Question about Mtd 22" Yard Machine Push Mower
We have a self propelled Yard Machines push mower. My husband tried to start it for the first time this year. After much effort, it would turn over, but not stay running. Any suggestions?
    Problem Solver:
  • 8 Answers
Drain all gas add fresh gas ,pull and clean sparkplug or replace. also check float in carborator might be stuck if this does not work check compression.good luck
Posted on May 09, 2010
My yard king performance 675 series has problem with self propelled unit.
your drive belt that turns the self propelled unit is worn or stretched and not turning the gears. or the gears themselves are worn down causing them not to engage. check your belt first that is most likely your problem. hope this helps
Sep 11, 2015 | Kelty Yard King 21" Push Lawn Mower w/...
I have a 675 series self propelled push mower. i hit a stump in the yard and now it will not start. what happened?
Hi ddjklamar...
You most likely sheared the flywheel key, and that causes the flywheel to turn and not be in time to start.
Remove the flywheel and replace the key, that should solve your problem
Please take time to rate me
Aug 23, 2011 | Briggs & Stratton Garden
I have an older 21" self propelled mower with a push button starter and pull rope starter. Neither will start engine.I
Need more info on what happens when you try and use the electric start and the rope start- does the engine turn over at all with either one?
Aug 15, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I have a yard machine 5.75hp self-propelled mower won't start
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Jun 01, 2010 | Mtd 22" Yard Machine Push Mower
How to tight my drivimg belt in my push mower honda
The model shown 11A-034F200 is not a self propel mower. Now if you have a self propel mower, most of the time, the only way is either replace the belt or there may be a spring. I will not be able to tell you further without the proper model number.
Good Day.
Oct 09, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Lawn mover will not start, was flipped over
The clicking noise may be the blade hitting the side of the mower or it was not put on properly. It needs a balance to the aluminum flywheel on top of the engine. The blade adapter and blade provide this balance for the engine to run.
Good Day.
Oct 07, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
I have a self propelled MTD Model #12AV55DQ513
CONTACT A LOCAL MTD DEALER. GOOD GUESS WOULD BE 100.00
Sep 21, 2009 | Mtd 22" Yard Machine Push Mower
Self propel issue's
I am not sure what the problem is but may be. A couple of things I would do is check and make sure that every thing with the self propel is as it should be like springs not broken or bad connectors. Also I would make sure that all bolts are tight that holds the self propel unit. The first thing I would check is see if all the wheels are at the same height.
If this doesn't help I would go to the Troybuilt web site and see if they have tech support, or see if they have a phone number under contact and call them and talk to some one there.
Good luck. I hope this helps.
roundo4
Aug 14, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Self propelled Yardman won't engage - cable problem I think???
are you in vero beach if so you can email me and i can fix it tj_gunter@comcast.net
May 21, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Mtd 22" Yard Machine Push Mower Logo
138 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
