Question about Kenmore 24902 Top Load Washer
Kenmore washer Hi, Don't have my washer model # with me right now, but when it gets to the rinse cycle it almost always pops the gfi breaker. I already have changed the gfi outlet and the breaker at the box. Any suggestions? Thank you.
    Genius:
  • 1,224 Answers
Its possible you need to give it a tune up call local repair man for costs of tune up's some can come out and tune up at home for you
Posted on May 07, 2008
SOURCE:
Kenmore 110-88752793 washer dryer. Tub filled up for the rinse cycle and then stopped. Tried turning on the dryer and that has no power either. Cycled the circuit breaker. Still nothing. Any ideas?
The circuit that supplies your washer and dryer may also have an in-line GFI outlet which may have tripped. Even though you have cycled the circuit breaker you would also have to reset the GFI outlet as well. Good luck.
Nov 26, 2016 | Kenmore Washing Machines
I have a kenmore dishwasher quitewash1 it will not get power or come on
Make sure the circuit breakers to the dish washer are on. Cycle them off then on to make sure. This will reset the GFI breaker. Plug the machine into the wall plug and make sure the wall plug in not a GFI also. If it is reset the wall plug and you should have power.
Oct 17, 2013 | Dishwashers
My Kenmore he front load washer stopped at the rinse and spin cycle. I don't know the model but it only a few years old. It made a load noise before stopping. I attempted to get it going again wit
Kenmore front loader. stopped at rinse. First ck to see if you washer works at different settings if so its very possible its your timmer or what called the wig wag or solonoid this switches the machine to spin & rinse. A basic service call should resolve your problem.
Jan 30, 2012 | Washing Machines
Older Kenmore model 110.82673110 washing machine keeps tripping the GFI. Replaced GFI but problem persists. How can I fix this?
i would install a regular outlet... and if the circuit breaker blows. then their is a direct short within the washer .i never heard of GFI being used on a washer ..remove it.. their may be other outlets on this circuit also that can adding to it tripping. like frig.. find out what is on that circuit by shutting off the breaker for washer see what else goes off...
Aug 24, 2010 | Kenmore Washing Machines
Kenmore series 70 fills with water on rise cycle but stops halfway throught then starts agian and finishes is this normal
If this has always stopped during the rinse cycle, most likely it's the "cool down" part of the rinse cycle.
See the following Sears site for manuals. Enter your model number and you should be able to download the proper manual for your washer.
http://www.managemylife.com/mmh/owner_manuals/
Aug 01, 2010 | Kenmore 24032\24036 Top Load Washer
Washing Machine Pops GFI Circuit
I agree. could be heater or motor..try disconnecting one wire on heater then trying if still same try unplugging motor plug ...this will say which one..please leave feedback..
Apr 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have a Kenmore top loading washer model #110 and won't agitate
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
Nov 14, 2009 | Kenmore 22422 Top Load Washer
I have a Kenmore washer. the water temp switches by itself.
IM NOT SURE HOW YOUR WASHER IS SET UP ON TEMP SETTINGS BUT-- THE RINCE CYCLE IS ALWAYS COLD RINCE
Nov 03, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 - in mid spin cycle the machine tripped GFI
check your pump ,,, sounds like you gotten something in it putting a strain on the motor to overload your breaker
Nov 17, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24902 Top Load Washer Logo
71 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
