How do I reset the dollar amount on the display center? Right now ther is nothing there.
  • bmc2 May 08, 2010
    It's a Maytag Neptune coin operated washer Model # mah21pddww. I have no display at all on the circuit board and the machine will take coins but not register them The only way I can get the washer to go anything is to remove the top service cover and an d-5 error lites up. If I push the delicate button the whole board lite up and the I can do a test cycle by pushing one of the other buttons, Once the test is over the board goes blank again, In normal operation it is supposed to flash between normal wash $2.00 and super wash $2.25 and when the coins are put in it should count down on the screen.
  • bmc2 May 09, 2010
    how would i reset the door error code?
  • 10,515 Answers
Kindly tell me the Make and Model of the Washer?
Kindly Explain the Question in Detail?
Let me know,so that we could Proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 08, 2010
  • taran_2005
    taran_2005 May 09, 2010
    Thanks for your response!!
    D-5 is a Door Error Code. You could Download the Complete Service Manual for Inspection or Reset.
    The link for Service Manual is :-
    http://servicematters.com/maytag_library...
    Let me know,if needed further assistance.
    Hope i helped you.
    Thanks
  • taran_2005
    You cannot Reset Door Lock Error Code. If at Fault, it has to be Replaced. The Service Manual have all the Details that is needed to Fix all the Problems.
    Hope i helped you.
    Thanks
I have a sam4s ER-5200M. Today it started printing a 4 in front of all prices on the receipt. The screen says the correct amount.
http://cashregisterguys.com/files/Samsung_5200_40M_man.pdf
i saw this on page 116,it looks relevant,,,,,,,,,21.. Display add price of linked item? When Y, the customer display shows a total of the item and linked item. For example, if PLU is $1.00 and is linked to PLU2, which is $0.25, the display will show $1.25.
it doesnt add 40 dollars so that leads me to believe that there is an error with the printer,you might need to reset and start over or call the company,good luck.
Apr 21, 2015 | Retail Supplies
Tip
Ford-Lincoln service light 1988-01
LS
2000-01
To reset CHANGE OIL SOON/OIL CHANGE REQUIRED message on the Message Center, press the STATUS control to access the System Check mode. Press the RESET button to display OIL LIFE _% RESET FOR NEW. Press and hold the RESET button until OIL LIFE IS 100% is displayed.
Mark VIII
1993-97
When "CHANGE OIL SOON" or "OIL CHANGE REQUIRED" is displayed on the Message Center, turn the ignition on. Press and hold "OIL CHANGE RESET' or the "RESET" button until "OIL LIFE RESET TO 100%" is displayed on the Message Center.
Continental
1989-94
When "SERVICE" is illuminated, on the Message Center, press the "SYSTEM CHECK" button on the right of the display. Then press the "RESET" button. The "SERVICE" symbol and mileage will start to flash. Next, press the "SYSTEM CHECK" and "RESET" buttons at the same time. The display will show "7,200 miles/11,580 km" and will count down from there as long as the buttons are depressed. Release the buttons at the desired service interval.
Continental
1988
When "SERVICE DUE" is illuminated on the Message Center, press the "CHECK OUT" button located below the display. Then press the "RESET" button. The display should now read "SERVICE DONE?" Next, press the "CHECK OUT" button and "RESET" buttons at the same time. The display will show "7,200 miles/11,580 km" and will count down from there as long as the buttons are depressed. Release the buttons at the desired service interval.
on Dec 07, 2009 | Ford Lincoln Continental Cars & Trucks
Why is there so much frost in the freezer?
Hello friend, thanks for your post!
From what you are describing it sounds like you may have a bad gasket or seal. The best way to test this would be to place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then replace the gasket. I hope this is helpful. -Matt
Oct 01, 2014 | Electrolux Refrigerators
I see moisture between the glass panels of the door.
Hello roderick234 - From what you have described it sounds like the beverage center has a poor door seal. When cold air and warm air outside is entering it causes condensation. Try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then I suggest contacting your manufacturer and see who they recommend to repair the unit.
Nov 10, 2012 | Electrolux 6.0 Cu. Ft. Beverage Center -...
My lg l5 is displaying that i have a unread message but theres nothing there
uI also have the same problem.. im tired of resetting my phone.. is ther any other way? Please help.. phone is lg optimus l5 e612
Oct 13, 2012 | LG Cell Phones
665.68601890 Acts as though it is not receiving power but breaker is not thrown. Is there an internal reset. Nothing responds - no lights, fan or microwave. Panel is black and non responsive
ther is on most microwaves a fuse inside usually located behind display panel located in a fuse block or will be on the control board itself.. normally a 20 amp fuse...try that first if not then make sure you have power to control and if so and no display most likely the display control board...
may luck out and be just the fuse though....good luck
Jan 08, 2011 | Kenmore Microwave Ovens
The repair man said we need anew screen for 1000 dollars. tv is 4 years old and iI pais 2200 dollars, I bout it from Costco Westbury Ny I paid 169 dollars twice,they couldn't fix it. When we turn on it...
Somehow I don't believe the Display is bad. This sounds like either the Z sustain board or the logic board is bad. Besides, that display costs more than $1000.00, so that raised a red flag to me right away. My recommendation is to take it into a more reputable service center in your area.
Dec 10, 2010 | Maxent MX-42HPM20 42 in. Plasma HDTV
Unit does not start and displays the code E1 or El
to fix is probably 100 dollars . to get new is 100 dollars
Jul 04, 2009 | Haier 539490003 Air Conditioner
Kenmore Dishwasher - Wife Having Meltdown
Get under the sink and pull the plug. Let it sit for a half an hour or so. While you wait make sure all the drain screens etc. are clean. Usually unplugging will reset board. Kind of like a reboot on a computer. I hope this works usually does if something else major isn't wrong.
Jan 18, 2009 | Dishwashers
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
