Question about Kirby G5 Bagged Upright Vacuum
Kirby g5d will not shift into drive - Kirby G5 Bagged Upright Vacuum
    Problem Solver:
  • 5 Answers
Check tech drive sensor, where handle connects to main unit, but you need to open cover off and greese handle slider.
Posted on Aug 23, 2010
Kirby g5 self propels too fast
the slide has shifted forward slightly, this happens when the kirby
is hit against walls and skirting boards. you will need a service by your local kirby engineer. see kirby.com for local agent
Mar 22, 2013 | Kirby G5 Bagged Upright Vacuum
Lost my manual
I am looking for instructions to attach my shampoo attachments,to my G5D, can you help me?
Jun 23, 2011 | Kirby Ultimate G Bagged Upright Vacuum
On the rear of the G5D Kirby there is 2 levers that mash with your foot , one is grey and marked with an "N" the other is green and marked "D", what is its purpose
"D" is for Drive, "N" is for Neutral. You cannot use the vacuum or even roll it into another room until the D is depressed. I believe Neutral is for bag and filter changes, repairs, etc. My thought is that it is designed that way so you can vacuum stairs without having it roll off the step......
So, if you run into the problem sometime that it won't roll, be sure the D is pressed.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jun 04, 2011 | Kirby G5 Bagged Upright Vacuum
Kirby g5 techdrive n/d pedal came off will not stay on
The pedal will need to be replaced. A shift mechanism pressed on the end of the shaft has come off and cannot be re-installed. The drive unit must be removed from the machine, and the pedal assembly and shift cam can then be replaced. This may not be a do-it-yourself repair, as a good deal of disassembly is required.
Feb 04, 2011 | Kirby G5 Bagged Upright Vacuum
Gear shift fell out
This is an easy fix you do not have to fully remove transmission it does help to lower it down by removing screws. Then try to get the right angle and realign the splines I have fixed mine twice, the second time I put thread locker on it and have not had any problem. Steve
Apr 30, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Our Kirby G5D won't start.
Make sure that both safety switches( in front and the bag are) are engaged. To see the video how to correctly attach the nozzle and bag go to:
http://www.goodvac.com
If it doesn't help, then most likely it is a switch. You can buy one on the same website.
Good Luck,
Rocky
Dec 05, 2009 | Kirby G5 Bagged Upright Vacuum
Kirby micron magic g5d 120v.50/60hz lost owners instuction manual
Hello, Here is a link to the shampooer instructions and you will also be able to find a manual there. The G5 manual is out of print, but ANY G series manual will work as they are all exactly the same with difference of color.
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Marci
Jun 14, 2009 | Kirby G5 Bagged Upright Vacuum
Transmission not engaging
In Kirby vacuums with tech drive there is a part called Bracket cam (see it here) that is designed to disengage wheels from transmission. When it starts wearing out Kirby would make crackling noise when on neutral and eventually may not disengage at all. If there was no stage where it was noisy on neutral it may be something else - most likely the pedal assembly broken (see it here). It is not very hard to replace it.
Oct 26, 2008 | Kirby G4 Bagged Upright Vacuum
Kirby 5 Model G5D
is there a re set button on a Kirby. Used the vacuum 2 weeks ago, worked just fine. Went to use it today and it won't start. Any ideas?
Jul 31, 2008 | Vacuums
Kirby G5 Bagged Upright Vacuum Logo
173 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
