Question about Vizio L32 32 in. LCD HDTV
How can I get the volume to work with out a humming sound? I have to raise the volume up to the top to hear the tv
  • 178 Answers
It may be the device(cable box, game system ?? ) connected to the tv has a volume control as well and that devices volume control is set very low. is dvd or vcr input fine? Is this connected to a computer, then check the volume control on the computer.
Posted on May 08, 2010
2 Suggested Answers
pazman
  • 81 Answers
SOURCE: No sound
maybe in your cable box
Posted on Apr 09, 2008
Tv works but no sound
Hello Jjwpod hi, to find where the trouble is, you need to place ear near speakers, you should hear a humming sound, adjust the volume up or down, the humming sound also goes up or down, this means your amplifier is working, no hum means trouble in amplifier.
summary:
No hum: trouble in amplifier, speaker connection.
Humming, but no audio: problem before amplification, most likely the Sound IF stage.
Sep 16, 2010 | RCA F27615 27" TV
I have no audio
Hello sir, Hi, No Audio on your TV can be user error or Hardware error, for the user error, make sure that the TV is not set to low volume or the setup is on MUTE, for the hardware error, Place your ear close to the speakers, then set the volume up and down several times, you should hear a soft hum that goes up or down, (make sure that the room is quiet.) The soft hum means that the power amplifier is working properly. so the problem may be on the main board where the sound is being produce before amplification, usually the sound IF section. NOW if you did not hear the soft hum, problem with the amplifier and speakers, A physical checking for open wire contact or loose connection is needed.
Aug 20, 2010 | Sharp LC46SB54U 46 in. LCD TV
Our 52 inch samsung plasma tv makes a humming sound when on. is this dangerous. comcast said it should not be happening
Try this.....
Turn cable remote volume all the way down. Raise the volume all the way up with your TV remote. Lower the volume with Cable remote to your usual listening volume.
Feb 12, 2010 | Samsung DLP HL-P5663W 56" TV
Hum from tv
try unplugging any equipment that you have attached to the tv one at a time, such as dvd players, surround sound, cable box, etc. also if you have a cable box attached, try adjusting the volume on it. if you have everything unplugged from tv and it still hums, then it may be a tv issue
Oct 21, 2009 | Televison & Video
Low volume output and very low volume when digital broadcast
if you are using a digital converter along with a standard tv , you have one volume level low making the unbalance sound a humming sound, if it is directlly into your tv, check your settings on your tv bass, trebile, by the sound of it you probably have a digital converter , if this is so, raise the volume of your TV to mid point that raise /lower your volume on the converter and it should be fine, also make sure your ouput channel is not the same as your broadcast channel in your area, example,,if your area uses channel 3 for broadcast, set your rf output to chann 4 , and vice versa.
Aug 21, 2009 | Televison & Video
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
Humming sound from TV
take your tv to a technian and ask him to check the power supply filter.
some of the ac ripple are passing through to the main amplifier.
a filter comsist of ( semi comductor, inductops and capacitors.
Sep 26, 2008 | Toshiba TheaterWide 62HM94 62" Rear...
Tv makes humming noise when on. how can I eliminate or reduce the nose?
Some of the larger TV's are DISH ready, meaning that they have the tuner inside for SAT TV. The SAT tuners often have an internal fan that makes a humming noise. If it sounds like something other than that, you might have a bad component in your sound circuit that allows 60 HZ hum through the speakers.
If it is a rear projection LCG TV it has a fan in it to cool the bulb. You will hear the fan if you listen closely. It usually cannot be heard over the volume.
The fluorescent bulb and electronics inside make humming sound naturally. Kinda like when you turn on a lamp, and some lamps make a low humming sound.
Apr 03, 2008 | Televison & Video
No sound
Mar 30, 2008 | Pioneer PDP-4360HD 43 in. Plasma...
Vizio L32 32 in. LCD HDTV Logo
181 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
