Question about NetGear MR814 Wireless Router
I am trying to set up a used router, but can't get
I have a gifted router, and when I try to load the wizard from the netgear website, it won't load.
Is ther another way to set up the router witout the wizard?
  • 88 Answers
Not at all unfortunatelly.
First make sure if you run first setup from CD already. If no then do it, if yes then
Setup wizard runs through browser.
Try to run it like that:
1. Open browser (firefox, internet explorer, opera, whatever)
2. type in address bar: http://192.168.0.1
3. There should appear enter username/password
4. Defaults are: login: admin, password: 1234
Cheers,
Mike
Leave rate if I helped you, thanks!!
Posted on May 08, 2010
Trying to reset netgear genie default user name from admin
Admin may not be a permissible username as many companies ship theirs set as admin. Try a different user name.
Oct 16, 2016 | NetGear Computers & Internet
No internet connection
Check if you can , by pass the wizard and set the connection manually. Let me find more details for you
Thanks
proton
Jul 24, 2008 | NetGear RangeMax WPN824 Router
How to instal
You'll wanna check out: ftp://downloads.netgear.com/files/WNR1000_SM_WW_23Jan09.pdf
Look for "installation"..
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready!
You can set up your wireless router using one of two methods:
• Smart Wizard Setup: The Smart Wizard Installation Assistant setup is available on your Resource CD. See "Installing Your Router Using the Smart Wizard" on page 9 to use the Smart Wizard Installation Assistant.
- This is the easiest option. The wizard guides you through the setup process. It automates many of the steps and verifies that the steps have been successfully completed.
- Smart Wizard requires a PC running Microsoft Windows.
• Manual Setup: If you cannot or prefer not to use the Smart Wizard Installation Assistant, see "Manually Installing Your Router" on page 13. For example, if you are connecting to a Mac, are using a Linux operating system, or are technically knowledgeable, select this option. If you choose to use this option and install your router manually, for best results, install and set up your router in this order:
Failure to follow these guidelines can result in significant performance degradation or an inability to wirelessly connect to the Internet.
NETGEAR does not recommend or support adding a NETGEAR router behind another router, or replacing a gateway with a a NETGEAR router.
If you have a Macintosh or Linux system, you must use the manual installation method (see "Manually Installing Your Router" on page 13).Getting to Know Your Wireless Router 7
1. Install and connect your wireless router to your network (see "Connecting Your Wireless Router" on page 14).
2. Set up your wireless router for Internet access (see "Setting Up Your Router for Internet Access" on page 18).
3. Configure your wireless network and select wireless security settings to protect your wireless network (see "Configuring Your Wireless Network" on page 21)
Feb 04, 2011 | NetGear WNR1000 Router
Trying to connect netgear wgr614v9 router to new toshiba computer with windows 7 ....setup says unsupported operating system....what do I do
As netgear setup disc doesnot support Win 7.
U need to manually setup the netgear product
-- hard resett the router using a restore factory setting hole on the back of the router
-- open the netgear router page using www.routerlogin.com
-- Username - admin , Password - password
-- run setup wizard
-- if it detects dynamic ip then press next
-- and on the left u will see wireless settings under setup .
-- secure the network using WPA_PSK(TKIP)
-- and then apply .
In case if it will detect static or fixed ip .
Then click on " Basic settings "
-- Under router MAC address
-- select "use computers MAC adress "
-- Apply
-- And then Powercycle the network..
-- And u will be able to go online ..
Jan 02, 2010 | NetGear WGR614 Wireless Router
NETGEAr support
not sure exactly why you would need the setup software... you should be able to plug it in and access the routers firmware and set it up that way.
here is the link to the site for your hardware.
http://kb.netgear.com/app/products/model/a_id/2591
Jun 01, 2009 | NetGear WGR614 Wireless Router
Netgear DG834G v3 Installation
connect the yellow (or blue?) ethernet cable to your computer, this should connect to the router (router should be ON)
Now, in internet explorer type 192.168.0.1 (this should be the defualt gateway for the router on default settings.
Now you're into the router, there should be a setup wizard button in there.
See if you can set it up using that
Regards
Tony
Feb 28, 2008 | NetGear DG834G Router
First use the Netgear setup wizard:-
Open Internet Explorer
Enter http://routeraddress e.g http://192.168.0.1
Click Setup Wizard (top left)
Then for With AOL make sure you have set these values in the Netgear
ADSL settings as PPPOa
VC 0,38
MTU setting to 1400
If you still have problems
Start -> Control Panel -> Add/Remove Programs -> select AOL Connectivity
click Add/Remove -> use the repair option
Follow instructions to repair.
Once complete make sure modem is configured and switched on and
try restarting AOL.
It should search for your connection, find it and allow you to log on.
Feb 06, 2008 | NetGear DG834G 54 Mbps 802.11g Wireless...
Xbox 360 live and netgear WGR614
Down load the new firmware and install it in your router.
http://kbserver.netgear.com/products/WGR614.asp
Use UPnP. If your router supports this. Turn it on. The router will work out the ports it needs to open for Xbox live. If your router does not have this feature, check the manufacturers website for the latest firmware. (also make sure portforwarding and/or DMZ is turned off as they interfere with UPnP)
Oct 16, 2007 | NetGear WGR614 Wireless Router
NetGear MR814 Wireless Router Logo
246 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
