Question about 2wire (1000-000057-000) Modem
Hook up 2 units to a 2wire modem with only 1 input I AM 90YEARS O
Huck up 2 units to a 2wire modem with only 1 input
  • 88 Answers
There are splitters but it won't work so don't bother buying.
Modem "does not know" how to split signal through 2 devices.
Cheers,
Mike
Leave rate if I helped you, thanks!
Posted on May 08, 2010
2 people on modem . router 2wire... and when one is one , other gets kicked off can't fix help
Try this links:
2wire installation guide: http://support.2wire.com/?page=view&article=765
changing wireless settings: http://support.2wire.com/?page=view&article=60
wireless configuration guide for windows XP: http://support.2wire.com/?page=view&article=224
wireless quick reference guide: http://support.2wire.com/?page=view&article=47
note: 2wire is already a wireless router / modem need for other modem to have a good network at home
if you are with At&T AT&T ' Yahoo! High speed Internet
Call +1 877 722 3755 (877-SBC-DSL5)
Aug 29, 2011 | AT&T High Speed DSL Modem
How do i setup my 2 wire router with dsl modem to network iat home
Try this links:
Aug 12, 2011 | 2wire (2701HG-B) Wireless Router
Trying to hook up 2wire modem to internet provider?
there is a cd-less install or Greenlight technology in it. it will automatically startup once you open a browser, (preferably IE. However, if you don't see it, try pushing the reset button at the back of the unit for 30 sec. open IE, then you will see the installation page.
NOTE: make sure you know what your username and password is... for authentication purpose...
links that may help: 2 WIRE Activation keys
http://www.2wire.com/?p=268
Try this links:
Jul 20, 2011 | 2wire (2701HG-B) Wireless Router
I have a 2wire 397 modem router from att in line ,i want to add another 2wire modem router in line to a different room to hook up a samsung 3d blu ray to go on the internet
you cannot have 2 modem routers on the same line, if your current modem router has wifi, you might consider using a wifi repeater that will pick up the signal elsewhere and give you added lan ports. alternatively, you could just run a lan lead to where your samsung is and use a 5 port lan switch.
Apr 26, 2011 | 2wire (2701HG-B) Wireless Router
Trying to hook up DSI to AT&T 2701HG-B gateway to make it wireless
hi,
So you want to connect your Nintendo DSI to your 2wire modem.
Here are the steps for connecting you DSI wirelessly:
1. First you need to realize that the game console the requirements for the wireless password should be WEP.
2. Open the Nintendo DS setup Utility
3. Select the Nintendo Wi-Fi Connection Settings
4. on the next page just click on the search for an access point.
5. then click on your wireless name.
(when you still using the default name for your 2wire it will be 2wirexxx "XXX last 3 numbers of the serial number of the 2wire modem")
6. when it is asking for the wep key it is the 10 numbers under the barcode of your 2wire modem.
7. Select No under Auto-obtain IP Adress.
8. click Save settings.
this is the steps on connecting your DSI for wireless connection.
If this doesnt work call At&t for connecting your DSI.
Thank you for choosing FIXYA.
Mar 04, 2011 | 2wire 2700HG-B Router (2700HGB)
How do i hook the router up
The router has several connections on the back, there's the Power (goes to AC Adapter), an Input RJ45 that is connected by RJ45 cable to the Cable/DSL modem, and several other connectors that can be connected to different computer Network Inputs. That's about it.
Oct 15, 2009 | 2wire (1000-400108-001) Router
How to connect 2wire 2700 HG-B router to voice modem motorola
that 2wire only works with DSL services, if you are using cable internet then no it wont work. If the surfboard digital voice is just a VOIP router then yes, plug the surfboard into one of the ethernet ports on the back of the 2wire.
Jun 06, 2009 | 2wire 2700HG-B Router (2700HGB)
2wire gateway
The modem is a Gateway 2Wire model 2701HG-D. Its function is to handle the high frequency data carrier that rides on top of your ordinary telephone wires to provide internet access. It has four ethernet ports and one USB port in addition to the telephone connector. QWest has said there have been problems with it and they recommend that you purchase a newer model for $100.
Ours failed yesterday with a bunch of green lamps glowing steadily without the normal blinking. The lady was about to go downtown to purchase a replacement when I figured out how to open the box with its four springy plastic bending tabs that you can see looking through the cooling apertures.
What I found was an internal operating voltage of about 4 volts which was well below the 5.1V printed on the power brick. When I ran the modem from a laboratory grade 5 volt source it seemed to work drawing about 1 ampere without any connection to the phone line.
Measuring the 5 volt supply that came with the modem I saw 5.2 volts but when loading it to 100 milliamps or so it dropped to 4 volts. It was definitely out of spec. Replacing the brick with another brand rated at 5 volts, 2.2 amperes solved the whole problem.
A failing power supply usually turns itself off but in this case measuring its output with a voltmeter would result in a conclusion that it was OK. Not so. You have to measure it under load which is a bit harder to do.
So. . . Don't rush to buy that new modem the way QWest says. Consider a replacement power brick. Positive 5 volts on the center of the connector with 2 amp capability. The original power converter used a three pin grounding plug for the AC source and the ground was connected to the negative side of the DC output. That's not normally done and does not seem to be necessary. It would make more sense to connect to the telephone company ground but that wire may not be available in the 6 pin telco socket.
Part numbers on the failed power brick
P/N 1000-500031-000
Part No GPUSW0512000GD1S
Input 100-120Vc.a 50/60Hz 0,15A
Output 5.1V DC 2A
Class 2 Power Unit
Made in China
And. . . after cracking the shell of the power brick the input aluminum electrolytic capacitor showed typical deformation of the round aluminum end. That kind of failure is very much a part of my life these days. Sigh.
May 13, 2008 | 2wire (1000-000057-000) Modem
Computers, modems,printers
Hello kingskidrick,
If you want to hook up a fax phone into the loop, first thing you have to do is get an ADSL filter from your ISP or wherever you think it is available. Make a parallel connection from the telephone cable, connect this filter's input to telephone and the output of the filter ( marked as telephone) should be connected to fax phone.
Thank you.
Mar 17, 2008 | 2wire 2700HG-B Router (2700HGB)
2wire (1000-000057-000) Modem Logo
79 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
