Question about Car Audio & Video
Soundstream rubicon 1600 d car audio amplifier protection light on and kiciking on and off at a rapid pace
5 Suggested Answers
  • 13 Answers
SOURCE: don't know to conneect my amplifier connecting firdt a soundstream ecualizer
What are you running in to your amp? If it's a CD player or radio, find the wires from them, disconnect them from the amp and connect them to the equalizer, then connect the equalizer to the amp.
Posted on Jul 12, 2009
  • 269 Answers
SOURCE: i have a brand new soundstream xxx 6500d amplifier
You need to plug in the RCA and speakers you could blow the amp. The amp is sensing no Input and No output. I would unplug the amp wait around 30 seconds then install the rca and speakers THEN install amp to battery + cable. You should be ok.
Posted on Jan 29, 2010
SPL Freak
  • 63 Answers
SOURCE: legacy audio LA590 car audio amp protecet mode
Is that on all the time or are you saying the light is on? If that light is always on that just means it's protecting your amp. If it's off and not playing bass then your in trouble
Posted on Mar 06, 2010
  • 208 Answers
SOURCE: Xplod XM-554ZR Car Audio Amplifier: powr/protect light comes on red not green...
Hi, disconnect all speakers from unit and try again - if red light still shows then your amp has died.
If the light goes green, then start testing for shorted speaker/wiring. This includes speaker wiring to vehicle shorts - there should be an o/c reading on your meter
Posted on May 05, 2010
I've had two soundstream rubicon 1.1600D amp's and they both worked for a while then the amp started to kick off and on. No fuses were blown, and the ground was fine. Any suggestions would be appreciated.
Sounds like a loose power connection? Check All connections, also make sure the impedance is correct 4ohm 8omh 16 ohm the speakers need to match the amplifiers output to work properly. ...
Feb 21, 2015 | Soundstream Car Audio & Video
Why would my 2500 soundstream Rub1 amp keep going into protection mode
Take a look inside it could possibly be a/some capacitor/s. If it is replace more than just one because they can also be going bad. This is a cheap fix they cost less than one or two dollars a piece.(if this is the problem)
Mar 30, 2014 | Soundstream RUB1.2500D 2500 Watts RMS Mono...
Soundstream rub1000d is not sending power to my subs
Does it have power indication, e.g. red light, green light
May 25, 2011 | Soundstream CAR AMPLIFIER, 1 CH, 1000 WTS...
Power to rubicon 404 no sound 4 channels of 2-way high pass
Check RCA,s at the back of the head deck, make sure sub is set to low bass frequency, make sure gain is turned up on the amp and head deck has subwoofer enabled and bass on. If you are powering speakers make sure the balance on the head deck is set to 0. Make sure it's wired up properly.
Jul 22, 2009 | Soundstream XTA240.2 Car Audio Amplifier
SHORT ON POWER SUPPLY
If it only goes into protect mode after the remote voltage is applied, the amp probably has shorted output transistors.
Nov 06, 2008 | Soundstream CAR AMPLIFIER, 1 CH, 1000 WTS...
Sounstream tra 560.2 always in 'protect'
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Nov 01, 2008 | Soundstream Tarantula Car Audio Amplifier
My light on my amp is blinking at a steadty pace.
The amp appears to be in protect mode. The most common reason for an amp to go into or remain in protect mode is shorted output transistors. To eliminate other possible causes, read through the following page. Let me know if you have any other questions.
Amp in Protect Mode - Troubleshooting
Aug 06, 2008 | Alpine MRV-T420 Car Audio Amplifier
Car Audio & Video Logo
127 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
