Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
Thin blue line
I have a thin blue line which runs vertical intermittently on the left side of my screen. It can take hours before it appears and then goes away. Sometimes when it appear, it flickers
  • earlthe3rd Dec 17, 2008
    Same TV. One week after factory warranty expired, a thin blue vertical line showed up in the upper left quadrant of the screen. This line does not go away and has been constant for about two months now.
    Sniper:
  • 53 Answers
I am a Sharp Servicing Technician. You posted this before. Ive got the same model TV as you do LC46D62U. I think the line you are experiencing is simply the broadcast. I notice it on some HD shows that broadcast the side bars. (Always on the Ellen Degeneres Show). Ive taken some picture.
1) Here's the line on the left that i experience
2) Later on in the broadcast, it goes away.
One way to check if its a TV problem or not. When the line shows up again, hit the MENU button on the remote. If the line appears to be "behind" the menu, then it is simply the broadcast.
If the line appears to be "on top" of the menu or shows right through the menu, then it is a TV problem.
Im thinking the reason it takes hours for hte line to appear is because it only shows up on certain shows or certain HD broadcasts.
Posted on Mar 28, 2008
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | RCA MM36100 36" TV
Blue thin vertical line on my monitor.
LCD needs to be replaced.
Common problem called "Tab separation".
Mar 22, 2009 | HP Compaq Presario R4000 Notebook
Samsung 26inche lcd tv has a blue thin line acrross the left side
call the repair guy, he will be able to diagnose, prbably a bord problem.
Dec 23, 2008 | Televison & Video
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
Blue vertical thin line on Acer Travelmate 2410
It might be the case that the pixels of that line have become dead.This is a monitor malfunctioning and you shud report to your vendor.
Feb 04, 2008 | Computers & Internet
40 inch lcd blue line vertical
The display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Hope ya fix it!
Jan 06, 2008 | Samsung LN-S4051D 40 in. LCD Television
On screen thin yellow and blue vertical lines.
Unfortunately the LCD is going faulty.. one or more of the "Driver" transistors that operates the LCD elements RGB, have faulted ON.. perhaps this link may help fix it. Otherwise :( http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Apr 21, 2007 | NEC LCD
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Jan 01, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
1,277 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
