Question about Acer Aspire 5315 Notebook
Cant forma acert my 3100 - Acer Aspire 5315 Notebook
  • jarsp May 09, 2010
    i restore my labtop i had install xp so i restore it to vista but it not working good so i want to install xp back in but it wont take my xp disk i try everything but it wont take it how can i install xp back in i went to dos but
    still wont take the disk how can you help me thank u
  • Mike
    Mike May 11, 2010
    Hello, Please post more info, what are you trying to format and how. Cheers, Mike Leave rate if I helped you, thanks!
  • 476 Answers
Please check my tips and tricks link below...
http://www.fixya.com/support/r4498094-erecovery_reinstall_acer_factory
Its a straight forward process,Please rate me thanks
Posted on May 09, 2010
  • Verne Koti May 12, 2010
    The disk with XP on it you will need to have the cd key to reinstall and this means all info you have previously installed will be wiped from the current XP installation.
    What to do from here????? Theres lots to do......
    Put in your XP disk in to the cd tray.
    change the bios boot up to cd/dvd,
    to do this hit the F1 key when start up happens and go to boot sequence and change it to CD/DVD,
    hit the F5 or F6 to take this option to the top of the list then save and exit,
    when you accept these changes and restart will happen automatically.
    The windows screen will start and check your current settings and devices on you machine,it will start the windows loading process.
    it will now load windows and ask if you want to repair your system,
    Select to install a new install over the existing,
    select the drive and delete the current info,
    then it will ask if you want to select somewhere to install the new info on to the unpartioned drive,
    select enter on the drive you wanna use,
    and then it will format this drive,enter L and its going to delete it,
    wiping it clean for the new windows
    this process will take about 30min approx,
    let it finish this process and make sure you have the cd serial key to finish this process.
    It will prompt you before starting up windows and it will ask for your computer owners details,network settings etc....waiting waiting....
    Finally after all this info is done the windows screen will open up and its just about time to go to the internet to download the drivers for this machine
    much easier if you had the acer system cd,,,,,,
    but the internet will help you finish this step.
    or
    Go to www.acer.co.nz
    then go to service & support
    Next drivers download section
    then a screen opens to help choose the correct model and make
    eventually it will take you to the drivers and applications page
    download from here is free and you dont need to sign up to join or use these web pages or the Acer info either
    Notes - NEW XP INSTALL should take bout 30 to 40 min
    then the drivers download will be straight forward too
    updates are next from the windows update site,SP2 is needed for high speed devices and SP3 disables some of them,,,,
    I really hope this helps fix you problem as you already rated me,
    Next step is to do a back up onto disk so the reinstall is quicker in future,
    Once all is working the way you want it to,do a system restore.
    Find this function by going to start,
    then accessories
    then system tools
    and then restore.
    Good luck and happy surfing,Cheers MISTERDJ
    to reinstall windows XP
    put the disk into the cd tray
    change the bios boot sequence to cd/dvd
    f5 o f6 to move the cd/dvd to the top of the list
    save and exit
    on restart XP disk will start up and scan the machine
    follow the prompts to reinstall XP
    dont repair the existing install just delete the partion and reinstall a new one,
    Follow the prompts and the rest is easy
    you will need drivers from www.acer.co.nz
    go to service n support
    then go to driver download section
    then go to make and model
    drivers and applications are stored here
    Its free and no joining fee either
    Have fun and happy surfing,MISTERDJ
How to test caterpillar c18 acert low oil pressure shut down
This is a critical element to protect the engine. Shop manual is needed. You can try manulslib.com but they may not have it.
So ask the dealer or MFG for one.
Mar 15, 2015 | Caterpillar C18 ACERT Marine Generator Set...
Backfiring thru exhaust
Valve Lash is incorrect, can also be caused by injector fallout ( injector over heated and continues to dump fuel long past its cut off point ).
May 07, 2014 | Caterpillar C15 Acert Engine Wdisplay...
Adjusting turbocharger for caterpillar c15....boost gauge does not get above 8psi
Most turbos are pre set. if you don't know what you are doing you can ruin it. I would look a little closer at the waste gate not performing properly.
Aug 22, 2013 | Caterpillar C15 Acert Engine Wdisplay...
Coolant leakage right side above oil filter
YOU PROBABLY HAVE A INTERCOOLER/PRECOOLER HOSE GOING BAD. IT IS LOCATED BEHIND THE OIL COOLER. THERE ARE TWO OF THEM, REPLACE THEM BOTH WHEN YOU GO IN THERE.
Feb 01, 2013 | Caterpillar C15 Acert Engine Wdisplay...
Knocking noise around pullys/damper
MAY BE THE BEARING INSIDE YOUR HARMONIC BALACER, CRANKSHAFT DAMPER THEY DO WEAR OUT AROUND 500,000 MILES. OR YOU HAVE BEARINGS OUT ON A PULLEY. AND IT COULD BE MORE THAN ONE PULLEY. I HAVE HAD TO REPLACE PULLEY SPINDLES ON MY C15 ACERT BEFORE. IT HAD COMPLETELY CHEWED UP THE BEARINGS.
Nov 30, 2012 | Caterpillar C15 Acert Engine Wdisplay...
To get a new Manual for Coolpix 3100
Please follow the below link to download the User Manual for Cool Pix 3100, its in PDF forma.
http://www.nikonusa.com/pdf/manuals/coolpix/CP3100man.pdf
Sep 30, 2009 | Nikon COOLPIX Cameras
My magellan 3100 won't charge
you cant charge a 3100 with the USB connection. most likely the power port is damaged and needs replaced. i repair those magellan gps if you need help. if i cant fix it there is no charge. wmetz@comcast.net
Mar 26, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Restriction code
Tell what is your Mobile operator name.
May 15, 2008 | Nokia 3100
Acer Aspire 5315 Notebook Logo
62 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
