Question about Sega Master System Console
My sega master ststem dose not wont to turn on the power light does not blink.
  • 47 Answers
Sounds like you have a master system 1 version and if the light on the console is not turning on then your power adaptor is likely faulty. see if you can test the power adaptor with a multi meter. If faulty you can purchase a new one from www.gameoz.com.au
Posted on Oct 14, 2010
Sega genesis wont start up
I had had a problem with my old Sega Genesis console the red light would not turn on even though I had turned the power on after a few se the voltage regulator got very hot really fast you could have a similar issue like I had for this if it is stone cold then it is dead. Try another ac adapter too see if it works if it does work then the ac adapter was bad. If there is no power light being on and it gets really hot really fast then it could be the capacitors that are causing it not to work or the voltage regulator is not working right. So you could buy a new one then.
Dec 23, 2013 | Sega Genesis Console
I need help setting up my Sega Master System, I am unable to attatch it to the tv.
Hi, Sega master system 2 are connected to your TV via an RF cable. One end is RCA which connects to your console the other end is Pal which connects to you TV's antenna inlet if your using the sega RF switch then the RF switch connects to your antenna inlet on your TV and you should have a RCA to RCA cable which connects the console to the switch. Please note these cables and power adaptors can in some cases be faulty. These console are manually tune to VHF-1 frequency so make sure your TV has this frequency. some do tune to UHF but most tune to VHF-1 if you need parts or want your console modified to connect to a modern TV via AV inlets or S-video visit www.gameoz.com.au they stock a huge range.
Jan 30, 2010 | Sega Master System Console
Fujitsu Plasmavision PDS-4233
HI, I haHe a Fujitsu Plasma HDTV Model PDS4233. The TV won't power ON, When i turn on the master power button the light starts flashing a red light repeatedly. I also observed that the Fans power up for about three seconds immediatly after i press the master power button, after the three seconds the fans shut OFF and the light continues to blink.. I haven't observed the light to see if there is a pattern with the blinking..
Aug 30, 2008 | Fujitsu Televison & Video
Hi, Sega master system 2 are connected to your TV via an RF cable. One end is RCA which connects to your console the other end is Pal which connects to you TV's antenna inlet if your using the sega RF switch then the RF switch connects to your antenna inlet on your TV and you should have a RCA to RCA cable which connects the console to the switch. Please note these cables and power adaptors can in some cases be faulty. These console are manually tune to VHF-1 frequency so make sure your TV has this frequency. some do tune to UHF but most tune to VHF-1 if you need parts or what your console modified to allow it to connect to your TV's AV inlet or S-Video visit www.gameoz.com.au as they stock a huge range of Retro gear.
Jul 27, 2008 | Sega Master System Console
Sega Game Gear power problems
try replacing some of the capacitors, that is mostly what causes the problems in the gamegear, mine had the same problem.
Feb 07, 2008 | Sega Game Gear Console
Sega Master System Console Logo
302 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
