Question about Kenmore HE2 Plus Front Load Washer
F 21 error code - Kenmore HE2 Plus Front Load Washer
  • castro_bern May 09, 2010
    i did this and the error is still there. Replace Pump?
  • Kenmore Master
  • 8,220 Answers
F21 Long drain Possible cause: Clogged filter, clogged/failed pump. Get the bottom panels screws out and remove it. Tech sheet with erro codes and diagnostics are behind the white motor control box to the left.f 21 error code - 17faa85.jpg379e38c.jpgccf409c.jpg
Posted on May 08, 2010
My washer has the code F 21 can you tell me what the problem might be??
I'd check owner's manual, or Mfg web site for your model.
Feb 10, 2018 | Washing Machines
I have a mit WS65411 shutdown error code 21
thats the error code for Xray protection which is usually indicating an issue with one of the CRTs and the safety shutdown kicks in and the 21 error will be stored.
Feb 05, 2013 | Televison & Video
Error code 21 A1
This means the air intake cover problem.
21
Malfunction of Air Intake Filter Switch Ensure air filter door is properly seated. Ensure front panel is properly installed.
Error codes here: http://www.palomastore.com/paloma_error_codes.html
Mar 03, 2010 | Rheem Paloma Tankless Water Heaters...
Mitsubishi tv error code 21
The service manual does not list an error code for "21".
Here are the error codes:
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Sep 13, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Error code 21
There are 3 step to repair 21 error
If you got 21 error then there is a 94% chance that your computer has registry problems. To repair 21 error you need to follow the steps below:
* Step 1 - Download a Perfect Optimizer,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair 21 error.
Jun 09, 2009 | Yahoo Mail
I have Hp Plotter 500 and i am getting error code 21:10.
your printer error message 21:10 is about service station or carriage problem, the fix steps follow here:
http://www.computercarefiles.com/TWI_Docs/bpp90134/default.html#P16_845
hope help you fix it. take a rating let me know how much helped you thanks!
May 21, 2009 | HP DesignJet 500ps InkJet Printer
What is a code 21 on a WS65809 mean? My red crt is not working.
X-Ray Protect circuit error code 21, make sure your counting it right because code 12 is no error
May 07, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Error code F-21
Hi there, I think the first thing you need to do is check the pump and make sur ethe impeller inside the pump is actuall turning and in good shape. Something may have passed through and in the course, sheared off the impeller fins. Chekc closely... Thanks
Mar 22, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
233 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
