Mitsubishi and the repair shop, I got a message from the Mitsubishi Service department.
    It says, "The part number for that screen is kit-screen/lens 52. It comes as a set with the rear screen attached
    MDEA Service (MF)"
    I thought I would share this response as it may be helpful to you in the future when giving advice. Apparently, Mitsubishi no longer sells just the lenticular screen but does sell a unit that is the screen and freznel lens already assembled. You may also wish to share this with your colleagues. :-) Have a nice weekend. With this information, the service technician was able to order the correct part and I will have the set fixed by next Thursday.
    Sergeant:
  • 300 Answers
This place says they carry it (not stocked) for $478.
Also, SearsPartsDirect.com seems to say they have them in stock for $250.
Posted on Mar 27, 2008
  • Tygh Duval
    Tygh Duval Mar 28, 2008
    You may be right. I don't know that I'd feel comfortable ordering it from Sears Parts without confirming that it's made for your 52". Your best bet may be to confirm the part number with the repair shop, then search the Sears Parts Direct website for that part number. Having the p/n of the screen will be the key to finding anywhere (online or not). I wish I could help more!
    As for the premium answer, if you accept it, it will show as "solved", but I believe people (you and experts) can still write comments. If you don't accept any solution (or make any comments, I'm not sure which) for 7 days, the system automatically assumes it's solved.
  • Tygh Duval
    To put it lightly, that sucks. I wholeheartedly agree that a manufacturer should support their product for decent amount of time (3 years?) before discontinuing parts. Unless the screen has been discontinued because a newer/better/upgraded screen (with a different p/n) has taken it's place, your options may be limited to scouring the world for a broken TV of the same model that you can salvage the screen from.
    P.S. I doubt the scratch would covered under the TV's 1 year warranty, but what if you did have a warranty claim with the screen? Mitsubishi would have to do something, if they can't replace the screen, wouldn't they? Replace the whole darn thing?
    Genius:
  • 3,422 Answers
You can try for the parts from HERE or from HERE
Goodluck,
Please don't forget to rate the solution.
  • Priya darshan Mar 27, 2008
    The best solution would be to get it repaired by calling the mitsubishi people to your home.You can also clear your other doubts by calling them on the below no.
    Main support number: 800-332-2119
    Support FAX : (714) 229-3854
    Email support: CustomerCare@meus.mea.com
  • Priya darshan Mar 28, 2008
    Hi again,
    Good to hear that your problem will be solved by next thursday.
    Thank you for using fixya.
    Have a great weekend!!
  • Mitsubishi Master
  • 13,433 Answers
Mitsubishi is currently offering the following parts
Model Number Model Description Part Number Part Description Price Available WD-52631 52" DLP TV I/B WD52631 OWNERS GUIDE $15.00 YES WD-52631 52" DLP TV I/QR WD52631 QUICK/REF WD52631/57731/65731 'G' $3.50 YES WD-52631 52" DLP TV 915P049010 LAMP (150W) (V33/V33Y/V33+) 'G' $249.00 YES WD-52631 52" DLP TV 290P137010 REMOTE 'G' $33.10 YES
  • 4 more comments
  • Ekse Mar 27, 2008
    That got a little hard to read..
    look for 52631
    http://www.mitsuparts.com/searchpage.cfm...
    I supose its possible, il look into it right now.
  • Ekse Mar 27, 2008
    that link got messed up also
    so try this http://www.mitsuparts.com/ instead.
  • Ekse Mar 27, 2008
    It would be nearly impossible to properly polish out the scratch and not
    have any visible damage. When polishing, you will also be removing any
    anti-reflective coatings.
    There are polishing compounds that will work with Plexiglas, but on most
    plastics, they may cause hazing or cloudiness. For an optical surface as
    like on a TV screen, this is not practical to polish out. In any case, you
    will end up having to replace the screen to fix it properly.
  • Ekse Mar 27, 2008
    So I see only two solutions
    1. replace
    2. live with it
  • Ekse Mar 27, 2008
    Heres what I found from coolguys links
    http://www.partstore.com/Model/Mitsubish...
    and noting from the other site.
  • Ekse Mar 27, 2008
    I just have to add,
    500 USD for a scratch is too much!!
The screen shield of my mitsubishi HD 1080 diamond projection tv is scratched and shows rainbow color dots in some places. What can I do? Can I fix it? Replace it?
The outer screen on most models is clear and called a protective screen and prevents glare---if it has that it has 2 more screens behind it.
Getting at the outer on is not so easy---the entire frame for the screens has to be removed, the inner screens removed to get at the outer screen to remove it (if 3 screens you can do without the outer one except if it got scratched before--next will be the next screen behind it.
Check with mitsubishi to see if the screen that is damaged is available or not.
Oct 29, 2012 | Mitsubishi Televison & Video
Mitsubishi WD-52631 top 3 inches wavy.
Best,Genuine and Simple Online business which Really Makes you a Millionaire ! visit :- http://bit.ly/xM9lTH
Feb 20, 2012 | Mitsubishi Diamond WD-65831 65" Projection...
Where can I get a replacement plactic screen cover
This set has 3 screens---the outer one is really only for glare--clear plexigalss--no longer available from Sony.
Sony 4-070-602-01
SCREEN, FRESNEL Sony 4-064-343-11
SCREEN, LENTICULAR Sony 4-058-894-11
SCREEN, PROTECTION (CONTRAST)Outer one is (Contrast) the other two inner ones are showing as available and about 180 each.
You would have to either have someone dismantle or do it yourself---most of these sets you have to remove all three screens from the rear of the set---then remove the outer contrast one if it is scratched or cracked--
If you get it out and measure it: It is possible you may be able to find a company who can cut you a plexi-glass piece to replace it with--lots of work to do this and you have to use extreme care when you remove the two inner screens--easy to damage them---Usually the inner two are taped along all the edges to keep dust etc from getting between them and the front one is a short distance forward of them.
The front protective screen is really only there for glare and to protect the inner screens from damage---I have seen people who had a cracked outer one just dismantle and remove that one---put the others back and use the set that way---have to be careful as the inner screens are easy to scratch or damage with the outer one removed.
Also---I have seen several where someone removed the outer one and got a piece of plexi glass big enough to put on the outside of the front of the set---secured all around the edges with velcro--does not look as good as the original but prevents glare and protects the inner screens.
If this told you something you did not know or helped you rate this solution as I do this here for free.
SD TECH
Jan 03, 2010 | Sony KP-53V80 53" Rear Projection...
Scratch
hello, if there is a scratch on your reflective outer glass panel screen, it can be replaced if you are handy with tools or diy i happen to have the screen removal manual for this tv model th42pz700u you dont have to dissasemble the tv just the outer front housing remove the back panel and theres some screws that hold the front casing on those come of and the front refelctive glass can be removed without any trouble or dissasembly of the internals just the front casing
you may need to find a selling as is plasma tv with a broken internal screen usually they are this way that outer screen dosent break easily so unless you want to pay 489 for this reflective glass part i would try and find a 'for parts or repair 42 inch pany' they will fit if they are the same size make sure the outer screen is not broken or scratched. hope this help
Nov 29, 2008 | Panasonic TH-42PZ700U 42 in. Plasma...
My screen on my lg kg800 is scratched how can i replace it with a new one
is the actual screen inside scratched or is the outer phone housing screen cover scratched? There is a difference. The actual LCD screen is inside the phone housing and is protected by the phones housing. If the actual LCD screen somehow was scratched it can be replaced very easily and usually inexpensively. Try Ebay for the LCD. If the phones outer clear housing is scratched you can also replace the housing either by purchasing the same phone used and using its housing or some "dummy" phones can be used for there housings also. If the scratch is not really bad I have used rubbing compound to remove fine scratches, good luck!
Sep 03, 2008 | Cell Phones
I HAVE A POLAROID a700 DIGITAL CAMERA WHICH HAS ITS LCD SCREEN 9 (OUTER, STICK ON)BADLY SCRATCHED. WHERE CAN I GET A REPLACEMENT, PLEASE?
No replacement available.
protective cover is the most likely option
http://www.google.co.uk/search?q=LCD+screen+protection+patches&sourceid=navclient-ff&ie=UTF-8&rlz=1B3GGGL_enGB260GB260
Aug 20, 2008 | Cameras
Big scratch on outer layer of glass
I tried the advertised Eyeglass fixer "Liquid Lense" treatment with good success
Apr 20, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Polaroid FLM-2601 flat screen
It has a protective outer screen and depending on the depth of the scratch you might be able to restore it. You'll need to look on-line at a few aircraft site for a kit that is meant to polish scratches from the plexi in an aircraft windshield. There is a company in Oregon http://www.chiefaircraft.com/airsec/Aircraft/Windshields/ScratchRemoval.html
that sells the kit for 34.95....
It is time consuming but I have restored many this way!
Bill
Mar 27, 2008 | Polaroid FLM-2601 Television
Nintendo ds lite touch screen protective outer layer(plastic)
you must send it in to Nintendo, for a new touch screen or take it to your nearest GameStop video store.
Dec 18, 2007 | Nintendo DS Lite Console
Scratched tv screen
I replaced the screen on my 62 inch projection TV for about $50 and the the picture quality is good! Have a sheet of plexiglass cut to the EXACT size needed. BEFORE installation it MUST be frosted on both sides by either a fine particle sandblaster or by sanding it VERTICALLY on BOTH sides with a power sander and a fine grade paper.
If this is only an OUTER protective screen and the image is projected on the inner screen then DO NOT frost the replacement screen, just install it.
Mar 18, 2006 | RCA P61927 61" Rear Projection Television
Mitsubishi WD-52631 52" Projection HDTV Logo
916 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
