Question about KitchenAid KHWS02R Front Load Washer
Pump Pluggage Feather pillow broke open in wash. Code F 02 for drain pluggage. Verified that drain hose was clear. Assume that the feathers are plugging the intake to the pump. Machine pumps out the water at a trickle. Any ideas?
    Brigadier General:
  • 4,090 Answers
You have solved your own problem here.
The pump itself is clogged. Not sure if you are savvy with taking the pump off this model, and opening it up. It is really a workshop job rather than a DIY.Some of the bolts are in tricky places and it can also be a pain to put back correctly. The outer casing of machine has to be removed (ideally) to get to the pump easily.
Please rate my help++++Thanks for using FIXYA
Posted on May 08, 2010
Washer will not drain even after changing water pump
There is a drain pump that is separate from the main pumps on most kenmore elites. There is also a check valve that could be stuck open. 8 of 10 times, however, if the machine was working fine and is now not fully draining, this is due to a drain hose pluggage or kink somewhere between the drain pump and the discharge into the sink. I've seen grease totally block the discharge into the sink trap and cause this problem. This should be thoroughly checked and must be 100% clear for the dw to drain properly.
Apr 22, 2014 | Washing Machines
Dishwasher would not drain
Your drain line some where is plugged or kinked. Try taking it off from under the sink where it is attached and blow should blow water or air into the dishwasher if not plugged
Mar 10, 2014 | Kenmore Dishwashers
Washing machine clogged with feathers
The pump is plugged most of the time it is under the washer take the hoses off and clean it out. Make sure to try to get ant feathers out of the hoses also
Sep 05, 2012 | Washing Machines
Hi; I have 55FLBWW and the np light keeps flashing, and will not go any farther.
Are you sure its NP and not ND the nd is for not draining, either your pump filter is plugged of the pump is clogged up and needs cleaned out, coulsd aslo be your drain hose. Best way to check is use a shop vav on the drain hose and **** up all the water you can that way, then take the filter cover off the pump filter (in front and under the bottom cover) and check for pluggage, if none is there then the pump may be clogged or not working.
Mar 12, 2011 | Maytag Neptune Washer
My Kenmore dishwasher leaves water in the bottom of the dishwasher. Is that OK? I notice the water when I clean out the bottom tray.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Jan 18, 2011 | Kenmore Washing Machines
Duck Feather Pillow In Washer. Feathers everywhere. door will not unlock or drain water. help
Pull off the lower front panel and reach up on the right of the washer to the door lock assembly you will feel a tab hanging down pull it and the door will release. Clean out the drain filter and pump hoses etc. Rise it out and you may have to clean the filter a few times.
Nov 29, 2010 | Maytag MAH8700A Front Load Washer
Frigidaire frontload FWT449 will not drain water
clean the filter and or the pump.to drain lift hose out of outlet pipe and lower into a bowl
Jun 28, 2010 | Frigidaire FWT449
Daughter washed a feather pillow which fell apart in front load frigidare washer now it wont spin and drain can u help plz?
The drain is plugged...
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 30, 2010 | Frigidaire ATF6000ES Front Load Washer
I washed a feather pillow and it busted, now it wont pump water out.
There is a filter down in the bottom front of the washer (below the drum) that is probably clogged with feathers. It is a pain to get to, but once you get it cleaned out, the washer should spin and drain without problems.
Oct 25, 2008 | GE WSXH208A Front Load Washer
KitchenAid KHWS02R Front Load Washer Logo
130 people viewed this question
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
